Wirenboard 6.7 не расширяется раздел
При обновлении прошивки с галкой расширить раздел процесс не проходит, лог прилагаю
Received good update FIT /var/www/uploads/202503141231_wb-2501_bullseye_wb67.fit, starting update
Sun Mar 16 06:51:20 UTC 2025: started update from /mnt/data/uploads/202503141231_wb-2501_bullseye_wb67.fit
Description: WirenBoard firmware update
Compatible device: contactless,imx6ul-wirenboard670
Firmware version: 202503141231
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix +fit-immutable-support +wb8-debug-network-update-fix +wrong-ab-layout-fix +update-from-cloud
Release name: wb-2501
Release suite: stable
Release target: wb6/bullseye
Release repo prefix:
Time of creation: Fri Mar 14 12:33:46 UTC 2025
Checking SHA1 hash of install
SHA1 hash of install ok
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.0109515 s, 1.5 MB/s
tar: stdout: write error
Firmware seems to be compatible with this controller
Extracting install script
Running install script
Console logging enabled; tempfile /tmp/tmp.W7GqbQKvTC, final file /mnt/data/uploads/wb-console.log will be written on exit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00815433 s, 2.0 MB/s
Checking SHA1 hash of rootfs
SHA1 hash of rootfs ok
rootfs is valid, installing firmware update
Getting mmcpart from U-Boot environment
Will install to /dev/mmcblk0p3
Debian: bullseye → bullseye
Cleaning up /dev/mmcblk0p3
Cleaning up using rsync
Mounting /dev/mmcblk0p3 at /tmp/tmp.fDojtEbcyx
Extracting files to new rootfs
/tmp/tmp.fDojtEbcyx /
Recovering device certificates
Mount /dev, /proc and /sys to rootfs /tmp/tmp.fDojtEbcyx
Running post-install scripts
Processing /tmp/tmp.fDojtEbcyx/usr/lib/wb-image-update/postinst/10update-u-boot
Skipping u-boot update (use factory reset to do it)
Processing /tmp/tmp.fDojtEbcyx/usr/lib/wb-image-update/postinst/10update-wbec-firmware
Skipping WBEC firmware update (use factory reset to do it)
Unmounting /dev, /proc and /sys from rootfs /tmp/tmp.fDojtEbcyx
Switching to new rootfs
Done!
Removing FIT /mnt/data/uploads/202503141231_wb-2501_bullseye_wb67.fit
Unmounting rootfs
Reboot system
Предварительно - обновите пакеты контроллера до актуальных версий. Либо используйте Не расширился rootfs wb 7.2.1 - #25 от пользователя AMD
