WB-MAP3: обновление прошивки на 2.10.7
WB 8.5 testing unstable.latest
При обновлении прошивок wb-mcu-fw-updater update-all WB-MAP3 “потерялся”:
root@wirenboard-APCGZIAD:~# wb-mcu-fw-updater update-all
2025-04-25 14:02:37,091 Will probe all devices on enabled serial ports of /etc/wb-mqtt-serial.conf:
Probing WB-LED (port: /dev/ttyRS485-1, slaveid: 58, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-LED (port: /dev/ttyRS485-1, slaveid: 83, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-LED (port: /dev/ttyRS485-1, slaveid: 187, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MAP3E fw2 (port: /dev/ttyRS485-1, slaveid: 42, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-LED (port: /dev/ttyRS485-1, slaveid: 188, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-LED (port: /dev/ttyRS485-1, slaveid: 107, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-LED (port: /dev/ttyRS485-1, slaveid: 66, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MIO (port: /dev/ttyRS485-1, slaveid: 24, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MAI6 (port: /dev/ttyRS485-1, slaveid: 202, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MAI6 (port: /dev/ttyRS485-1, slaveid: 67, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MIO (port: /dev/ttyRS485-1, slaveid: 27, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MAI6 (port: /dev/ttyRS485-1, slaveid: 73, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MAI6 (port: /dev/ttyRS485-1, slaveid: 173, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MWAC-v2 (port: /dev/ttyRS485-1, slaveid: 145, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-LED (port: /dev/ttyRS485-1, slaveid: 108, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 125, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 109, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 120, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 49, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 61, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 100, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-LED (port: /dev/ttyRS485-2, slaveid: 1, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 12, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MIO (port: /dev/ttyRS485-2, slaveid: 15, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing WB-MR6C (port: /dev/ttyRS485-2, slaveid: 119, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:00)
Probing XY-MD0X (port: /dev/ttyRS485-2, slaveid: 30, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:01)
Probing XY-MD0X (port: /dev/ttyRS485-2, slaveid: 31, uart_params: 115200N2, response_timeout: 0.50)... (elapsed: 00:01)
2025-04-25 14:03:01,403 Update: 3.5.4 -> 3.5.5 (WB-LED (58, /dev/ttyRS485-1))
2025-04-25 14:03:02,661 Update: 3.5.4 -> 3.5.5 (WB-LED (83, /dev/ttyRS485-1))
2025-04-25 14:03:03,533 Update: 3.5.4 -> 3.5.5 (WB-LED (187, /dev/ttyRS485-1))
2025-04-25 14:03:04,417 Update: 2.10.6 -> 2.10.7 (WB-MAP3E fw2 (42, /dev/ttyRS485-1))
2025-04-25 14:03:05,811 Update: 3.5.4 -> 3.5.5 (WB-LED (188, /dev/ttyRS485-1))
2025-04-25 14:03:06,675 Update: 3.5.4 -> 3.5.5 (WB-LED (107, /dev/ttyRS485-1))
2025-04-25 14:03:07,545 Update: 3.5.4 -> 3.5.5 (WB-LED (66, /dev/ttyRS485-1))
2025-04-25 14:03:08,424 Is actual: 1.6.5 -> 1.6.5 (WB-MIO (24, /dev/ttyRS485-1))
2025-04-25 14:03:09,294 Is actual: 2.1.3 -> 2.1.3 (WB-MAI6 (202, /dev/ttyRS485-1))
2025-04-25 14:03:10,175 Is actual: 2.1.3 -> 2.1.3 (WB-MAI6 (67, /dev/ttyRS485-1))
2025-04-25 14:03:11,047 Is actual: 1.6.5 -> 1.6.5 (WB-MIO (27, /dev/ttyRS485-1))
2025-04-25 14:03:11,933 Is actual: 2.1.3 -> 2.1.3 (WB-MAI6 (73, /dev/ttyRS485-1))
2025-04-25 14:03:12,817 Is actual: 2.1.3 -> 2.1.3 (WB-MAI6 (173, /dev/ttyRS485-1))
