U-Boot SPL 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0 = 0x01030103
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3b3c
.p0_mpwrdlctl = 0x3f3f3532
.p0_mpwldectrl0 = 0x000c000c
.p0_mpwldectrl1 = 0x000d000d
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 48C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=1
mmcpart=3
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net: Could not get PHY for FEC0: addr 0
No ethernet found.
Hit any key to stop autoboot: 0
=> setenv mmcpart 3
=> saveenv
Saving Environment to MMC... Writing to MMC(1)... OK
=> reset
resetting ...
.p0_mpdgctrl0 = 0x01060103
.p0_mprddlctl = 0x3f3f3a3e
.p0_mpwrdlctl = 0x3f3f3432
Reset cause: WDOG
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=1
mmcpart=3
upgrade_available=0
Net: eth0: ethernet@2188000
Hit any key to stop autoboot: 1
.p0_mprddlctl = 0x3f3f3b3e
default -a пишет, что нет такой команды. Остальные команды ввёл.
Контроллер загруажается теперь.
Но проблема с обновлением через флэшку осталась.
## Info: input data size = 4285 = 0x10BD
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
Press FW button to enter firmware update mode
Entering firmware update mode.
Checking if ubootenv part is present
## Loading FIT header to 0x82000000 ...
## Loading FIT strings to 0x82000028 ...
## Loading FIT struct to 0x82000100 ...
Can't find subimage 'ubootenv'
Extracting kernel
7937936 bytes read in 365 ms (20.7 MiB/s)
Description: Update kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x82000300
Data Size: 7928976 Bytes = 7.6 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 47f6419e0d5d8326c41b16761827dc3d746fec78
## Verifying ... sha1+
Loading part 0 ... OK
Extracting DTB
## Loading FIT header to 0x83000000 ...
## Loading FIT strings to 0x83000028 ...
## Loading FIT struct to 0x83000100 ...
55849 bytes read in 30 ms (1.8 MiB/s)
Description: Update DTB
Type: Flat Device Tree
Data Start: 0x83000480
Data Size: 46505 Bytes = 45.4 KiB
Architecture: ARM
Hash algo: sha1
Hash value: ef9dd3fe2b348fb8eb9f150b9dc2e27d6899e823
Kernel image @ 0x82000000 [ 0x000000 - 0x78fc90 ]
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef8c000, end 9ef9a5a8 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.22-wb6_initramfs (root@WB-buildserver) (gcc ver sion 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #2 SMP Tue Feb 1 16 :52:01 MSK 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] OF: fdt:Machine model: Wiren Board init (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @cfbd0000 s25932 r8192 d23220 u5734 4
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 130048
[ 0.000000] Kernel command line: console=ttymxc0,115200 bootmode=update_auto
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 506756K/524288K available (5120K kernel code, 202K rwdata , 1576K rodata, 5120K init, 295K bss, 17532K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xd0000000 ( 512 MB)
[ 0.000000] modules : 0xaf000000 - 0xb0000000 ( 16 MB)
[ 0.000000] .text : 0xb0008000 - 0xb0600000 (6112 kB)
[ 0.000000] .init : 0xb0800000 - 0xb0d00000 (5120 kB)
[ 0.000000] .data : 0xb0d00000 - 0xb0d32880 ( 203 kB)
[ 0.000000] .bss : 0xb0d34000 - 0xb0d7ddb0 ( 296 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478 484971ns
[ 0.000052] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002598] Console: colour dummy device 80x30
[ 0.002640] Calibrating delay loop (skipped), value calculated using timer fr equency.. 48.00 BogoMIPS (lpj=240000)
[ 0.002673] pid_max: default: 32768 minimum: 301
[ 0.002861] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002886] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004094] CPU: Testing write buffer coherency: ok
[ 0.004589] /cpus/cpu@0 missing clock-frequency property
[ 0.004627] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004683] Setting up static identity map for 0x80100000 - 0x80100070
[ 0.007065] Brought up 1 CPUs
[ 0.007101] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.007117] CPU: All CPU(s) started in SVC mode.
[ 0.008337] devtmpfs: initialized
[ 0.034596] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.035289] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.035338] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.035519] pinctrl core: initialized pinctrl subsystem
[ 0.037549] NET: Registered protocol family 16
[ 0.038066] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.040761] cpuidle: using governor menu
[ 0.076281] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.076315] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.078525] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.118691] mxs-dma 1804000.dma-apbh: initialized
[ 0.123202] SCSI subsystem initialized
[ 0.123826] usbcore: registered new interface driver usbfs
[ 0.123985] usbcore: registered new interface driver hub
[ 0.124230] usbcore: registered new device driver usb
[ 0.125845] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
[ 0.126699] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
[ 0.127552] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
[ 0.129046] i2c i2c-1: IMX I2C adapter registered
[ 0.129088] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.129502] pps_core: LinuxPPS API ver. 1 registered
[ 0.129528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.129586] PTP clock support registered
[ 0.131969] clocksource: Switched to clocksource mxc_timer1
[ 0.155903] NET: Registered protocol family 2
[ 0.157134] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.157258] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.157416] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.157533] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.157589] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.157894] NET: Registered protocol family 1
[ 0.158743] RPC: Registered named UNIX socket transport module.
[ 0.158774] RPC: Registered udp transport module.
[ 0.158788] RPC: Registered tcp transport module.
[ 0.158804] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.727783] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.743080] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.745106] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.755528] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 49)
[ 0.755563] io scheduler noop registered (default)
[ 0.760689] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx 6q.bin failed with error -2
[ 0.760729] imx-sdma 20ec000.sdma: external firmware not found, using ROM fir mware
[ 0.769762] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[ 1.321611] console [ttymxc0] enabled
[ 1.327173] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud = 5000000) is a IMX
[ 1.337463] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 56, base_baud = 5000000) is a IMX
[ 1.380240] imx_rngc 2284000.rngb: Freescale RNGC registered.
