Заметил, что версия zigbee2mqtt в web интерфейсе показывает 1.35.3, а статус ofline. При обновлении на новую версию ничего не меняется.
Вот вывод диагностических сообщений:
systemctl status zigbee2mqtt
Active: active (running) since Sun 2024-05-12 14:58:38 +07; 11s ago
Main PID: 10050 (npm start)
Tasks: 19 (limit: 4790)
Memory: 40.3M
CPU: 12.167s
CGroup: /system.slice/zigbee2mqtt.service
├─10050 npm start
├─10089 sh -c -- node index.js
└─10090 node index.js
May 12 14:58:38 wirenboard-A7C5WKJX systemd[1]: Started zigbee2mqtt.
May 12 14:58:42 wirenboard-A7C5WKJX npm[10050]: > zigbee2mqtt@1.37.0 start
May 12 14:58:42 wirenboard-A7C5WKJX npm[10050]: > node index.js
May 12 14:58:44 wirenboard-A7C5WKJX npm[10090]: Zigbee2MQTT requires node version ^18 || ^20 || ^21, yo>
npm start
root@wirenboard-A7C5WKJX:/mnt/data/root/zigbee2mqtt# npm start
> node index.js
Zigbee2MQTT requires node version ^18 || ^20 || ^21, you are running v16.18.1!
[2024-05-12 15:15:33] info: z2m: Logging to console, file (filename: log.log)
[2024-05-12 15:15:43] info: z2m: Starting Zigbee2MQTT version 1.37.0 (commit #46f34c8c)
[2024-05-12 15:15:43] info: z2m: Starting zigbee-herdsman (0.45.0)
[2024-05-12 15:15:48] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD4","baudRate":115200,"rtscts"
:false,"autoOpen":false}
[2024-05-12 15:15:48] info: zh:zstack:znp: Serialport opened
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: - PAN ID: configured=28739, adapter=13739
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: - Extended PAN ID: configured=00124b002a2ef102, adapter=00124
b002a2ef102
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: - Network Key: configured=cfec29987127cb2998ef2a3f0c26325d, a
dapter=83a32bdb56211b0696c5645e1c1fb9de
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: - Channel List: configured=11, adapter=11
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coor
dinator backup at /mnt/data/root/zigbee2mqtt/data/coordinator_backup.json.
[2024-05-12 15:15:49] error: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all
devices!
[2024-05-12 15:15:49] error: z2m: Error while starting zigbee-herdsman
[2024-05-12 15:15:49] error: z2m: Failed to start zigbee
[2024-05-12 15:15:49] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.h
tml for possible solutions
[2024-05-12 15:15:49] error: z2m: Exiting...
[2024-05-12 15:15:49] error: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more in
formation
at ZnpAdapterManager.determineStrategy (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/
adapter/manager.ts:223:35)
at ZnpAdapterManager.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/mana
ger.ts:57:26)
at Controller.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:124:29)
at Zigbee.start (/mnt/data/root/zigbee2mqtt/lib/zigbee.ts:62:27)
at Controller.start (/mnt/data/root/zigbee2mqtt/lib/controller.ts:108:27)
at start (/mnt/data/root/zigbee2mqtt/index.js:107:5)
Перезагрузка не помогает!
