Не стартует загрузка WB6
WB6.5
s/n A3PW5UD7
Добрый день, заменил на одном объекте WB6 на WB7 и положил шестой на полку. Спустя время решил его поставить чтобы висел на стенде, но он у меня отказался загружаться. Горит красная кнопка, пробывал скинуть к заводским настройкам - не получается, в консоле наблюдаю следующее:
U-Boot 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38 +0000)
CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 46C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM:  512 MiB
MMC:   FSL_SDHC: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@02188000
Hit any key to stop autoboot:  0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
1 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
  Device 0: Vendor: SMI      Rev: 1100 Prod: USB DISK
            Type: Removable Hard Disk
            Capacity: 7680.0 MB = 7.5 GB (15728640 x 512)
reading wb6_update.fit
** Unable to read file wb6_update.fit **
reading wb6_update_FACTORYRESET.fit
** Unable to read file wb6_update_FACTORYRESET.fit **
No USB update detected, continuing boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
invalid extent block
ext4fs_devread read outside partition 4294967120
** File not found /boot/uEnv.txt **
Running default loadzimage ...
** File not found /boot/zImage **
U-Boot SPL 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0   = 0x01080102
.p0_mpdgctrl1   = 0x0e3f0e3f
.p0_mprddlctl   = 0x3f3f3d3c
.p0_mpwrdlctl   = 0x3f3f3833
.p0_mpwldectrl0 = 0x00050003
.p0_mpwldectrl1 = 0x00060006
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
Reset cause: POR
DRAM:  512 MiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
Какие дальнейшие действия?
Добрый день. Попробуйте провести те же операции с другой флешкой, как минимум заново отформатировать и повторно скачать образ. Не с каждой флешкой получается корректно сбросить настройки.
Отформатировал, загружаюсь, подтверждаю сброс к заводским настройкам и далее
Wed Jan 25 14:23:23 UTC 2023: started update from /usb/wb6_update_FACTORYRESET.fit
Description:         WirenBoard firmware update
Compatible device:   contactless,imx6ul-wirenboard61
Firmware version:    202301121947
Firmware compatible: unknown
Release name:        wb-2207
Release suite:       stable
Release target:      wb6/stretch
Release repo prefix:
Time of creation:    Thu Jan 12 19:49:01 UTC 2023
>>> Checking SHA1 hash of install
PROGRESS: 0%
>>> SHA1 hash of install ok
>>> Wiping data partition (factory reset)
mke2fs 1.43.4 (31-Jan-2017)
The file /dev/mmcblk0p6 does not exist and no size was specified.
!!! Failed to format data partition
Через debug выполните на нем
fdisk -l /dev/mmcblk0
вывод из лога ниже
=> fdisk -l /dev/mmcblk0
Unknown command 'fdisk' - try 'help'
при выводе help нет команды fdisk
uboot естественно не поддерживает приложения.
Покажите лог процесса factory reset сначала, весь.
без флэшки:
.p0_mpdgctrl0   = 0x01060100
CPU:   Industrial temperature grade (-40C to 105C) at 34C
Reset cause: POR
DRAM:  512 MiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
с флэшкой и пробую сброс к заводским настройкам
.p0_mpdgctrl0   = 0x01070101
.p0_mpwrdlctl   = 0x3f3f3831
.p0_mpwldectrl0 = 0x00050005
CPU:   Industrial temperature grade (-40C to 105C) at 37C
Reset cause: POR
DRAM:  512 MiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
1 bytes read in 19 ms (0 Bytes/s)
