стал периодически перезагружаться борд.
сделал ему FACTORYRESET, но перезагружаться он не перестал
[ 119.939169] systemd[1]: Started MQTT Driver for GPIO-controlled switches.
[ 120.294750] systemd[1]: Started Wiren Board MQTT to Modbus TCP gateway.
[ 120.412167] systemd[1]: Started MQTT Driver for ADC.
[ 120.475847] systemd[1]: Reexecuting.
[ 120.635711] printk: systemd: 25 output lines suppressed due to ratelimiting
[ 123.374771] RTL871X: nolinked power save enter
[ 124.160361] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
U-Boot SPL 2021.10-wb1.1.2-g0aab62b564 (Jul 27 2022 - 09:27:30 +0000)
DRAM init ok, rows:16, ncs:1, size: 1024MB
.p0_mpdgctrl0 = 0x01140117
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3c40
.p0_mpwrdlctl = 0x3f3f3734
.p0_mpwldectrl0 = 0x000e000c
.p0_mpwldectrl1 = 0x000f000f
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.1.2-g0aab62b564 (Jul 27 2022 - 09:27:30 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 65C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 1 GiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=3
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net: Could not get PHY for FEC0: addr 0
No ethernet found.
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices... 1 USB Device(s) found
и что-то не то с вашей последней прошивкой, которая stable/67/202210102131_stable_webupd_wb67.fit
после нее ошибки при загрузке и не работает ничего… пришлось ставить 202210101009_stable_webupd_wb67.fit
