WBE2R-R-ZIGBEE + антенна выдаёт Error: SRSP - SYS - version after 6000ms
Отписал автору: 0.13.124 regression (SRSP - SYS - version after 6000ms) · Issue #406 · Koenkk/zigbee-herdsman · GitHub
Кусок дебаг лога:
Zigbee2MQTT:debug 2021-08-12 18:25:23: Loaded state from file /mnt/data/root/zigbee2mqtt-bak/data/state.json
Zigbee2MQTT:info  2021-08-12 18:25:23: Logging to console and directory: '/mnt/data/root/zigbee2mqtt-bak/data/log/2021-08-12.18-25-10' filename: log.txt
Zigbee2MQTT:info  2021-08-12 18:25:24: Starting Zigbee2MQTT version 1.20.0-dev (commit #6068cd85)
Zigbee2MQTT:info  2021-08-12 18:25:24: Starting zigbee-herdsman (0.13.124)
Zigbee2MQTT:debug 2021-08-12 18:25:24: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/mnt/data/root/zigbee2mqtt-bak/data/coordinator_backup.json","databaseBackupPath":"/mnt/data/root/zigbee2mqtt-bak/data/database.db.backup","databasePath":"/mnt/data/root/zigbee2mqtt-bak/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/ttyMOD3","rtscts":true}}'
  zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[185,174,223,88,254,27,89,64,155,142,203,102,85,0,51,15],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"rtscts":true,"path":"/dev/ttyMOD3"},"databasePath":"/mnt/data/root/zigbee2mqtt-bak/data/database.db","databaseBackupPath":"/mnt/data/root/zigbee2mqtt-bak/data/database.db.backup","backupPath":"/mnt/data/root/zigbee2mqtt-bak/data/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}' +0ms
  zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyMOD3 and {"baudRate":115200,"rtscts":true,"autoOpen":false} +0ms
  zigbee-herdsman:adapter:zStack:znp:log Serialport opened +58ms
  zigbee-herdsman:adapter:zStack:znp:log Writing skip bootloader payload +526ms
  zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239] +0ms
  zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1} +0ms
  zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32] +1s
  zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,1,121,1,26] +0ms
  zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,1,121,1,26] +10ms
  zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 1 - [121,1] - 26 +9ms
  zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - ping - {"capabilities":377} +0ms
  zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [] +55ms
  zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - version - {} +124ms
  zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,2,35] +109ms
  zigbee-herdsman:adapter:zStack:unpi:parser <-- [254] +29ms
  zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254] +3ms
  zigbee-herdsman:adapter:zStack:unpi:parser <-- [5,97,2,2,0,2,6,3,99] +10ms
  zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,5,97,2,2,0,2,6,3,99] +3ms
  zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 5 - 3 - 1 - 2 - [2,0,2,6,3] - 99 +2ms
  zigbee-herdsman:adapter:zStack:znp:error Error while parsing to ZpiObject 'RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 1. Received 5
  zigbee-herdsman:adapter:zStack:znp:error     at boundsError (internal/buffer.js:82:9)
  zigbee-herdsman:adapter:zStack:znp:error     at Buffer.readUInt32LE (internal/buffer.js:216:5)
  zigbee-herdsman:adapter:zStack:znp:error     at BuffaloZnp.readUInt32 (/mnt/data/root/zigbee2mqtt-bak/node_modules/zigbee-herdsman/src/buffalo/buffalo.ts:101:35)
  zigbee-herdsman:adapter:zStack:znp:error     at BuffaloZnp.read (/mnt/data/root/zigbee2mqtt-bak/node_modules/zigbee-herdsman/src/buffalo/buffalo.ts:284:25)
  zigbee-herdsman:adapter:zStack:znp:error     at BuffaloZnp.read (/mnt/data/root/zigbee2mqtt-bak/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/buffaloZnp.ts:161:26)
  zigbee-herdsman:adapter:zStack:znp:error     at Function.readParameters (/mnt/data/root/zigbee2mqtt-bak/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:107:46)
  zigbee-herdsman:adapter:zStack:znp:error     at Function.fromUnpiFrame (/mnt/data/root/zigbee2mqtt-bak/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:73:30)
  zigbee-herdsman:adapter:zStack:znp:error     at Znp.onUnpiParsed (/mnt/data/root/zigbee2mqtt-bak/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:103:38)
  zigbee-herdsman:adapter:zStack:znp:error     at Parser.emit (events.js:314:20)
  zigbee-herdsman:adapter:zStack:znp:error     at Parser.parseNext (/mnt/data/root/zigbee2mqtt-bak/node_modules/zigbee-herdsman/src/adapter/z-stack/unpi/parser.ts:45:26)' +0ms````
Received 5 could mean a possible corruption.
Модуль неисправен?
То есть не работает именно с свежей версией?
Именно так. На предыдущей работает. См. лог выше WBE2R-R-ZIGBEE + антенна выдаёт Error: SRSP - SYS - version after 6000ms - #39 от пользователя redis
Тут надо копать в сторону именно прошивки (версии прошивки) модуля. А зачем, если не секрет поднимать версию?
Без программатора модуль не перешить, как я понимаю, так что копать нечем.
Можете проверить , подтверждается ли поведение на других экземплярах модуля wbe2r-r-zigbee?
Да, по крайней мере на моем экземпляре. Доедет программатор - проверю снова.