# Detected USB flash drive with update file
# Filename: wb6_update_FACTORYRESET.fit
# Press a FW key if you want to update firmware from this file
# or wait 3 seconds to boot normally.
USB update procedure start
Checking if ubootenv part is present
## Loading FIT header to 0x82000000 ...
## Loading FIT strings to 0x82000028 ...
## Loading FIT struct to 0x82000100 ...
FAT: Misaligned buffer address (820010c8)
   Skip 7928976 bytes of data
FAT: Misaligned buffer address (8200042c)
   Skip 46505 bytes of data
FAT: Misaligned buffer address (82000e74)
   Skip 4917 bytes of data
   Skip 169931024 bytes of data
FAT: Misaligned buffer address (82000a14)
** wb6_update_FACTORYRESET.fit shorter than offset + len **
Can't find subimage 'ubootenv'
Extracting kernel
7945616 bytes read in 4894 ms (1.5 MiB/s)
     Description:  Update kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x82000300
     Data Size:    7928976 Bytes = 7.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   47f6419e0d5d8326c41b16761827dc3d746fec78
## Verifying ... sha1+
   Loading part 0 ... OK
Extracting DTB
## Loading FIT header to 0x83000000 ...
## Loading FIT strings to 0x83000028 ...
## Loading FIT struct to 0x83000100 ...
FAT: Misaligned buffer address (830010c8)
FAT: Misaligned buffer address (8300042c)
63589 bytes read in 703 ms (87.9 KiB/s)
     Description:  Update DTB
     Type:         Flat Device Tree
     Data Start:   0x83000440
     Data Size:    46505 Bytes = 45.4 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   ef9dd3fe2b348fb8eb9f150b9dc2e27d6899e823
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Loading Device Tree to 9ef61000, end 9ef6f5a8 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.22-wb6_initramfs (root@WB-buildserver) (gcc ver        sion 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #2 SMP Tue Feb 1 16        :52:01 MSK 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio        n cache
[    0.000000] OF: fdt:Machine model: Wiren Board init (i.MX6UL/ULL)
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] percpu: Embedded 14 pages/cpu @cfbcf000 s25932 r8192 d23220 u5734        4
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag        es: 130048
[    0.000000] Kernel command line: console=ttymxc0,115200 bootmode=usbupdate,wb        6_update_FACTORYRESET.fit
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 506756K/524288K available (5120K kernel code, 202K rwdata        , 1576K rodata, 5120K init, 295K bss, 17532K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xd0000000   ( 512 MB)
[    0.000000]     modules : 0xaf000000 - 0xb0000000   (  16 MB)
[    0.000000]       .text : 0xb0008000 - 0xb0600000   (6112 kB)
[    0.000000]       .init : 0xb0800000 - 0xb0d00000   (5120 kB)
[    0.000000]       .data : 0xb0d00000 - 0xb0d32880   ( 203 kB)
[    0.000000]        .bss : 0xb0d34000 - 0xb0d7ddb0   ( 296 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000017] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478        484971ns
[    0.000054] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff,        max_idle_ns: 79635851949 ns
[    0.002606] Console: colour dummy device 80x30
[    0.002649] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 48.00 BogoMIPS (lpj=240000)
[    0.002682] pid_max: default: 32768 minimum: 301
[    0.002869] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.002893] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.004095] CPU: Testing write buffer coherency: ok
[    0.004595] /cpus/cpu@0 missing clock-frequency property
[    0.004635] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004688] Setting up static identity map for 0x80100000 - 0x80100070
[    0.007064] Brought up 1 CPUs
[    0.007098] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.007114] CPU: All CPU(s) started in SVC mode.
[    0.008328] devtmpfs: initialized
[    0.034558] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7        rev 5
[    0.035239] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
[    0.035290] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.035467] pinctrl core: initialized pinctrl subsystem
[    0.037499] NET: Registered protocol family 16
[    0.038015] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.040736] cpuidle: using governor menu
[    0.076014] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
[    0.076046] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.078271] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.118459] mxs-dma 1804000.dma-apbh: initialized
[    0.122968] SCSI subsystem initialized
[    0.123585] usbcore: registered new interface driver usbfs
[    0.123739] usbcore: registered new interface driver hub
[    0.123985] usbcore: registered new device driver usb
[    0.125606] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
[    0.126463] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
[    0.127317] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
[    0.128803] i2c i2c-1: IMX I2C adapter registered
[    0.128846] i2c i2c-1: can't use DMA, using PIO instead.
[    0.129258] pps_core: LinuxPPS API ver. 1 registered
[    0.129280] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
[    0.129337] PTP clock support registered
[    0.131711] clocksource: Switched to clocksource mxc_timer1
[    0.155650] NET: Registered protocol family 2
[    0.156883] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.157006] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.157164] TCP: Hash tables configured (established 4096 bind 4096)
[    0.157277] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.157335] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.157640] NET: Registered protocol family 1
[    0.158474] RPC: Registered named UNIX socket transport module.
