Не расширяется rootfs wb 7.2.1
здравствуйте. накатил 2407 stable через гуй, поставил галочку “расширить rootfs”, еще раз накатил. прошивка обновляется успешно, раздел остается прежним. не хотелось бы делать factory reset, подскажите что еще попробовать. спасибо.
Thu Sep 26 10:25:00 UTC 2024: started update from /mnt/data/uploads/202409041832_wb-2407_bullseye_wb7x.fit
Description:         WirenBoard firmware update
Compatible device:   wirenboard,wirenboard-720
Firmware version:    202409041832
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix +update-from-cloud
Release name:        wb-2407
Release suite:       stable
Release target:      wb7/bullseye
Release repo prefix:
Time of creation:    Wed Sep  4 18:35:00 UTC 2024
>>> Checking SHA1 hash of install
>>> SHA1 hash of install ok
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00232448 s, 7.0 MB/s
tar: stdout: write error
>>> Firmware seems to be compatible with this controller
>>> Extracting install script
>>> Running install script
>>> Console logging enabled; tempfile /tmp/tmp.YEg5qA85EN, final file /mnt/data/uploads/wb-console.log will be written on exit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00074159 s, 22.1 MB/s
>>> Checking SHA1 hash of rootfs
>>> SHA1 hash of rootfs ok
>>> rootfs is valid, installing firmware update
>>> Getting mmcpart from U-Boot environment
>>> Will install to /dev/mmcblk0p3
>>> Debian: bullseye -> bullseye
>>> Cleaning up /dev/mmcblk0p3
>>> Cleaning up using rsync
>>> Mounting /dev/mmcblk0p3 at /tmp/tmp.Wu577aCUFU
>>> Extracting files to new rootfs
/tmp/tmp.Wu577aCUFU /
>>> Recovering device certificates
>>> Mount /dev, /proc and /sys to rootfs /tmp/tmp.Wu577aCUFU
>>> Running post-install scripts
>>> > Processing /tmp/tmp.Wu577aCUFU/usr/lib/wb-image-update/postinst/10update-u-boot
Skipping u-boot update (use factory reset to do it)
>>> > Processing /tmp/tmp.Wu577aCUFU/usr/lib/wb-image-update/postinst/10update-wbec-firmware
Skipping WBEC firmware update (use factory reset to do it)
>>> Unmounting /dev, /proc and /sys from rootfs /tmp/tmp.Wu577aCUFU
>>> Switching to new rootfs
>>> Done!
>>> Removing FIT /mnt/data/uploads/202409041832_wb-2407_bullseye_wb7x.fit
>>> Unmounting rootfs
>>> Reboot system
7.2.1B 579
root@wirenboard-AI6XF5NV:/var/log# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       976M  626M  284M  69% /
devtmpfs        491M     0  491M   0% /dev
tmpfs           499M  4.0K  499M   1% /dev/shm
tmpfs           200M  1.3M  199M   1% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
/dev/mmcblk0p6  4.7G  1.2G  3.3G  27% /mnt/data
tmpfs           100M     0  100M   0% /run/user/0
Согласно документации, единственным вариантом остается сброс устройства к заводским настройкам. Перед выполнением сброса рекомендуется создать резервную копию, чтобы сохранить все ваши данные.
Подробно разобрано тут: Не расширился rootfs wb 7.2.1 - #18 от пользователя GreyVoyager
Не забудьте предварительно обновить uboot и заменит заводской .fit в /mnt/data/.wb-restore/factoryreset.fit
factory reset не помог. помогло взять версию 2404 (не самую последнюю), накатить после сброса дважды с расширением раздела, она расширился. после уже встала последняя (202409041832_wb-2407_bullseye_wb7x.fit). такое ощущение, что в ней есть ошибка\отключен скрипт. всем спасибо.
Рад, что вопрос решился!
