Wb-mqtt-serial - ошибки на Serial protocol error: request timed out
Подключил 4 кондея Haier с блоками ONOKOM AIR HR-1-MB-B и теперь они по кругу сыпят ошибками
|19-11-2024 17:36:30.643 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 coil(s) @ 10 of device modbus:3: Serial protocol error: request timed out|
|19-11-2024 17:36:19.761 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 coil(s) @ 5 of device modbus:4: Serial protocol error: request timed out|
|19-11-2024 17:35:42.681 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 20 of device modbus:4: Serial protocol error: request timed out|
|19-11-2024 17:35:23.494 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 8 of device modbus:3: Serial protocol error: request timed out|
|19-11-2024 17:33:47.652 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 coil(s) @ 5 of device modbus:4: Serial protocol error: request timed out|
|19-11-2024 17:33:12.860 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 coil(s) @ 1 of device modbus:2: Serial protocol error: request timed out|
|19-11-2024 17:33:04.615 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 9 of device modbus:2: Serial protocol error: request timed out|
|19-11-2024 17:32:55.708 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 8 of device modbus:4: Serial protocol error: request timed out|
|19-11-2024 17:31:42.857 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 2 of device modbus:2: Serial protocol error: request timed out|
|19-11-2024 17:30:03.290 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 11 of device modbus:1: Serial protocol error: request timed out|
|19-11-2024 17:29:41.365 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 3 of device modbus:1: Serial protocol error: request timed out|
|19-11-2024 17:29:20.393 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 9 of device modbus:3: Serial protocol error: request timed out|
|19-11-2024 17:28:04.472 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 holding(s) @ 2 of device modbus:1: Serial protocol error: request timed out|
|19-11-2024 17:26:54.666 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:2: Serial protocol error: request timed out|
|19-11-2024 17:25:55.940 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 coil(s) @ 5 of device modbus:1: Serial protocol error: request timed out|
Как я понимаю это чтение 1 регистра и причем переодически и по каждому кондею. Но при этом кондеи видны и ими можно управлять. Скажите проверь шину, но я ее проверил, все протянул… Может что-то нужно настроить ?
Прикрепите, пожалуйста, диагностический архив.
При проверке всё учли согласно документации? RS-485:Физическое подключение — Wiren Board
А именно, подскажите, какие терминирующие резисторы и где расположены?
Какая топология?
Где именно расположен контроллер топологически?
Добрый день !
В системе 3 шины RS-485, по топологии все шины последовательные, контроллер во главе каждой шины.
  • RS-485-1 основная шина, там тоже есть вопросы с измерителем энергии WB-MAP6S
  • RS-485-2 шина для кондиционеров 4 Haier устройства от ONOKOM AIR HR-1-MB-B
  • слот расширения MOD3 - шина для вентустановки VENTMACHINE Orange 600
На интерфейсах RS-485-1 и RS-485-2 включены терминирующие резисторы, а на модуле WBE2-I-RS486-ISO что в слот MOD3 тоже есть терминирующий резистор.
Проложены ли шины рядом с силовыми линиями? Есть ли терминирующий резистор на втором конце шины?
Какая скорость baud rate?
Ну и также ожидаю диагностический архив.
  • Да шины проложены рядом с силовыми линиями. Что есть, то есть. Но кабели или KNX c изоляцией или витая пара с изоляцией.
  • на втором конце ничего нет
  • скорости 1 - 115200, 2 - 9600, 3 - 9600
diag_output_AY3WLCTH_2024-11-20-22.46.23.zip (412,1 КБ)
С изоляцией имеете ввиду с экраном? Если так, то как экран подключен?
Рекомендую поставить резисторы 120 Ом на оба конца каждой шины. На встроенных портах контроллера они автоматически включены, на модуле расширения надо установить или замкнуть перемычку.
Диагархив посмотрела. Да, очень похоже на проблемы с физическим подключением, помехами. Ошибки по таймауту много раз в минуту.
Можете проверить: подключить и сконфигурировать в контроллере единственным устройством коротким, заведомо исправным кабелем, без силовых рядом.
