Привет, не получается подключиться к интернету через модем. Кажется проблема с модемом.
-- Boot d1d34583e1174d088b31fc583c8eca32 --
сен 15 13:16:15 wirenboard-AQSPJYFN systemd[1]: Starting Modem Manager...
сен 15 13:16:16 wirenboard-AQSPJYFN ModemManager[383]: <info> ModemManager (version 1.20.0) starting in system bus...
сен 15 13:16:16 wirenboard-AQSPJYFN systemd[1]: Started Modem Manager.
сен 15 13:16:19 wirenboard-AQSPJYFN ModemManager[383]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/soc/1c0b000.ethernet': not supported by any plugin
сен 15 13:16:19 wirenboard-AQSPJYFN ModemManager[383]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/soc/1c19000.usb/usb2/2-1': not supported by any plugin
сен 15 13:16:19 wirenboard-AQSPJYFN ModemManager[383]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/soc/1c50000.ethernet': not supported by any plugin
сен 15 13:16:53 wirenboard-AQSPJYFN ModemManager[383]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/soc/1c13000.usb/musb-hdrc.2.auto': not supported by any plugin
сен 15 13:17:08 wirenboard-AQSPJYFN ModemManager[383]: <info> [device wbc] creating modem with plugin 'simtech' and '4' ports
сен 15 13:17:08 wirenboard-AQSPJYFN ModemManager[383]: <info> [base-manager] modem for device 'wbc' successfully created
сен 15 13:17:09 wirenboard-AQSPJYFN ModemManager[383]: <warn> [modem0] couldn't load supported modes: Couldn't retrieve supported modes
сен 15 13:17:12 wirenboard-AQSPJYFN ModemManager[383]: <warn> [modem0/sim0] couldn't load list of emergency numbers: Failed to parse CRSM query result '+CRSM: 105,129'
сен 15 13:17:13 wirenboard-AQSPJYFN ModemManager[383]: <warn> [modem0/sim0] couldn't load GID1: Memory failure
сен 15 13:17:13 wirenboard-AQSPJYFN ModemManager[383]: <warn> [modem0/sim0] couldn't load GID2: Memory failure
сен 15 13:17:13 wirenboard-AQSPJYFN ModemManager[383]: <warn> [modem0/sim0] couldn't load list of emergency numbers: Failed to parse CRSM query result '+CRSM: 105,129'
сен 15 13:17:14 wirenboard-AQSPJYFN ModemManager[383]: <info> [modem0] state changed (unknown -> disabled)
сен 15 13:17:14 wirenboard-AQSPJYFN ModemManager[383]: <info> [modem0] state changed (disabled -> enabling)
сен 15 13:17:14 wirenboard-AQSPJYFN ModemManager[383]: <info> [modem0] power state updated: on
сен 15 13:17:15 wirenboard-AQSPJYFN ModemManager[383]: <info> [modem0] 3GPP registration state changed (unknown -> idle)
сен 15 13:17:17 wirenboard-AQSPJYFN ModemManager[383]: <info> [modem0] state changed (enabling -> enabled)
сен 15 13:17:56 wirenboard-AQSPJYFN ModemManager[383]: <info> [modem0] 3GPP registration state changed (idle -> denied)
-- Boot 401863d93f3b4d19878fa5dd158ce81f --
