Лог загрузки
In: serial@1c28000
Out: serial@1c28000
Err: serial@1c28000
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=3
upgrade_available=0
Environment size: 43/131068 bytes
## Resetting to default environment
Net: No ethernet found.
Hit <SPACE> key to stop autoboot in 1s
## Info: input data size = 4281 = 0x10B9
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
Press FW button to enter firmware update mode
Entering firmware update mode.
Checking if ubootenv part is present
## Loading FIT header to 0x42000000 ...
** File not found .wb-restore/factoryreset.fit **
Read failed: -1Extracting kernel
Read failed: -1Extracting DTB
## Loading FIT header to 0x43000000 ...
Read failed: -1zimage: Bad magic!
ERROR: Failed to enter update mode!
ERROR: /mnt/data/.wb-restore/factoryreset.fit missing or corrupt
Checking if there is a microSD card with update file
1 bytes read in 8 ms (0 Bytes/s)
# Detected microSD card with update file
# Filename: wb_update.fit
# Press a FW key if you want to update firmware from this file
# or wait 3 seconds to boot normally.
USB update procedure start
## Loading FIT strings to 0x42000028 ...
## Loading FIT struct to 0x42000100 ...
Can't find subimage 'ubootenv'
Extracting kernel
11496768 bytes read in 1211 ms (9.1 MiB/s)
Description: Update kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x42000300
Data Size: 11487808 Bytes = 11 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 12f0c7170a6a34f72034cf172abd663ce9327a57
## Verifying ... sha1+
Loading part 0 ... OK
Extracting DTB
## Loading FIT strings to 0x43000028 ...
## Loading FIT struct to 0x43000100 ...
66284 bytes read in 284 ms (227.5 KiB/s)
Description: Update DTB
Type: Flat Device Tree
Data Start: 0x43000500
Data Size: 56812 Bytes = 55.5 KiB
Architecture: ARM
Hash algo: sha1
Hash value: c4ee3d66f088e7581499d46e11a3383c68474a11
Kernel image @ 0x42000000 [ 0x000000 - 0xaf4a40 ]
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Loading Device Tree to 49fef000, end 49fffdeb ... OK
## DT property 'device-serial' not found! If the device was produced before 2023-08-07, please ignore it
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.35-wb150 (root@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #2 SMP Tue Oct 10 12:09:51 UTC 2023
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Wiren Board rev. 7.x (A40i), FIT bootlet
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 16 MiB at 0xbec00000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff]
[ 0.000000] HighMem [mem 0x0000000070000000-0x00000000bfffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] percpu: Embedded 15 pages/cpu s31180 r8192 d22068 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
[ 0.000000] Kernel command line: console=ttyS0,115200 bootmode=update_auto bootmode=sdupdate,wb_update.fit
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 2042620K/2097152K available (7168K kernel code, 655K rwdata, 1528K rodata, 8192K init, 396K bss, 38148K reserved, 16384K cma-reserved, 1294324K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4f8 with crng_init=0
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.000309] Console: colour dummy device 80x30
[ 0.000364] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000384] pid_max: default: 32768 minimum: 301
[ 0.000540] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000558] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001452] CPU: Testing write buffer coherency: ok
[ 0.001783] /cpus/cpu@0 missing clock-frequency property
[ 0.001811] /cpus/cpu@1 missing clock-frequency property
[ 0.001832] /cpus/cpu@2 missing clock-frequency property
[ 0.001854] /cpus/cpu@3 missing clock-frequency property
[ 0.001866] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002411] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002540] rcu: Hierarchical SRCU implementation.
[ 0.003159] smp: Bringing up secondary CPUs ...
[ 0.013923] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.024758] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.035524] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.035620] smp: Brought up 1 node, 4 CPUs
[ 0.035647] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.035654] CPU: All CPU(s) started in HYP mode.
[ 0.035661] CPU: Virtualization extensions available.
[ 0.036470] devtmpfs: initialized
[ 0.047488] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.047736] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.047761] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.048621] pinctrl core: initialized pinctrl subsystem
[ 0.049710] NET: Registered protocol family 16
[ 0.050680] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.051711] thermal_sys: Registered thermal governor 'step_wise'
[ 0.052215] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.052231] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.083046] SCSI subsystem initialized
[ 0.083274] usbcore: registered new interface driver usbfs
[ 0.083326] usbcore: registered new interface driver hub
[ 0.083375] usbcore: registered new device driver usb
[ 0.085043] clocksource: Switched to clocksource arch_sys_counter
[ 0.085386] FS-Cache: Loaded
[ 0.085782] CacheFiles: Loaded
[ 0.093244] NET: Registered protocol family 2
[ 0.093819] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.093864] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.093938] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.094054] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.094179] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.094245] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.094458] NET: Registered protocol family 1
[ 0.095206] RPC: Registered named UNIX socket transport module.