2025-04-25 14:03:13,698 Is actual: 1.21.6 -> 1.21.6 (WB-MWAC-v2 (145, /dev/ttyRS485-1))
2025-04-25 14:03:14,614 Update: 3.5.4 -> 3.5.5 (WB-LED (108, /dev/ttyRS485-1))
2025-04-25 14:03:15,492 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (125, /dev/ttyRS485-2))
2025-04-25 14:03:16,374 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (109, /dev/ttyRS485-2))
2025-04-25 14:03:17,246 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (120, /dev/ttyRS485-2))
2025-04-25 14:03:18,124 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (49, /dev/ttyRS485-2))
2025-04-25 14:03:19,015 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (61, /dev/ttyRS485-2))
2025-04-25 14:03:19,898 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (100, /dev/ttyRS485-2))
2025-04-25 14:03:20,780 Update: 3.5.4 -> 3.5.5 (WB-LED (1, /dev/ttyRS485-2))
2025-04-25 14:03:21,662 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (12, /dev/ttyRS485-2))
2025-04-25 14:03:22,589 Is actual: 1.6.5 -> 1.6.5 (WB-MIO (15, /dev/ttyRS485-2))
2025-04-25 14:03:23,464 Is actual: 1.21.5 -> 1.21.5 (WB-MR6C (119, /dev/ttyRS485-2))
2025-04-25 14:03:23,465 Flashing firmware to WB-LED (58, /dev/ttyRS485-1)
2025-04-25 14:03:27,195 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
100%|######################################################################################################################################################################################################|243/243
2025-04-25 14:03:38,329 Flashing firmware to WB-LED (83, /dev/ttyRS485-1)
2025-04-25 14:03:41,793 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
2025-04-25 14:03:52,387 Flashing firmware to WB-LED (187, /dev/ttyRS485-1)
2025-04-25 14:03:55,825 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
2025-04-25 14:04:06,425 Flashing firmware to WB-MAP3E fw2 (42, /dev/ttyRS485-1)
2025-04-25 14:04:09,993 Flashing /var/lib/wb-mcu-fw-updater/map3eG16__2.10.7_master_f96b655.wbfw (210 data chunks)
100%|######################################################################################################################################################################################################|210/210
2025-04-25 14:04:20,164 No communication with the instrument (no answer)
2025-04-25 14:04:20,187 Flashing firmware to WB-LED (188, /dev/ttyRS485-1)
2025-04-25 14:04:23,630 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
2025-04-25 14:04:34,287 Flashing firmware to WB-LED (107, /dev/ttyRS485-1)
2025-04-25 14:04:37,769 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
2025-04-25 14:04:48,325 Flashing firmware to WB-LED (66, /dev/ttyRS485-1)
2025-04-25 14:04:51,801 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
2025-04-25 14:05:02,360 Flashing firmware to WB-LED (108, /dev/ttyRS485-1)
2025-04-25 14:05:05,836 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
2025-04-25 14:05:15,879 Flashing firmware to WB-LED (1, /dev/ttyRS485-2)
2025-04-25 14:05:19,346 Flashing /var/lib/wb-mcu-fw-updater/ledG__3.5.5_master_8fe193f.wbfw (243 data chunks)
2025-04-25 14:05:29,901 No answer from:
2025-04-25 14:05:29,902         WB-MAP3E fw2 (42, /dev/ttyRS485-1)
2025-04-25 14:05:29,903 Devices are possibly disconnected
2025-04-25 14:05:29,904 8 upgraded, 0 skipped upgrade, 0 bootloader updates available, 0 stuck in bootloader, 1 disconnected and 0 too old for any updates.
Судя по логам - появился на шине примерно через минуту. Прошивка обновилась.
(507,3 КБ)
Это штатная ситуация: WB-MAP3E перезагружается после прошивки и иногда не отвечает 20–60 секунд.
Контроллер WB8.5 с wb-mcu-fw-updater может не дождаться ответа устройства и выдать ошибку связи.
Прошивка реально установилась, что видно по таймингам и отсутствию ошибок процесса.
