Добрый день, после перехода на свежую прошивку (wb-2501 stable) перестал открываться в Вэбе Шлюз mqtt-modbus. Вывод при поиcке ошибок:
root@wirenboard-A6QLDBO7:~# systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
● wb-mqtt-mbgate.service loaded failed failed Wiren Board MQTT to Modbus gateway
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
2 loaded units listed.
root@wirenboard-A6QLDBO7:~# systemctl status wb-mqtt-mbgate
● wb-mqtt-mbgate.service - Wiren Board MQTT to Modbus gateway
Loaded: loaded (/lib/systemd/system/wb-mqtt-mbgate.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2025-02-26 11:02:44 UTC; 27min ago
Process: 1788 ExecStart=/usr/bin/wb-mqtt-mbgate -c /etc/wb-mqtt-mbgate.conf (code=exited, status=6)
Main PID: 1788 (code=exited, status=6)
CPU: 163ms
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: desc: Failed to validate against schema associated with property name ‘size’.
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: Error 177
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: context: <root>[registers][inputs]
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: desc: Failed to validate item #150 in array.
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: Error 178
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: desc: Failed to validate against schema associated with property name ‘inputs’.
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: Error 179
Feb 26 11:02:46 wirenboard-A6QLDBO7 wb-mqtt-mbgate[1788]: desc: Failed to validate against schema associated with property name ‘registers’.
root@wirenboard-A6QLDBO7:~# systemctl status NetworkManager-wait-online
● NetworkManager-wait-online.service - Network Manager Wait Online
Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2025-02-26 11:03:31 UTC; 27min ago
Docs: man:nm-online(1)
Process: 505 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAILURE)
Main PID: 505 (code=exited, status=1/FAILURE)
CPU: 510ms
Feb 26 11:02:32 wirenboard-A6QLDBO7 systemd[1]: Starting Network Manager Wait Online…
Feb 26 11:03:31 wirenboard-A6QLDBO7 systemd[1]: NetworkManager-wait-online.service: Main process exited, code=exited, status=1/FAILURE
Feb 26 11:03:31 wirenboard-A6QLDBO7 systemd[1]: NetworkManager-wait-online.service: Failed with result ‘exit-code’.
Feb 26 11:03:31 wirenboard-A6QLDBO7 systemd[1]: Failed to start Network Manager Wait Online.
Были следующие попытки устранить ошибки:
- /etc/wb-mqtt-mbgate.conf.default скопирован в /etc/wb-mqtt-mbgate.conf
- /etc/wb-mqtt-mbgate.conf изменялся вручную
- перезаливалась свежая прошивка
- сброс при помощи команды
systemctl reset-failed
Ни один из способов не привел к решению проблемы.
Ко всему прикладываю дигностический архив.