[ 0.095222] RPC: Registered udp transport module.
[ 0.095231] RPC: Registered tcp transport module.
[ 0.095238] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.480480] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.481926] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.489775] NFS: Registering the id_resolver key type
[ 0.489826] Key type id_resolver registered
[ 0.489836] Key type id_legacy registered
[ 0.489881] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.490541] bounce: pool size: 64 pages
[ 0.490591] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.490603] io scheduler mq-deadline registered
[ 0.490611] io scheduler kyber registered
[ 0.491224] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.560714] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.572590] loop: module loaded
[ 0.579449] libphy: Fixed MDIO Bus: probed
[ 0.579869] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[ 0.580432] libphy: sun4i_mii_bus: probed
[ 0.582568] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.582587] ehci-platform: EHCI generic platform driver
[ 0.583126] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.583153] ohci-platform: OHCI generic platform driver
[ 0.583705] usbcore: registered new interface driver cdc_acm
[ 0.583715] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.583771] usbcore: registered new interface driver usb-storage
[ 0.585685] sun6i-rtc 1c20400.rtc: registered as rtc1
[ 0.585703] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.585947] i2c /dev entries driver
[ 0.588607] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.590357] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.590739] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[ 0.590998] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 0.591487] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 0.591624] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 0.591747] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 0.591854] sun8i-ce 1c15000.crypto: Register cbc(aes)
[ 0.591987] sun8i-ce 1c15000.crypto: Register ecb(aes)
[ 0.592102] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
[ 0.592212] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
[ 0.592337] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
[ 0.594001] iio-rescale a1-volt: using raw+scale source channel
[ 0.594273] iio-rescale a2-volt: using raw+scale source channel
[ 0.594488] iio-rescale a3-volt: using raw+scale source channel
[ 0.594709] iio-rescale vin-volt: using raw+scale source channel
[ 0.596545] NET: Registered protocol family 10
[ 0.597381] Segment Routing with IPv6
[ 0.597471] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.598113] NET: Registered protocol family 17
[ 0.598204] Key type dns_resolver registered
[ 0.598269] Registering SWP/SWPB emulation handler
[ 0.598358] registered taskstats version 1
[ 0.612878] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.616321] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.616756] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[ 0.618208] printk: console [ttyS0] disabled
[ 0.618319] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 53, base_baud = 1500000) is a Allwinner sun4i
[ 1.469405] printk: console [ttyS0] enabled
[ 1.474335] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PI regulator
[ 1.481175] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 274
[ 1.487813] sun4i-pinctrl 1c20800.pinctrl: pin-274 (1c28800.serial) status -517
[ 1.495135] sun4i-pinctrl 1c20800.pinctrl: could not request pin 274 (PI18) from group PI18 on device 1c20800.pinctrl
[ 1.505826] dw-apb-uart 1c28800.serial: Error applying setting, reverse things back
[ 1.514819] wbec spi0.0: wrong wbec ID at 0x0. Get 0x0 istead of 0x3CD2
[ 1.521559] wbec: probe of spi0.0 failed with error -524
[ 1.527278] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[ 1.535292] libphy: sun4i_mii_bus: probed
[ 1.540008] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
[ 1.546846] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
[ 1.553457] sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
[ 1.562383] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
[ 1.569195] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
[ 1.575818] sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
[ 1.583296] sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8 on device 1c20800.pinctrl
[ 1.593820] sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
