Более того я тестировал через Moxa Nport 5150,также ошибки сыпяться
В вашем случае ошибки слишком частые, что обычно бывает при плохом подключении, наводках или аппаратных проблемах:
Feb 17 10:31:32 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 25856 of device modbus:186: Serial protocol error: request timed out
Feb 17 10:31:32 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:31:52 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 21762 of device modbus:186: Serial protocol error: request timed out
Feb 17 10:32:34 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:36: Serial protocol error: malformed response: invalid data size
Feb 17 10:32:34 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:32:34 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:186: Serial protocol error: request timed out
Feb 17 10:32:35 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:32:35 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:186: Serial protocol error: request timed out
Feb 17 10:32:35 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 1 input(s) @ 4 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:33:35 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 1 input(s) @ 5380 of device modbus:186: Serial protocol error: request timed out
Feb 17 10:33:35 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 1 input(s) @ 4 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:33:35 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 4 input(s) @ 121 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:33:35 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 25856 of device modbus:186: Serial protocol error: request timed out
Feb 17 10:33:36 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:186: Serial protocol error: malformed response: invalid data size
Feb 17 10:33:36 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 4 input(s) @ 121 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:33:36 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:36: Serial protocol error: request timed out
Feb 17 10:33:36 wirenboard-A64RO4Z4 wb-mqtt-serial[1698]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:186: Serial protocol error: request timed out
Более того, при воспроизведении на моем стенде сейчас ошибки вообще отсутствуют.
Баг, на уровне ядра, не критический и никак не мешает опросу устройств, кроме предупреждений в логе.
Нет, если вы уверены, что физически все надежно подключено и нет внешних воздействий.
Если у вас есть возможность предоставить доступ через облако, то я еще раз все проверю, возможно мы что-то еще не учли.
И укажите почтовый адрес:
Это очень интересно. Приложите тоже свой диагархив, лог с debug и фото подключения. Если тему не создавали, то разделим, чтобы не запутались.
Я писал выше что на скорости 115200 частые ошибки,на 9600 не так часто
Не только предупреждение в логе. Я заметил этот баг когда нагрузил измерением модуль wb-mai6. И визуально это проявлялось в покраснении контролов. Вот тогда и начал бить тревогу. Хотя когда только получил модули с контроллером точно не было покраснений,но тогда и всего один канал был нагружен. Человек в теме отписался о точно такой же проблеме и к чему она приводит в реальности. Так что это не просто запись в логе.
Я выше выкладывал фото подключения. Проводки 10 см свиты,наконечники НШВИ,оконечный резистор. Придраться по подключению не к чему.
Приглашения отправил,логин и пароль от SSH скинул в личку. Очень хочу что бы проблема оказалась в моем железе/ПО.Дайте знать как закончите удаленное подключение.
абсолютно всё один в один, как у автора темы. у меня пока переезд, и в ближайшие пару тройку недель не смогу плотно заняться сборкой настольного стенда и вопросом логирования и дебага, так как в программе на объекте учёл отваливания. кстати, у меня открыт доступ по SSH и Http на ваш айпишник (ваш коллега там с другой проблемой разбирался: с отваливанием облака, Андрей Радионов) поэтому без проблем можете подключаться смотреть на реальном объекте. повторюсь, там подключение через WBE2-I-RS485-ISO экранированным кабелем 5 метров, на осциллографе картинка интерфейса идеальная на обоих концах, с течением времени никаких всплесков и искажений сигнала не обнаруживается, а контролы окрашиваются в красный. Я сейчас активно пишу код и иногда удалённо обновляю программу, поэтому у нас с вами могут встречаться коллизии во время одновременной работы ))
Благодарю, зашел.
Благодарю, если не разберемся, то подключусь к вашему контроллеру.
Все настройки еще раз проверил, проблем не вижу.
У меня на контроллере при скорости 115200 с подключенным модулем WB-MAI6 с WB8.4.4, WB8.5.3 ошибки возникают примерно 1 раз в 1-2 минуты.
Лог WB8.5.3 (актуальный testing)
Feb 17 11:45:34.965961 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 1 input(s) @ 5380 of device modbus:55: Serial protocol error: malformed response: invalid crc
Feb 17 11:47:45.077230 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:55: Serial protocol error: malformed response: invalid data size
Feb 17 11:49:14.165263 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 1 input(s) @ 5380 of device modbus:55: Serial protocol error: malformed response: invalid crc
Feb 17 11:49:51.860774 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:55: Serial protocol error: malformed response: invalid data size
Feb 17 11:50:31.053302 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:55: Serial protocol error: malformed response: invalid data size
Feb 17 11:51:06.100683 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 2 input(s) @ 1536 of device modbus:55: Serial protocol error: malformed response: invalid data size
Feb 17 11:52:20.277206 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:55: Serial protocol error: malformed response: invalid crc
Feb 17 11:52:30.501057 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:55: Serial protocol error: malformed response: invalid crc
Feb 17 11:54:58.713790 wirenboard-AHAF37M wb-mqtt-serial[104968]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:55: Serial protocol error: malformed response: invalid crc
Тот же модуль подключил к WB7.4.4 (актуальный testing) и ошибок нет, хотя ранее на нем же они проявлялись стабильно.
Теперь подключил 8 устройств через разветвитель шины RS-485 WB-BUSHUB и пока не наблюдаю ошибок crc.
