Здравствуйте! Подключаюсь к witenboard 6 через ssh , все подключается , но когда открываю веб интерфейс выходит ошибка сверху справа не удается подключиться к wirenboard
systemctl status mosquitto ввожу эту команду выходит это:
root@wirenboard-ALMVD27Q:~# systemctl status mosquitto
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-06-18 15:04:19 UTC; 17min ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 16320 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 16329 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 16336 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 16340 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 16348 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 16348 (code=exited, status=1/FAILURE)
CPU: 139ms
Jun 18 15:04:18 wirenboard-ALMVD27Q systemd[1]: mosquitto.service: Failed with result ‘exit-code’.
Jun 18 15:04:18 wirenboard-ALMVD27Q systemd[1]: Failed to start Mosquitto MQTT Broker.
Jun 18 15:04:19 wirenboard-ALMVD27Q systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 148.
Jun 18 15:04:19 wirenboard-ALMVD27Q systemd[1]: Stopped Mosquitto MQTT Broker.
Jun 18 15:04:19 wirenboard-ALMVD27Q systemd[1]: mosquitto.service: Start request repeated too quickly.
Jun 18 15:04:19 wirenboard-ALMVD27Q systemd[1]: mosquitto.service: Failed with result ‘exit-code’.
Jun 18 15:04:19 wirenboard-ALMVD27Q systemd[1]: Failed to start Mosquitto MQTT Broker.
Подскажите, как исправить ?