[ 1.601915] sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PA regulator
[ 1.608716] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
[ 1.615166] sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
[ 1.622469] sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0 on device 1c20800.pinctrl
[ 1.632816] dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
[ 1.647674] axp20x-i2c 0-0034: AXP20x variant AXP221 found
[ 1.660960] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0034/axp221-pek/input/input0
[ 1.680457] vcc-3v3: supplied by regulator-dummy
[ 1.685822] vdd-cpu: supplied by regulator-dummy
[ 1.691134] vdd-sys: supplied by regulator-dummy
[ 1.696430] dcdc4: supplied by regulator-dummy
[ 1.701536] vcc-dram: supplied by regulator-dummy
[ 1.706340] vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
[ 1.713234] vcc-gmac-phy: supplied by vcc-3v3
[ 1.718155] random: fast init done
[ 1.721706] dc5ldo: supplied by vcc-dram
[ 1.726165] tv: Bringing 700000uV into 3300000-3300000uV
[ 1.731957] tv: supplied by regulator-dummy
[ 1.736654] aldo2: Bringing 2500000uV into 3300000-3300000uV
[ 1.742777] aldo2: supplied by regulator-dummy
[ 1.748343] avcc-pll: supplied by regulator-dummy
[ 1.753704] eldo1: supplied by regulator-dummy
[ 1.758865] eldo2: supplied by regulator-dummy
[ 1.763810] vcc-pe: Bringing 1200000uV into 1800000-1800000uV
[ 1.770462] vcc-pe: supplied by regulator-dummy
[ 1.775509] vcc-sd-alt: Bringing 700000uV into 1800000-1800000uV
[ 1.782293] vcc-sd-alt: supplied by regulator-dummy
[ 1.787855] dldo2: supplied by regulator-dummy
[ 1.792955] dldo3: supplied by regulator-dummy
[ 1.798133] dldo4: supplied by regulator-dummy
[ 1.802823] rtc_ldo: supplied by regulator-dummy
[ 1.808124] ldo_io0: supplied by regulator-dummy
[ 1.813388] ldo_io1: supplied by regulator-dummy
[ 1.821742] axp20x-adc axp22x-adc: DMA mask not set
[ 1.831306] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[ 1.841086] axp20x-i2c 0-0034: AXP20X driver loaded
[ 1.873114] rtc-pcf85063 2-0051: registered as rtc0
[ 1.887367] rtc-pcf85063 2-0051: setting system clock to 2023-12-22T09:24:15 UTC (1703237055)
[ 1.899399] lm75 2-0048: supply vs not found, using dummy regulator
[ 1.910028] lm75 2-0048: hwmon1: sensor 'lm75b'
[ 1.932669] sun4i-pinctrl 1c20800.pinctrl: pin PB16 already requested by 1c17000.spi; cannot claim for i2c_eeprom1
[ 1.943072] sun4i-pinctrl 1c20800.pinctrl: pin-48 (i2c_eeprom1) status -22
[ 1.949961] sun4i-pinctrl 1c20800.pinctrl: could not request pin 48 (PB16) from group PB16 on device 1c20800.pinctrl
[ 1.957893] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 1.960564] i2c-gpio i2c_eeprom1: Error applying setting, reverse things back
[ 1.976585] i2c-gpio: probe of i2c_eeprom1 failed with error -22
[ 1.982844] sun4i-pinctrl 1c20800.pinctrl: pin PB14 already requested by 1c17000.spi; cannot claim for i2c_eeprom2
[ 1.993203] sun4i-pinctrl 1c20800.pinctrl: pin-46 (i2c_eeprom2) status -22
[ 2.000086] sun4i-pinctrl 1c20800.pinctrl: could not request pin 46 (PB14) from group PB14 on device 1c20800.pinctrl
[ 2.010692] i2c-gpio i2c_eeprom2: Error applying setting, reverse things back
[ 2.017842] i2c-gpio: probe of i2c_eeprom2 failed with error -22
[ 2.024127] sun4i-usb-phy 1c13400.phy: phy0 dr_mode=3
[ 2.031310] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 54, base_baud = 1500000) is a Allwinner sun4i
[ 2.041442] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[ 2.049399] libphy: sun4i_mii_bus: probed
[ 2.113556] mmc0: new DDR MMC card at address 0001
[ 2.119079] mmcblk0: mmc0:0001 MMC64G 58.2 GiB
[ 2.124008] mmcblk0boot0: mmc0:0001 MMC64G partition 1 4.00 MiB
[ 2.130282] mmcblk0boot1: mmc0:0001 MMC64G partition 2 4.00 MiB
[ 2.136476] mmcblk0rpmb: mmc0:0001 MMC64G partition 3 4.00 MiB, chardev (249:0)
[ 2.146942] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.189067] sun4i-emac 1c0b000.ethernet: using random MAC address e6:44:6a:a6:83:03
[ 2.198791] sun4i-emac 1c0b000.ethernet: eth0: at (ptrval), IRQ 67 MAC: e6:44:6a:a6:83:03
[ 2.207649] dwmac-sun8i 1c50000.ethernet: IRQ eth_wake_irq not found
[ 2.214000] dwmac-sun8i 1c50000.ethernet: IRQ eth_lpi not found
[ 2.220865] ehci-platform 1c14000.usb: EHCI Host Controller
[ 2.226478] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[ 2.234540] ehci-platform 1c14000.usb: irq 38, io mem 0x01c14000
[ 2.265057] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[ 2.271880] hub 1-0:1.0: USB hub found