[    0.158504] RPC: Registered udp transport module.
[    0.158519] RPC: Registered tcp transport module.
[    0.158533] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.727450] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[    0.742708] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.744729] ntfs: driver 2.1.32 [Flags: R/W].
[    0.755152] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        49)
[    0.755188] io scheduler noop registered (default)
[    0.760316] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx        6q.bin failed with error -2
[    0.760358] imx-sdma 20ec000.sdma: external firmware not found, using ROM fir        mware
[    0.769503] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud =        5000000) is a IMX
[    1.323680] console [ttymxc0] enabled
[    1.329210] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud =        5000000) is a IMX
[    1.339494] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 56, base_baud =        5000000) is a IMX
[    1.382273] imx_rngc 2284000.rngb: Freescale RNGC registered.
[    1.417036] brd: module loaded
[    1.436060] loop: module loaded
[    1.444265] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.455686] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.463266] libphy: Fixed MDIO Bus: probed
[    1.469697] 20b4000.ethernet supply phy not found, using dummy regulator
[    1.477724] pps pps0: new PPS source ptp0
[    1.510517] libphy: fec_enet_mii_bus: probed
[    1.516780] fec 20b4000.ethernet eth0: registered PHC device 0
[    1.641799] 2188000.ethernet supply phy not found, using dummy regulator
[    1.762757] pps pps1: new PPS source ptp1
[    1.767821] libphy: fec_enet_mii_bus: probed
[    1.775790] fec 2188000.ethernet eth1: registered PHC device 1
[    1.782369] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.788937] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.794799] usbcore: registered new interface driver cdc_acm
[    1.800496] cdc_acm: USB Abstract Control Model driver for USB modems and ISD        N adapters
[    1.808985] usbcore: registered new interface driver usb-storage
[    1.872153] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
[    1.888253] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.s        nvs:snvs-r as rtc1
[    1.897376] i2c /dev entries driver
[    1.905606] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[    1.913118] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_SD1_DATA1 already re        quested by watchdog; cannot claim for watchdog_6x
[    1.924667] imx6ul-pinctrl 20e0000.iomuxc: pin-114 (watchdog_6x) status -22
[    1.931671] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 114 (MX6UL_P        AD_SD1_DATA1) from group wdggrp_6x  on device 20e0000.iomuxc
[    1.944137] gpio-wdt watchdog_6x: Error applying setting, reverse things back
[    1.951324] gpio-wdt: probe of watchdog_6x failed with error -22
[    1.959122] sdhci: Secure Digital Host Controller Interface driver
[    1.965447] sdhci: Copyright(c) Pierre Ossman
[    1.969834] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.041779] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADM        A
[    2.061338] ledtrig-cpu: registered to indicate activity on CPUs
[    2.071353] random: fast init done
[    2.089421] usbcore: registered new interface driver usbhid
[    2.097184] usbhid: USB HID core driver
[    2.111443] NET: Registered protocol family 17
[    2.122462] Registering SWP/SWPB emulation handler
[    2.129524] registered taskstats version 1
[    2.146495] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature        grade - max:105C critical:100C passive:95C
[    2.169660] rtc-pcf8563 4-0051: setting system clock to 2023-01-26 14:29:16 U        TC (1674743356)
[    2.178150] of_cfs_init
[    2.180802] of_cfs_init: OK
[    2.189680] vdd3p0: disabling
[    2.194857] vref-3v3: disabling
[    2.200110] usb1_vbus: disabling
[    2.212096] Freeing unused kernel memory: 5120K (b0800000 - b0d00000)
[    2.227876] mmc0: new DDR MMC card at address 0001
[    2.248053] mmcblk0: mmc0:0001 W62704 3.53 GiB
[    2.262083] mmcblk0boot0: mmc0:0001 W62704 partition 1 2.00 MiB
mount: mounting none on /dev/pts [    2.273742] mmcblk0boot1: mmc0:0001 W62704 p        artition 2 2.00 MiB
failed: No such file or directory
[    2.292328] mmcblk0rpmb: mmc0:0001 W62704 partition 3 512 KiB
[    2.304790]  mmcblk0: p1 p2 p3 p4 < >
Boot mode: usbupdate,wb6_update_FACTORYRESET.fit