[ 1.415223] brd: module loaded
[ 1.434198] loop: module loaded
[ 1.442447] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.453864] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.461376] libphy: Fixed MDIO Bus: probed
[ 1.467905] 20b4000.ethernet supply phy not found, using dummy regulator
[ 1.475932] pps pps0: new PPS source ptp0
[ 1.508977] libphy: fec_enet_mii_bus: probed
[ 1.515253] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.642062] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.763023] pps pps1: new PPS source ptp1
[ 1.768082] libphy: fec_enet_mii_bus: probed
[ 1.775185] fec 2188000.ethernet eth1: registered PHC device 1
[ 1.781594] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.788297] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.794130] usbcore: registered new interface driver cdc_acm
[ 1.799827] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 1.808191] usbcore: registered new interface driver usb-storage
[ 1.871610] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 1.887838] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.s nvs:snvs-r as rtc1
[ 1.896968] i2c /dev entries driver
[ 1.905153] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.912651] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_SD1_DATA1 already re quested by watchdog; cannot claim for watchdog_6x
[ 1.924185] imx6ul-pinctrl 20e0000.iomuxc: pin-114 (watchdog_6x) status -22
[ 1.931188] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 114 (MX6UL_P AD_SD1_DATA1) from group wdggrp_6x on device 20e0000.iomuxc
[ 1.943611] gpio-wdt watchdog_6x: Error applying setting, reverse things back
[ 1.950803] gpio-wdt: probe of watchdog_6x failed with error -22
[ 1.958587] sdhci: Secure Digital Host Controller Interface driver
[ 1.964915] sdhci: Copyright(c) Pierre Ossman
[ 1.969301] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.042038] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADM A
[ 2.061597] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.071599] random: fast init done
[ 2.089651] usbcore: registered new interface driver usbhid
[ 2.097418] usbhid: USB HID core driver
[ 2.111708] NET: Registered protocol family 17
[ 2.122691] Registering SWP/SWPB emulation handler
[ 2.129710] registered taskstats version 1
[ 2.146687] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[ 2.170001] rtc-pcf8563 4-0051: setting system clock to 2023-11-13 08:55:29 U TC (1699865729)
[ 2.178490] of_cfs_init
[ 2.181144] of_cfs_init: OK
[ 2.190063] vdd3p0: disabling
[ 2.195241] vref-3v3: disabling
[ 2.200489] usb1_vbus: disabling
[ 2.212442] Freeing unused kernel memory: 5120K (b0800000 - b0d00000)
[ 2.227769] mmc0: new DDR MMC card at address 0001
[ 2.247905] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[ 2.262330] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
mount: mounting none on /dev/pts [ 2.272300] mmcblk0boot1: mmc0:0001 Q2J55L p artition 2 16.0 MiB
failed: No such file or directory
[ 2.292547] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[ 2.303377] mmcblk0: p1 p2 p3 p4 < p5 p6 >
Boot mode: update_auto
Board is WB6, loading ci_hdrc_imx module
[ 2.542204] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 2.547150] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 2.582044] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 2.587742] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.594601] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.601831] usb usb1: Product: EHCI Host Controller
[ 2.606763] usb usb1: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[ 2.613423] usb usb1: SerialNumber: ci_hdrc.0
[ 2.619253] hub 1-0:1.0: USB hub found
[ 2.623252] hub 1-0:1.0: 1 port detected
[ 2.628695] 2184200.usb supply vbus not found, using dummy regulator
[ 2.639384] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.644484] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.672061] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.677843] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.684720] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.692002] usb usb2: Product: EHCI Host Controller
[ 2.696896] usb usb2: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[ 2.703589] usb usb2: SerialNumber: ci_hdrc.1
[ 2.709362] hub 2-0:1.0: USB hub found
[ 2.713352] hub 2-0:1.0: 1 port detected
[ 3.022131] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 3.072106] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 3.213927] usb 1-1: New USB device found, idVendor=23a9, idProduct=ef18
[ 3.220754] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.228105] usb 1-1: Product: DISK
[ 3.231558] usb 1-1: Manufacturer: USB
[ 3.238560] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 3.246762] scsi host0: usb-storage 1-1:1.0
[ 3.262783] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[ 3.269558] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.278497] hub 2-1:1.0: USB hub found
[ 3.282654] hub 2-1:1.0: 4 ports detected
[ 3.602139] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 3.754701] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[ 3.761701] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 3.769320] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 3.774430] usb 2-1.1: Manufacturer: Realtek
[ 3.778749] usb 2-1.1: SerialNumber: 00e04c000001
1+0 records in
1+0 records out
1024 bytes (1.0 kB, 1.0 KiB) copied, 0.0003995 s, 2.6 MB/s
Wait for eMMC to become available...
Activate Mass Storage device
[ 4.015122] udc-core: couldn't find an available UDC - added [g_mass_storage] to list of pending drivers
[ 4.324527] scsi 0:0:0:0: Direct-Access SCSI DISK 1.00 PQ : 0 ANSI: 4
[ 4.337105] sd 0:0:0:0: [sda] 7880800 512-byte logical blocks: (4.03 GB/3.76 GiB)
[ 4.348333] sd 0:0:0:0: [sda] Write Protect is off
[ 4.354567] sd 0:0:0:0: [sda] No Caching mode page found
[ 4.359954] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.372362] sda: sda1
[ 4.378144] sd 0:0:0:0: [sda] Attached SCSI removable disk
