в логе zigbee2mqtt теперь иначе
| 25-10-2022 17:53:21.273 | } |
| 25-10-2022 17:53:21.273 | requireStack: [ ‘/mnt/data/root/zigbee2mqtt/index.js’ ] |
| 25-10-2022 17:53:21.273 | code: ‘MODULE_NOT_FOUND’, |
| 25-10-2022 17:53:21.273 | at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) { |
| 25-10-2022 17:53:21.273 | at Function.Module._load (node:internal/modules/cjs/loader:868:12) |
| 25-10-2022 17:53:21.273 | at Module.load (node:internal/modules/cjs/loader:1033:32) |
| 25-10-2022 17:53:21.273 | at Object.Module._extensions…js (node:internal/modules/cjs/loader:1209:10) |
| 25-10-2022 17:53:21.273 | at Module._compile (node:internal/modules/cjs/loader:1155:14) |
| 25-10-2022 17:53:21.273 | at Object. (/mnt/data/root/zigbee2mqtt/index.js:1:1) |
| 25-10-2022 17:53:21.273 | at require (node:internal/modules/cjs/helpers:103:18) |
| 25-10-2022 17:53:21.273 | at Module.require (node:internal/modules/cjs/loader:1057:19) |
| 25-10-2022 17:53:21.273 | at Function.Module._load (node:internal/modules/cjs/loader:833:27) |
| 25-10-2022 17:53:21.273 | at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15) |
| 25-10-2022 17:53:21.273 | - /mnt/data/root/zigbee2mqtt/index.js |
| 25-10-2022 17:53:21.273 | Require stack: |
| 25-10-2022 17:53:21.273 | Error: Cannot find module 'core-js/features/object/from-entries’ |
| 25-10-2022 17:53:21.273 | ^ |
| 25-10-2022 17:53:21.273 | throw err; |
| 25-10-2022 17:53:21.273 | node:internal/modules/cjs/loader:988 |
| 25-10-2022 17:53:20.449 | > node index.js |
| 25-10-2022 17:53:20.449 | > zigbee2mqtt@1.25.2 start |
