Wbe2r-r-zigbee
Не желает работать Zigbee2MQTT
вот что пишет:
Zigbee2MQTT requires node version ^18 || ^20 || ^21, you are running v16.18.1!
это статус
root@wirenboard-A7H5VVZX:~# systemctl status zigbee2mqtt
â— zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2024-01-26 15:35:21 MSK; 5min ago
Process: 14921 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
Main PID: 14921 (code=exited, status=1/FAILURE)
CPU: 10.294s
Jan 26 15:35:21 wirenboard-A7H5VVZX systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart counter is at 5.
Jan 26 15:35:21 wirenboard-A7H5VVZX systemd[1]: Stopped zigbee2mqtt.
Jan 26 15:35:21 wirenboard-A7H5VVZX systemd[1]: zigbee2mqtt.service: Consumed 10.294s CPU time.
Jan 26 15:35:21 wirenboard-A7H5VVZX systemd[1]: zigbee2mqtt.service: Start request repeated too quickly.
Jan 26 15:35:21 wirenboard-A7H5VVZX systemd[1]: zigbee2mqtt.service: Failed with result ‘exit-code’.
Jan 26 15:35:21 wirenboard-A7H5VVZX systemd[1]: Failed to start zigbee2mqtt.
Все делал по инструкции в Вики.
вот что пишет после
root@wirenboard-A7H5VVZX:/mnt/data/root/zigbee2mqtt# npm start
zigbee2mqtt@1.35.1 start
node index.js
/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:183
return new YAMLException(message, mark);
YAMLException: can not read an implicit mapping pair; a colon is missed (5:28)
2 | permit_join: false
3 | mqtt:
4 | base_topic: zigbee2mqtt
5 | server:‘mqtt://localhost’
6 | serial:
7 | port: /dev/ttyMOD4
at generateError (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:183:10)
at throwError (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:187:9)
at readBlockMapping (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1136:11)
at composeNode (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1441:12)
at readBlockMapping (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1164:11)
at readDocument (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1625:3)
at loadDocuments (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1688:5)
at Object.load (/mnt/data/root/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1714:19)
at Object.read (/mnt/data/root/zigbee2mqtt/lib/util/yaml.ts:7:29)
Я ничего не понимаю
Здравствуйте, у вас ошибка форматирования файла настроек /mnt/data/root/zigbee2mqtt/data/configuration.yaml. Проверьте, чтобы файл выглядел как в статье Подключение устройств Zigbee к контроллеру Wiren Board — Wiren Board
Если не разберётесь сами, пришлите файл сюда, мы поможем.
файл конфигурации точно соответствует как в статье
homeassistant: false
permit_join: false
mqtt:
serial:
port: /dev/ttyMOD4
advanced:
rtscts: false
last_seen: epoch
pan_id: GENERATE
network_key:GENERATE
В файле важны отступы, они должны быть пробелами и в нужном количестве. Пришлите, пожалуйста, конфиг файлом, а не в сообщении.
Новый текстовый документ (3).txt (226 байтов)
контроллер в облаке, можете сами там посмотреть
Переустановил, заработало. Пока что вижуОнлайн, еще не пробовал подключать устройства.
Вот только после всех обновлений и установки такое сообщение:
System load: 0.93 0.79 0.90 Up time: 23:20
Memory usage: 15% of 1.96G Usage of /: 91% of 976M /mnt/data: 6 % of 55G
91% от чего?
и что с этим делать?
91% от корневого раздела, который 1Гбайт на старых контроллерах. Можно его увеличить:Увеличение корневого раздела контроллеров Wiren Board — Wiren Board
