ERROR: [mbgate] FATAL: Failed to parse JSON /etc/wb-mqtt-mbgate.conf:* Line 1, Column 1
Вижу в журнале такие сообщения, как поправить?
1729299083: Saving in-memory database to /var/lib/mosquitto//mosquitto.db.
19-10-2024 03:51:16.838 [init.scope]	wb-mqtt-mbgate.service: Failed with result 'exit-code'.
19-10-2024 03:51:16.837 [init.scope]	wb-mqtt-mbgate.service: Main process exited, code=exited, status=1/FAILURE
19-10-2024 03:51:16.822 [wb-mqtt-mbgate]	  Syntax error: value, object or array expected.
19-10-2024 03:51:16.822 [wb-mqtt-mbgate]	ERROR: [mbgate] FATAL: Failed to parse JSON /etc/wb-mqtt-mbgate.conf:* Line 1, Column 1
19-10-2024 03:51:16.746 [init.scope]	Started Wiren Board MQTT to Modbus gateway.
19-10-2024 03:51:16.657 [init.scope]	Stopped Wiren Board MQTT to Modbus gateway.
19-10-2024 03:51:16.637 [init.scope]	wb-mqtt-mbgate.service: Scheduled restart job, restart counter is at 345.
19-10-2024 03:51:15.122 [ntp]	frequency file /var/lib/ntp/ntp.drift.TEMP: Permission denied
19-10-2024 03:51:06.541 [init.scope]	wb-mqtt-mbgate.service: Failed with result 'exit-code'.
19-10-2024 03:51:06.535 [init.scope]	wb-mqtt-mbgate.service: Main process exited, code=exited, status=1/FAILURE
19-10-2024 03:51:06.521 [wb-mqtt-mbgate]	  Syntax error: value, object or array expected.
19-10-2024 03:51:06.521 [wb-mqtt-mbgate]	ERROR: [mbgate] FATAL: Failed to parse JSON /etc/wb-mqtt-mbgate.conf:* Line 1, Column 1
19-10-2024 03:51:06.425 [init.scope]	Started Wiren Board MQTT to Modbus gateway.
19-10-2024 03:51:06.406 [init.scope]	Stopped Wiren Board MQTT to Modbus gateway.
19-10-2024 03:51:06.385 [init.scope]	wb-mqtt-mbgate.service: Scheduled restart job, restart counter is at 344.
19-10-2024 03:50:56.262 [init.scope]	wb-mqtt-mbgate.service: Failed with result 'exit-code'.
19-10-2024 03:50:56.256 [init.scope]	wb-mqtt-mbgate.service: Main process exited, code=exited, status=1/FAILURE
19-10-2024 03:50:56.241 [wb-mqtt-mbgate]	  Syntax error: value, object or array expected.
19-10-2024 03:50:56.241 [wb-mqtt-mbgate]	ERROR: [mbgate] FATAL: Failed to parse JSON /etc/wb-mqtt-mbgate.conf:* Line 1, Column 1
19-10-2024 03:50:56.165 [init.scope]	Started Wiren Board MQTT to Modbus gateway.
19-10-2024 03:50:56.148 [init.scope]	Stopped Wiren Board MQTT to Modbus gateway.
19-10-2024 03:50:56.129 [init.scope]	wb-mqtt-mbgate.service: Scheduled restart job, restart counter is at 343.
19-10-2024 03:50:46.048 [init.scope]	wb-mqtt-mbgate.service: Failed with result 'exit-code'.
19-10-2024 03:50:46.044 [init.scope]	wb-mqtt-mbgate.service: Main process exited, code=exited, status=1/FAILURE
19-10-2024 03:50:46.030 [wb-mqtt-mbgate]	  Syntax error: value, object or array expected.
19-10-2024 03:50:46.030 [wb-mqtt-mbgate]	ERROR: [mbgate] FATAL: Failed to parse JSON /etc/wb-mqtt-mbgate.conf:* Line 1, Column 1
(221,0 КБ)
Как я вижу - файл /etc/wb-mqtt-mbgate.conf пуст.
Рекомендую добавить в него пустую конфигурацию, например из дефолтной.
А после каких действий (после чего) он очистился?
apt update && apt upgrade. Видимо при обновлении был вопрос что делать с этим файлом и не правильно выбрал вариант
Ну, файл не меняется, так как принадлежит к пакету wb-configs, а в нем изменений не было.
Попробую воспроизвести конечно.
Получилось восстановить работу сервиса?
