В предыдущей теме подробно описано: wb-mqtt-db-cli выходит по таймауту, в Web UI бесконечно крутятся точки
Лог при включенном debug выдает следующее:
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[23216]: INFO: [signal handling] Received signal 15
фев 16 12:21:03 wirenboard-ANKMIELJ systemd[1]: Stopping Wiren Board database logger...
фев 16 12:21:03 wirenboard-ANKMIELJ systemd[1]: wb-mqtt-db.service: Succeeded.
фев 16 12:21:03 wirenboard-ANKMIELJ systemd[1]: Stopped Wiren Board database logger.
фев 16 12:21:03 wirenboard-ANKMIELJ systemd[1]: wb-mqtt-db.service: Consumed 4min 25.611s CPU time.
фев 16 12:21:03 wirenboard-ANKMIELJ systemd[1]: Started Wiren Board database logger.
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: MQTT broker localhost:1883
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: Config file /etc/wb-mqtt-db.conf
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] Default host and port detected, checking if UNIX socket exists on /var/run/mosqui>
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] UNIX socket exists, using it for connection
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [sqlite] Creating tables if necessary
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: DEBUG: [sqlite] Creating 'channels' table...
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: DEBUG: [sqlite] Creating 'data' table...
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: DEBUG: [sqlite] Creating 'variables' table...
фев 16 12:21:03 wirenboard-ANKMIELJ wb-mqtt-db[31644]: DEBUG: [sqlite] Updating database version variable...
фев 16 12:21:04 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [sqlite] Create indices if necessary
фев 16 12:21:04 wirenboard-ANKMIELJ wb-mqtt-db[31644]: DEBUG: [sqlite] Creating 'data_topic' index on 'data' ('channel')
фев 16 12:21:04 wirenboard-ANKMIELJ wb-mqtt-db[31644]: DEBUG: [sqlite] Creating 'data_topic_timestamp' index on 'data' ('channel', 'timestamp')
фев 16 12:21:04 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [sqlite] Analyzing data table
фев 16 12:21:04 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [sqlite] DB initialization is done
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: DB logger started, go to main loop
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] connection estabilished with code "0" <success>
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 1)
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 2)
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 5)
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 6)
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 7)
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 8)
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 9)
фев 16 12:21:05 wirenboard-ANKMIELJ wb-mqtt-db[31644]: INFO: [mqtt] subscription succeeded (message id 10)
