проблема вернулась и уже ни как не желает уходить…
dmesg
usb 1-1: device not accepting address 10, error -71
[ 2718.558885] usb 1-1: new high-speed USB device number 11 using ehci-platform
[ 2719.009239] usb 1-1: device not accepting address 11, error -71
[ 2719.015420] usb usb1-port1: unable to enumerate USB device
[ 2719.898886] usb 1-1: new high-speed USB device number 12 using ehci-platform
[ 2720.288911] usb 1-1: device descriptor read/64, error -71
[ 2722.498981] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2722.838957] usb 1-1: new high-speed USB device number 13 using ehci-platform
[ 2723.228921] usb 1-1: device descriptor read/64, error -71
[ 2724.959042] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2726.219094] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2726.226008] usb usb4-port1: attempt power cycle
[ 2727.828981] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2729.159004] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2729.165975] usb usb4-port1: unable to enumerate USB device
[ 2797.078899] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2798.368826] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2798.375792] usb usb4-port1: attempt power cycle
[ 2799.978823] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2801.268812] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2801.275435] usb usb4-port1: unable to enumerate USB device
[ 2871.908794] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2873.188810] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2873.195564] usb usb4-port1: attempt power cycle
[ 2874.828717] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2876.089011] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[ 2876.095713] usb usb4-port1: unable to enumerate USB device
подключал мышь - светится но в устройствах не определяется… любые флешки и т.п. в прошлый раз все как-то заработало и сегодня заметил что все отвалилось и ничего не помогает… куда копать?