Спойлер
Nov 20 22:43:25 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 8 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:43:30 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 20 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:43:36 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 9 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:43:40 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 8 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:43:47 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 3 of device modbus:1: Serial protocol error: request timed out
Nov 20 22:43:53 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 1 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:43:56 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 1 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:43:59 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 11 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:44:01 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 1 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:44:05 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 8 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:44:10 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 10 of device modbus:1: Serial protocol error: request timed out
Nov 20 22:44:12 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 8 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:44:16 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 6 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:44:21 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 8 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:44:25 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 10 of device modbus:1: Serial protocol error: request timed out
Nov 20 22:44:35 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:40: Serial protocol error: malformed response: invalid crc
Nov 20 22:44:36 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 1 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:44:40 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:44:42 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:44:51 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 6 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:45:01 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 input(s) @ 4313 of device modbus:142: Serial protocol error: malformed response: invalid crc
Nov 20 22:45:08 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 10 of device modbus:1: Serial protocol error: request timed out
Nov 20 22:45:10 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 20 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:45:14 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:45:26 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 10 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:45:28 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 6 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:45:30 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 11 of device modbus:1: Serial protocol error: request timed out
Nov 20 22:45:36 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 8 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:45:37 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 6 input(s) @ 5142 of device modbus:142: Serial protocol error: request timed out
Nov 20 22:45:38 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 8 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:45:42 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 10 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:45:44 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 11 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:45:46 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 5 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:45:47 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 10 of device modbus:1: Serial protocol error: request timed out
Nov 20 22:45:49 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 holding(s) @ 3 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:45:53 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:45:57 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 2 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:46:00 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 8 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:46:02 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 2 of device modbus:3: Serial protocol error: request timed out
Nov 20 22:46:04 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 10 of device modbus:1: Serial protocol error: request timed out
Nov 20 22:46:07 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:2: Serial protocol error: request timed out
Nov 20 22:46:14 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 8 of device modbus:4: Serial protocol error: request timed out
Nov 20 22:46:19 wirenboard-AY3WLCTH wb-mqtt-serial[1275015]: WARNING: [modbus] failed to read 1 coil(s) @ 8 of device modbus:4: Serial protocol error: request timed out
Поставил на шину кондиционеров в конце терминирующий резистор. Проверил сопротивление между A и B = 115 Ом. Что свидетельствует о целостности шины. Эффекта ни какого не получил. Ошибки так и сыплются от всех кондеев по кругу
Попробовал соединить прямой шиной из витой пары, только один кондиционер. Так сказать на прямую. Чтобы исключить возможные помехи от силовых проводов. И в результате получаю опять те же ошибки :
27-11-2024 14:46:09.146 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 10 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:44:38.718 [wb-mqtt-serial] WARNING: [modbus] failed to read 6 input(s) @ 9238 of device modbus:142: Serial protocol error: malformed response: invalid crc
27-11-2024 14:44:36.294 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 20 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:43:35.172 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 9 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:42:16.692 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 coil(s) @ 2 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:41:58.218 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:41:55.580 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 8 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:40:57.175 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 5 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:39:50.293 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 coil(s) @ 5 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:39:13.276 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 3 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:38:15.319 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 coil(s) @ 9 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:38:13.311 [wb-mqtt-serial] WARNING: [register handler] failed to write: <modbus:3:coil: 1>: Serial protocol error: request timed out
27-11-2024 14:36:52.696 [wb-mqtt-serial] WARNING: [register handler] failed to write: <modbus:3:coil: 1>: Serial protocol error: request timed out
27-11-2024 14:34:39.146 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 10 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:33:48.187 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 2 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:32:32.672 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 2 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:31:36.167 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 20 of device modbus:3: Serial protocol error: request timed out
27-11-2024 14:31:25.618 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 coil(s) @ 1 of device modbus:3: Serial protocol error: request timed out
При чем 1 регистр это его состояния и его включение в зависимости от типа регистра. Не понимаю, если его не может нормально прочитать. Хотя нормально и включает и показывает состояние…
я не особый спец по модбасу и помехам, но в первую очередь проверьте (и сократите) количество опрашиваемых регистров и уменьшите частоту опроса. Если есть возможность и желание покопаться в проблеме для теста оставить на шине одно устройство с опросом одного регистра… и постепенно наращивайте количество - думаю увидите предел перехода к ошибкам.
А “прямая шина” это короткий заведомо исправный кабель?
Прямая шина, это FTP кабель А и В - оранжевая пара, +/Gnd - синяя пара.
На сбалансированной шине должно быть 60 Ом. Два резистора в параллель по 120 Ом ставится, по одному на концах.
И ещё убедитесь, что у вас включена задержка между опросами. По умолчанию в драйвере нет задержки между посылками. Устройства ВБ это проглатывают, а сторонние устройства не редко нет.
Про какую задержку между посылками вы говорите. Поясните подробнее. Не совсем владею этой темой. Какие точно параметры исправить и какие значения попробовать.
Я немного не в теме - если вы используете штатный шаблон от ВБ, то по идее там должно быть уже все прописано и я не прав. А вот если сами задаёте регистры опроса и т.п., тогда есть смысл поразбираться.
