Debian GNU/Linux 11 wirenboard-A6M5AOQR ttyS0
wirenboard-A6M5AOQR login: [ 34.407277] vcc-gmac-phy: disabling
[ 34.411356] dc5ldo: disabling
[ 34.415113] dldo4: disabling
[ 36.753425] Mass Storage Function, version: 2009/09/11
[ 36.758955] LUN: removable file: (no medium)
[ 36.786505] using random self ethernet address
[ 36.791354] using random host ethernet address
[ 36.928168] dbg0: HOST MAC 1a:55:89:a2:69:44
[ 36.932721] dbg0: MAC 1a:55:89:a2:69:43
[ 42.313950] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Stopping telegraf metric s…rd Cloud (wirenboard.cloud)…
[ OK ] Stopped telegraf metric se…oard Cloud (wirenboard.cloud).
Starting telegraf metric s…rd Cloud (wirenboard.cloud)…
[ OK ] Started telegraf metric se…oard Cloud (wirenboard.cloud).
[ 77.842053] Bluetooth: hci0: advertising data len corrected 31 → 21
[ 81.784042] Bluetooth: hci0: advertising data len corrected 31 → 21
[EC] Watchdog is timed out, reset power.
U-Boot SPL 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
DRAM: 2048 MiB
Trying to boot from MMC2
U-Boot 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
CPU: Allwinner R40 (SUN8I 1701)
Model: Wiren Board rev. 7.2.0 (A40i)
I2C: ready
DRAM: 2 GiB
MMC: mmc@1c0f000: 0, mmc@1c11000: 1
Loading Environment from MMC… OK
In: serial@1c28000
Out: serial@1c28000
Err: serial@1c28000
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
Info: input data size = 142 = 0x8E
bootcount=0
mmcpart=2
uenvcmd=true ; echo reset environment; env default -a; setenv mmcdev 0; saveenv; bmode emmc; reset
upgrade_available=0
Environment size: 142/131068 bytes
Resetting to default environment
Net: No ethernet found.
Hit key to stop autoboot in 1s
Info: input data size = 4281 = 0x10B9
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
Press FW button to enter firmware update mode
326 bytes read in 2 ms (159.2 KiB/s)
Importing environment from 0x42000000…
Checking if uenvcmd is set …
test - minimal test like /bin/sh
Usage:
test [args..]
Running default loadzimage …
6545328 bytes read in 174 ms (35.9 MiB/s)
MMC read: dev # 1, block # 2016, count 32 … 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt sun8i-r40-wirenboard742
57964 bytes read in 6 ms (9.2 MiB/s)
254 bytes read in 3 ms (82 KiB/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc …
Kernel image @ 0x42000000 [ 0x000000 - 0x63dfb0 ]
Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Loading Device Tree to 49fdd000, end 49ffffff … OK
какие могут быть мои дальнейшие действия
