При добавлении счетчика Энергомера 303 , прекращается опрос всех устройств.
В чем проблема.
Файл Mqtt прилагаю.
"debug": false,
"ports": [
"path": "/dev/ttyRS485-1",
"devices": [
"slave_id": "30",
"device_type": "WB-MSW2"
"slave_id": "31",
"baud_rate": 9600,
"parity": "N",
"data_bits": 8,
"stop_bits": 2,
"poll_interval": 10,
"enabled": true
"path": "/dev/ttyRS485-2",
"devices": [
"slave_id": "20",
"device_type": "milur305",
"enabled": true
"slave_id": "00000202",
"enabled": true,
"device_type" : "Energomera CE301/CE303",
"frame_timeout_ms" : 100
"port_type": "serial",
"baud_rate": 9600,
"parity": "N",
"data_bits": 8,
"stop_bits": 1,
"poll_interval": 0,
"enabled": true,
"type": null,
"response_timeout_ms": 200
"path": "/dev/ttyMOD1",
"devices": [],
"baud_rate": 9600,
"parity": "N",
"data_bits": 8,
"stop_bits": 2,
"enabled": false
"path": "/dev/ttyMOD2",
"devices": [],
"baud_rate": 9600,
"parity": "N",
"data_bits": 8,
"stop_bits": 2,
"enabled": false
"path": "/dev/ttyMOD3",
"devices": [],
"baud_rate": 9600,
"parity": "N",
"data_bits": 8,
"stop_bits": 2,
"enabled": false