Интервал между опросами кажется называется. Находится на страницах настройки порта. Подробнее о нем было написано в шаблонах драйвера, поизучайте документацию, там так же было где-то какие цифры ставить. Саму задержку можно прописать как в настройках, так и шаблоне. Наберите прям в Яндексе шаблоны устройств WB, там сразу ссылки были. Я так искал обычно)))
Мне кажется, нащупал решение. Спасибо Al-x ! У каждого устройства, есть скрытые свойства. У ONOKOM → “Свойства” выбираем “Минимальный интервал между запросами к устройству (мс)” поставил вместо 0 → 50 мс. Ошибки вроде пока пропали. Сейчас попробую собрать шину из 4 кондеев и проверить на всех.
Да, перед этим попробовал читать утилитой “modbus_client” именно этот регистр у этого устройства и ошибок вообще не было. Все прекрасно читалось. И совет от Al-x оказался прямо в кассу :slight_smile: Ещё раз спасибо за идеи. Соберу все отпишусь по результату.
По архиву вижу, что готовые шаблоны использовали без изменений, верно?
Да верно, использовались готовые шаблоны.
После того как собрал шину из 4 кондиционеров и выставил в шаблоне “Минимальный интервал между запросами к устройству (мс)” поставил вместо 0 → 50 мс. Больше проблем по этой шине не наблюдаю. Но появились подобные ошибки на /dev/ttyRS485-1 по другим модулям…
28-11-2024 11:43:26.261 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 100 of device modbus:126: Serial protocol error: malformed response: invalid crc
28-11-2024 11:37:30.388 [wb-mqtt-serial] WARNING: [modbus] failed to read 3 input(s) @ 400 of device modbus:109: Serial protocol error: malformed response: invalid crc
28-11-2024 11:29:22.577 [wb-mqtt-serial] WARNING: [modbus] failed to read 6 input(s) @ 4866 of device modbus:142: Serial protocol error: malformed response: invalid crc
28-11-2024 11:17:22.800 [wb-mqtt-serial] WARNING: [modbus] failed to read 6 input(s) @ 8962 of device modbus:142: Serial protocol error: malformed response: invalid crc
28-11-2024 11:12:28.026 [wb-mqtt-serial] WARNING: [modbus] failed to read 4 input(s) @ 8716 of device modbus:142: Serial protocol error: malformed response: invalid crc
28-11-2024 11:00:17.626 [wb-mqtt-serial] WARNING: [modbus] failed to read 3 input(s) @ 400 of device modbus:134: Serial protocol error: malformed response: invalid crc
28-11-2024 10:47:01.314 [wb-mqtt-serial] WARNING: [modbus] failed to read 6 input(s) @ 4866 of device modbus:142: Serial protocol error: request timed out
28-11-2024 10:41:03.827 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 holding(s) @ 100 of device modbus:83: Serial protocol error: malformed response: invalid crc
28-11-2024 10:26:25.924 [wb-mqtt-serial] WARNING: [modbus] failed to read 3 input(s) @ 400 of device modbus:41: Serial protocol error: malformed response: invalid crc
28-11-2024 10:24:05.881 [wb-mqtt-serial] WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:134: Serial protocol error: malformed response: invalid crc
28-11-2024 10:09:55.038 [wb-mqtt-serial] WARNING: [modbus] failed to read 1 input(s) @ 4344 of device modbus:142: Serial protocol error: malformed response: invalid crc
и подобный метод (описанный выше) не приводит к решению этих проблем…
Ошибки на шине в среднем ~раз в 10 мин - это в пределах нормы. В целом только эти записи в журнале беспокоят? По работе нет нареканий? Можете диагархив на всякий случай свежий прикрепить?
Я поэтому вас послал в документы, ибо на память не помню цифры. Где-то был рассчет какая именно должна быть длительность задержки. Толи два такта, толи ещё сколько, не помню.
У меня при 9600 стоит 5000 (МКС). У вас 50 мс, если вы не ошиблись, но это точно слишком дофига. Будет долго опрашивать.
Я не ошибся. Я о другом параметре писал. Я писал об минимальном интервале между запросами к устройству. И он выставляется на устройстве. А вы пишите от параметре всей шины (задержка перед записью в порт). Как я понимаю, это немного другой параметр. Но идеи была наверное схожая.
Сегодня накатил ещё одно обновление на контроллер, включая wb-mqtt-serial. И мне кажется система становится более стабильной. Ошибок меньше. Хотя я кроме этого ничего не делал, даже на объекте не был.
Еще хотел спросить на Wirenboad 8.4, как понять работает ли быстрый MODBUS и я не нашел ни молнии в конфигах, как было на 7 версии и параметра “sporadic” ? Может где-то тут кроется ещё моя проблема…