[ 2.275701] hub 1-0:1.0: 1 port detected
[ 2.280457] ehci-platform 1c19000.usb: EHCI Host Controller
[ 2.286071] ehci-platform 1c19000.usb: new USB bus registered, assigned bus number 2
[ 2.293983] ehci-platform 1c19000.usb: irq 40, io mem 0x01c19000
[ 2.325034] ehci-platform 1c19000.usb: USB 2.0 started, EHCI 1.00
[ 2.331767] hub 2-0:1.0: USB hub found
[ 2.335565] hub 2-0:1.0: 1 port detected
[ 2.340246] ehci-platform 1c1c000.usb: EHCI Host Controller
[ 2.345851] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[ 2.353743] ehci-platform 1c1c000.usb: irq 42, io mem 0x01c1c000
[ 2.385601] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[ 2.392308] hub 3-0:1.0: USB hub found
[ 2.396105] hub 3-0:1.0: 1 port detected
[ 2.495114] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[ 2.501745] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 4
[ 2.509676] ohci-platform 1c14400.usb: irq 39, io mem 0x01c14400
[ 2.589671] hub 4-0:1.0: USB hub found
[ 2.593453] hub 4-0:1.0: 1 port detected
[ 2.598148] ohci-platform 1c19400.usb: Generic Platform OHCI controller
[ 2.604773] ohci-platform 1c19400.usb: new USB bus registered, assigned bus number 5
[ 2.612663] ohci-platform 1c19400.usb: irq 41, io mem 0x01c19400
[ 2.689675] hub 5-0:1.0: USB hub found
[ 2.693456] hub 5-0:1.0: 1 port detected
[ 2.698144] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[ 2.704766] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 6
[ 2.712572] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.719756] ohci-platform 1c1c400.usb: irq 43, io mem 0x01c1c400
[ 2.799669] hub 6-0:1.0: USB hub found
[ 2.803456] hub 6-0:1.0: 1 port detected
[ 2.808406] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[ 2.818847] dwmac-sun8i 1c50000.ethernet: IRQ eth_wake_irq not found
[ 2.825256] dwmac-sun8i 1c50000.ethernet: IRQ eth_lpi not found
[ 2.832268] dwmac-sun8i 1c50000.ethernet: IRQ eth_wake_irq not found
[ 2.838654] dwmac-sun8i 1c50000.ethernet: IRQ eth_lpi not found
[ 2.844857] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 2.845074] of_cfs_init
[ 2.854498] dwmac-sun8i 1c50000.ethernet: IRQ eth_wake_irq not found
[ 2.856331] of_cfs_init: OK
[ 2.862648] dwmac-sun8i 1c50000.ethernet: IRQ eth_lpi not found
[ 2.880639] Freeing unused kernel memory: 8192K
[ 2.891253] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 2.897113] mmc1: error -22 whilst initialising SD card
[ 2.915300] Run /init as init process
[ 2.939147] dwmac-sun8i 1c50000.ethernet: IRQ eth_wake_irq not found
mount: mounting none on /dev/pts failed: No such file or directo[ 2.945602] dwmac-sun8i 1c50000.ethernet: IRQ eth_lpi not found
ry
Run busybox watchdog for /dev/watchdog
Run busybox watchdog for /dev/watchdog0
Run busybox watchdog for /dev/watchdog1
watchdog: can't open '/dev/watchdog0': Device or resource busy
watchdog: WDIOC_SETTIMEOUT: Invalid argument
Boot mode: sdupdate,wb_update.fit
Board is WB7
[ 3.977464] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 3.983325] mmc1: error -22 whilst initialising SD card
[ 5.097460] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 5.103309] mmc1: error -22 whilst initialising SD card
[ 6.217454] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 6.223303] mmc1: error -22 whilst initialising SD card
BusyBox v1.30.1 (Debian 1:1.30.1-6+b3) built-in shell (ash)
Enter 'help' for a list of built-in commands.
sh: can't access tty; job control turned off
~ # [ 7.337934] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 7.343784] mmc1: error -22 whilst initialising SD card
[ 8.457422] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 8.463255] mmc1: error -22 whilst initialising SD card
[ 9.577377] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 9.583205] mmc1: error -22 whilst initialising SD card
[ 10.697368] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 10.703195] mmc1: error -22 whilst initialising SD card
[ 11.817367] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 11.823194] mmc1: error -22 whilst initialising SD card
[ 12.937367] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 12.943192] mmc1: error -22 whilst initialising SD card
[ 14.057373] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 14.063200] mmc1: error -22 whilst initialising SD card
[ 15.177369] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 15.183195] mmc1: error -22 whilst initialising SD card
[ 16.297372] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 16.303199] mmc1: error -22 whilst initialising SD card
