Не могу прошить wb 6.9A/1G3
флэшка проверена на wb 6.9.1U/1G. там процесс прошивки стартует.
на этом нет… пробовал прошивки:
http://fw-releases.wirenboard.com/fit_image/testing/67/202211080929_testing_bullseye_wb67.fit
http://fw-releases.wirenboard.com/fit_image/stable/67/202211111113_wb-2207_stretch_wb67.fit
U-Boot 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38 +0000)
CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 36C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
1 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
  Device 0: Vendor:          Rev: PMAP Prod: USB DISK 2.0
            Type: Removable Hard Disk
            Capacity: 7644.0 MB = 7.4 GB (15654912 x 512)
reading wb6_update.fit
** Unable to read file wb6_update.fit **
reading wb6_update_FACTORYRESET.fit
1 bytes read in 19 ms (0 Bytes/s)
# Detected USB flash drive with update file
# Filename: wb6_update_FACTORYRESET.fit
# Press a FW key if you want to update firmware from this file
# or wait 3 seconds to boot normally.
USB update procedure start
Checking if ubootenv part is present
## Loading FIT header to 0x82000000 ...
## Loading FIT strings to 0x82000028 ...
## Loading FIT struct to 0x82000100 ...
FAT: Misaligned buffer address (820010c8)
   Skip 7928976 bytes of data
FAT: Misaligned buffer address (8200042c)
   Skip 46505 bytes of data
FAT: Misaligned buffer address (82000e74)
   Skip 4917 bytes of data
   Skip 171666401 bytes of data
** wb6_update_FACTORYRESET.fit shorter than offset + len **
Can't find subimage 'ubootenv'
Extracting kernel
7945616 bytes read in 4901 ms (1.5 MiB/s)
     Description:  Update kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x82000300
     Data Size:    7928976 Bytes = 7.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   47f6419e0d5d8326c41b16761827dc3d746fec78
## Verifying ... sha1
U-Boot SPL 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38)
DRAM init ok, rows:16, ncs:1, size: 1024MB
.p0_mpdgctrl0   = 0x01100110
.p0_mpdgctrl1   = 0x0e3f0e3f
.p0_mprddlctl   = 0x3f3f3d40
.p0_mpwrdlctl   = 0x3f3f3734
.p0_mpwldectrl0 = 0x000b000d
.p0_mpwldectrl1 = 0x000e000e
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
CPU:   Industrial temperature grade (-40C to 105C) at 41C
Какой релиз ПО установлен?
Обновите предварительно до актуального, с обновлением загрузчика, стандартным способом с помощью apt.
А для чего собираетесь использовать facctory reset?
спасибо. после обновления apt прошилось… только очень много времени заняло
А, собственно зачем делать factory reset вообще?
