Failed to load '/boot/zImage' после увеличения корневого раздела
После попытке Расширить rootfs
oot@wirenboard-ANTF342K:~# wb-run-update /mnt/data/.wb-update/202503270622_wb-2501_bullseye_wb7x.fit
Сб 29 мар 2025 12:24:59 MSK: started update from /mnt/data/.wb-update/202503270622_wb-2501_bullseye_wb7x.fit
Description:         WirenBoard firmware update
Compatible device:   wirenboard,wirenboard-720
Firmware version:    202503270622
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix +fit-immutable-support +wb8-debug-network-update-fix +wrong-ab-layout-fix +update-from-cloud
Release name:        wb-2501
Release suite:       stable
Release target:      wb7/bullseye
Release repo prefix:
Time of creation:    Чт 27 мар 2025 09:24:38 MSK
>>> Checking SHA1 hash of install
>>> SHA1 hash of install ok
32+0 записей получено
32+0 записей отправлено
16384 байт (16 kB, 16 KiB) скопирован, 0,0006745 s, 24,3 MB/s
>>> Firmware seems to be compatible with this controller
>>> Extracting install script
>>> Running install script
>>> Using flags from /mnt/data/.wb-update/install_update.web.flags: ‘–force-repartition /n’
>>> Console logging enabled; tempfile /tmp/tmp.6jg8nTIm2k, final file /mnt/data/.wb-update/wb-console.log will be written on exit
16384 байт (16 kB, 16 KiB) скопирован, 0,00141429 s, 11,6 MB/s
>>> Checking SHA1 hash of rootfs
>>> SHA1 hash of rootfs ok
>>> rootfs is valid, installing firmware update
>>> Getting mmcpart from U-Boot environment
>>> Will install to /dev/mmcblk0p3
>>> Debian: bullseye -> bullseye
>>> Cleaning up /dev/mmcblk0p3
>>> Cleaning up using rsync
>>> Mounting /dev/mmcblk0p3 at /tmp/tmp.tgE01R0PPC
>>> Extracting files to new rootfs
/tmp/tmp.tgE01R0PPC ~
>>> Recovering device certificates
>>> Mount /dev, /proc and /sys to rootfs /tmp/tmp.tgE01R0PPC
>>> Running post-install scripts
>>> > Processing /tmp/tmp.tgE01R0PPC/usr/lib/wb-image-update/postinst/10update-u-boot
Skipping u-boot update (use factory reset to do it)
>>> > Processing /tmp/tmp.tgE01R0PPC/usr/lib/wb-image-update/postinst/10update-wbec-firmware
Skipping WBEC firmware update (use factory reset to do it)
>>> Unmounting /dev, /proc and /sys from rootfs /tmp/tmp.tgE01R0PPC
>>> Switching to new rootfs
>>> Done!
>>> Removing FIT /mnt/data/.wb-update/202503270622_wb-2501_bullseye_wb7x.fit
>>> Unmounting rootfs
>>> Reboot system
Connection to 192.168.1.72 closed by remote host.
Connection to 192.168.1.72 closed.
получил:
U-Boot 2021.10-wb1.5.0-gf1b9e03284 (Apr 05 2023 - 14:31:04 +0000)
CPU:   Allwinner R40 (SUN8I 1701)
Model: Wiren Board rev. 7.2.0 (A40i)
I2C:   ready
DRAM:  1 GiB
MMC:   mmc@1c0f000: 0, mmc@1c11000: 1
Loading Environment from MMC... OK
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
## Info: input data size = 142 = 0x8E
bootcount=0
mmcpart=3
uenvcmd=true ; echo reset environment; env default -a; setenv mmcdev 0; saveenv; bmode emmc; reset
upgrade_available=1
Environment size: 142/131068 bytes
## Resetting to default environment
Net:   No ethernet found.
Hit <SPACE> key to stop autoboot in  1s
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
Press FW button to enter firmware update mode
326 bytes read in 7 ms (44.9 KiB/s)
Importing environment from 0x42000000...
Checking if uenvcmd is set ...
test - minimal test like /bin/sh
Usage:
test [args..]
Running default loadzimage ...
как это исправить, желательно с сохранением всех данных?
Прошу прислать полный вывод с отладочной консоли при загрузке контроллера в текстовом виде.
Да, но путем фактору ресет.
В “получил” весь вывод и представлен.
