WB7 ModemManager
Здравствуйте, я настроил модем через NetworkManager. У меня выделенная сеть от мтс, там другой apn и логин с паролем. Но подключение к сети не работает. Модем подключается но потом соединение резко обрывается, подскажите в чём может быть дело?
ModemManager[12848]: <debug> [1701067858.757021] [modem0/bearer0] connected
ModemManager[12848]: <debug> [1701067858.757620] [modem0/bearer0] PPP is required for connection, will ignore disconnection reports
ModemManager[12848]: <info>  [1701067858.757847] [modem0] state changed (connecting -> connected)
ModemManager[12848]: <info>  [1701067858.761533] [modem0] simple connect state (10/10): all done
ModemManager[12848]: <debug> [1701067858.764316] [ttyUSB2/at] device open count is 1 (close)
ModemManager[12848]: <debug> [1701067858.946469] [base-manager] adding port ppp0 at sysfs path: /sys/devices/virtual/net/ppp0
ModemManager[12848]: <debug> [1701067858.946796] [filter] (net/ppp0) port filtered: virtual device
ModemManager[12848]: <debug> [1701067860.808388] [ttyUSB1/at] <-- '<CR><LF>+CGREG: 1,19D9,08BC2E8E<CR><LF>'
ModemManager[12848]: <debug> [1701067860.809884] [ttyUSB1/at] <-- '<CR><LF>+CNSMOD: 30<CR><LF>'
ModemManager[12848]: <debug> [1701067860.810320] [modem0] access technology changed (umts -> unknown)
ModemManager[12848]: <debug> [1701067861.230883] [modem0] user request to disconnect modem (all bearers)
ModemManager[12848]: <debug> [1701067861.246694] [modem0/bearer0] disconnecting...
ModemManager[12848]: <info>  [1701067861.246967] [modem0] state changed (connected -> disconnecting)
Есть еще такая ошибка
Nov 27 07:40:54 wirenboard-ART5QY5H NetworkManager[29760]: PAP authentication succeeded
Nov 27 07:40:54 wirenboard-ART5QY5H pppd[29760]: kernel does not support PPP filtering
Nov 27 07:40:54 wirenboard-ART5QY5H NetworkManager[29760]: kernel does not support PPP filtering
Nov 27 07:40:55 wirenboard-ART5QY5H NetworkManager[386]: <info>  [1701070855.6145] device (ttyUSB1): state change: config -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
В том случае если есть доступный интернет на другом интерфейсе контроллера - соединение модема разрывается, для stable это нормальное поведение. Если нужно поведение изменять - то используйте testing.
Ну или остановите wb-connection-manager
Ого спасибо действительно
Ну и посмотрте в тему: Определение сим карт и оператора - #5 от пользователя PeteK