В связи с этим делаю вывод, что проблема в контроллере и она может быть связана с существующей багой, но у вас ошибки возникают очень часто – несколько раз в минуту при короткой шине:
Feb 17 16:31:11.567145 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:11.943983 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 4 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:11.947524 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 13568 of device modbus:186: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:12.289034 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 4 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:12.456771 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 4 input(s) @ 121 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:12.764776 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:36: Serial protocol error: request timed out
Feb 17 16:31:13.088762 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:13.169962 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:186: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:13.186668 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:36: Serial protocol error: request timed out
Feb 17 16:31:13.290745 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 25856 of device modbus:186: Serial protocol error: request timed out
Feb 17 16:31:13.292028 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 4 input(s) @ 121 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:13.404658 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 17666 of device modbus:186: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:13.432695 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:16.593448 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 25856 of device modbus:186: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:18.620321 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:24.645190 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 21762 of device modbus:186: Serial protocol error: malformed response: invalid crc
Feb 17 16:31:52.588885 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:186: Serial protocol error: request timed out
Feb 17 16:31:59.000546 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 4 of device modbus:36: Serial protocol error: malformed response: invalid data size
Feb 17 16:32:06.688419 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 123 of device modbus:186: Serial protocol error: request timed out
Feb 17 16:32:06.689788 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:36: Serial protocol error: malformed response: invalid crc
Feb 17 16:32:06.790459 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 22 input(s) @ 250 of device modbus:186: Serial protocol error: malformed response: invalid crc
Feb 17 16:32:06.811238 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 4 of device modbus:36: Serial protocol error: request timed out
Feb 17 16:32:07.805668 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 1 input(s) @ 4 of device modbus:36: Serial protocol error: request timed out
Feb 17 16:32:07.835391 wirenboard-A64RO4Z4 wb-mqtt-serial[302891]: WARNING: [modbus] failed to read 4 input(s) @ 121 of device modbus:36: Serial protocol error: request timed out
Предлагаю забрать контроллер и модуль WB-MAI6 на исследование, чтобы исключить аппаратные неисправности.
- WB8-4G-64G-IND – 1 шт. A64RO4Z4
- WB-MAI6 – 1 шт. 354361
- ссылку на эту тему, Wb-mai6 мигают красным контролы - #24 от пользователя DmitryKur
- серийные номера устройств, комплектацию (установленные сенсоры или внутренние модули расширения),
Из облака вышел
у меня ошибки тоже пореже, в среднем 30-90 секунд, пока считаем это нормальным? ![]()
Нормальным не считаем и ждем выхода нового ядра, с которым это проблема обещает уйти. Но это моё предположение, я ваш контроллер не диагностировал.
Пришлите в л/с ссылку на вашу тему и название организации, чтобы я мог найти в облаке. Если у вас проблема остается через WBE2-I-RS485-ISO, то интересно посмотреть.
для меня сейчас это не является острой проблемой, как исправите, так и ладно. Но если есть технический интерес посмотреть, то без проблем. ссылку на облако дать не могу, так как там как раз проблема с облаком (пока никто не знает, почему оно отвалилось и тоже поступило предложение отправить контроллер вам на замену). у меня через проброс портов открыт ssh и http на ваш айпишник. можете у Андрея узнать или написать мне на почту isupov.it@gmail.com, сюда не буду выкладывать
Без проблем отпралю.Отправлю даже со всеми перемычками и резюками на модуле.Как есть.Большое спасибо за принятое решение вопроса.Будем надеется что дело в контроллере.Напоминаю что контроллер покупался как восстановленный,это не принципиально?
В данном случае нет. У этого была неисправность в модуле WBMZ5-BATTERY.
Получил новый контроллер и модуль. Прошивка на контроллере пока stable. Мигание контролов прекратилось. Ошибки стали пореже.
| 26-02-2026 11:50:55.228 | WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:94: Serial protocol error: request timed out |
| 26-02-2026 11:50:53.173 | WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:94: Serial protocol error: malformed response: invalid data size |
| 26-02-2026 11:50:26.795 | WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:48:59.172 | WARNING: [modbus] failed to read 1 input(s) @ 5380 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:47:53.996 | WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:46:58.864 | WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:94: Serial protocol error: malformed response: invalid data size |
| 26-02-2026 11:46:07.819 | WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:45:30.908 | WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:44:42.207 | WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:44:11.852 | WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:43:59.748 | WARNING: [modbus] failed to read 1 input(s) @ 5380 of device modbus:94: Serial protocol error: malformed response: invalid data size |
| 26-02-2026 11:42:52.651 | WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:42:50.547 | WARNING: [modbus] failed to read 2 input(s) @ 1536 of device modbus:94: Serial protocol error: request timed out |
| 26-02-2026 11:42:19.819 | WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:42:01.460 | WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:94: Serial protocol error: request timed out |
| 26-02-2026 11:41:22.530 | WARNING: [modbus] failed to read 2 input(s) @ 104 of device modbus:94: Serial protocol error: request timed out |
| 26-02-2026 11:40:51.036 | WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:94: Serial protocol error: malformed response: invalid crc |
| 26-02-2026 11:40:41.979 | WARNING: [modbus] failed to read 1 input(s) @ 9476 of device modbus:94: Serial protocol error: request timed out |
Благодарю за обратную связь! Добавил комментарий для инженеров, которые будут проводить исследование.
1 сообщение было перенесено в новую тему: Wb-mai6 мигают красным контролы с датчиков РТ100
Добрый день. Есть результаты диагностики отправленного контроллера и модуля?
Комментарий инженера: “Неисправность не выявлена”.
Не совсем понял. Не исправность не выявлена по железу или ПО?. Или при получении контроллера с модулем как был подключен у Вас не моргали контролы?