Board is WB6, loading ci_hdrc_imx module
[    2.538158] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    2.543383] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    2.571731] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    2.577408] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.584280] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
[    2.591513] usb usb1: Product: EHCI Host Controller
[    2.596428] usb usb1: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[    2.603084] usb usb1: SerialNumber: ci_hdrc.0
[    2.608931] hub 1-0:1.0: USB hub found
[    2.612946] hub 1-0:1.0: 1 port detected
[    2.618460] 2184200.usb supply vbus not found, using dummy regulator
[    2.629136] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.634237] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[    2.661790] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    2.667546] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.674433] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
[    2.681709] usb usb2: Product: EHCI Host Controller
[    2.686606] usb usb2: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[    2.693270] usb usb2: SerialNumber: ci_hdrc.1
[    2.699069] hub 2-0:1.0: USB hub found
[    2.703056] hub 2-0:1.0: 1 port detected
[    2.971886] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    3.061845] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[    3.165090] usb 1-1: New USB device found, idVendor=090c, idProduct=1000
[    3.172020] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.179285] usb 1-1: Product: USB DISK
[    3.183169] usb 1-1: Manufacturer: SMI Corporation
[    3.188008] usb 1-1: SerialNumber: FC170204104509WSXM3K
[    3.196610] usb-storage 1-1:1.0: USB Mass Storage device detected
[    3.204458] scsi host0: usb-storage 1-1:1.0
[    3.252761] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[    3.259589] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.269848] hub 2-1:1.0: USB hub found
[    3.274106] hub 2-1:1.0: 4 ports detected
[    3.591876] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[    3.744452] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[    3.751460] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
[    3.759099] usb 2-1.1: Product: 802.11n WLAN Adapter
[    3.764215] usb 2-1.1: Manufacturer: Realtek
[    3.768533] usb 2-1.1: SerialNumber: 00e04c000001
Load modules for USB to work
Starting USB update
Waiting for USB to settle (0/10)
[    4.370341] scsi 0:0:0:0: Direct-Access     SMI      USB DISK         1100 PQ        : 0 ANSI: 4
[    4.383428] sd 0:0:0:0: [sda] 15728640 512-byte logical blocks: (8.05 GB/7.50        GiB)
[    4.394054] sd 0:0:0:0: [sda] Write Protect is off
[    4.400367] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does        n't support DPO or FUA
[    4.424588]  sda: sda1
[    4.434729] sd 0:0:0:0: [sda] Attached SCSI removable disk
umount: can't umount /usb: Invalid argument
Looking for wb6_update_FACTORYRESET.fit on /dev/sda
mount: mounting /dev/sda on /usb failed: Invalid argument
Looking for wb6_update_FACTORYRESET.fit on /dev/sda1
[    5.115054] FAT-fs (sda1): Volume was not properly unmounted. Some data may b        e corrupt. Please run fsck.
BusyBox v1.22.1 (Debian 1:1.22.0-19+deb9u2) built-in shell (ash)
Enter 'help' for a list of built-in commands.
                          FACTORY RESET REQUESTED
           This WILL destroy ALL YOUR DATA: configuration, scripts,
                           files in home directory!
         If you are ABSOLUTELY SURE that you want to reset Wiren Board
             to factory condition, hold the FW button for 4 seconds.
        If you will not do it in 10 seconds, the controller will reboot
                        without firmware update.
           If you want to perform a regular firmware update, rename
         FIT file to "wbX_update.fit" without "factory-reset" suffix.
Factory reset is confirmed!
Thu Jan 26 14:29:26 UTC 2023: started update from /usb/wb6_update_FACTORYRESET.f        it
PROGRESS: 0%
Добрый день, подскажите есть какие-то мысли глядя в логи?
Может быть будет проще отправить вам пациента на вскрытие?
Возможна ли замена WB6 на WB7 с доплатой?
Пожалуй, тут нужно переинициализировать на стенде.
Можно попробовать, конечно на производстве, стоимость “диагностики” - 500 рублей+ доставка.
Менять на WB7 не получится, довольно старое устройство: Условия возврата - Wiren Board
Спасибо!
Написал на info@wirenboard.com ссылку на тему прикрепил
