У меня подобное не воспроизводится.
Публикую устройство:
mosquitto_pub -t zigbee2mqtt/bridge/devices -m '[{"date_code":"20201026","definition":{"description":"Wireless button","exposes":[{"access":5,"category":"diagnostic","description":"Remaining battery in %","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":5,"category":"diagnostic","description":"Reported battery voltage in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Triggered action (e.g. a button click)","label":"Action","name":"action","property":"action","type":"enum","values":["single","double","long"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"SNZB-01","options":[],"supports_ota":false,"vendor":"SONOFF"},"disabled":false,"endpoints":{"1":{"bindings":[{"cluster":"genOnOff","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}},{"cluster":"genPowerCfg","target":{"endpoint":1,"ieee_address":"0x00124b001f31552a","type":"endpoint"}}],"clusters":{"input":["genBasic","genIdentify","genPowerCfg"],"output":["genOnOff","genIdentify"]},"configured_reportings":[{"attribute":"batteryVoltage","cluster":"genPowerCfg","maximum_report_interval":7200,"minimum_report_interval":3600,"reportable_change":0},{"attribute":"batteryPercentageRemaining","cluster":"genPowerCfg","maximum_report_interval":7200,"minimum_report_interval":3600,"reportable_change":0}],"scenes":[]}},"friendly_name":"moes_sceneswitch_1","ieee_address":"0x00124b002454cd17","interview_completed":true,"interview_state":"SUCCESSFUL","interviewing":false,"manufacturer":"eWeLink","model_id":"WB01","network_address":22741,"power_source":"Battery","supported":true,"type":"EndDevice"}]'
публикую событие
mosquitto_pub -t zigbee2mqtt/moes_sceneswitch_1 -m '{"action":"4_single","battery":100,"last_seen":1752741399642,"linkquality":76,"voltage":3000}'
Затем перезапускаю wb-rules и (после публикации устройства)
mosquitto_pub -t zigbee2mqtt/moes_sceneswitch_1 -m '{"action":"1_single","battery":100,"last_seen":1752741399642,"linkquality":76,"voltage":3000}'
