Это консоль загрузчика, через нее доступ куда-либо внутри ОС получить не удастся точно.
Дождитесь загрузки ОС.
Вот последнее что выдаёт лог загрузки, но консоль не становится доступной сколько не жди.
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down...
Starting Bluetooth service...
[ OK ] Started D-Bus System Message Bus.
[ 18.170569] RTL871X: nolinked power save enter
[ OK ] Started watch config files.
Starting Initialize Wiren Board Device Tree overlays...
[ OK ] Started Cgroup management daemon.
Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
Starting Login Service...
[ 40.749849] new mount options do not match the existing superblock, will be ignored
Starting Restore local date from Wiren Board GSM RTC...
[ OK ] Started Node-RED graphical event wiring tool.
[ OK ] Started Regular background program processing daemon.
[ OK ] Started System Logging Service.
[ OK ] Started initialize filesystems at first boot.
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ OK ] Started Mosquitto MQTT v3.1/v3.1.1 Broker.
[FAILED] Failed to start Initialize Wiren Board Device Tree overlays.
See 'systemctl status wb-hwconf-manager.service' for details.
[ OK ] Started Restore local date from Wiren Board GSM RTC.
[FAILED] Failed to start Login Service.
See 'systemctl status systemd-logind.service' for details.
[*** ] A start job is running for Bluetooth service (1min 9s / 1min 33s)[ 80.853402] RTL871X: RTW_ADAPTIVITY_EN_
[ 80.853425] AUTO, chplan:0x20, Regulation:3,3
[ 80.861712] RTL871X: RTW_ADAPTIVITY_MODE_
[ 80.861718] NORMAL
[ *** ] A start job is running for Bluetooth service (1min 9s / 1min 33s)[ 81.782857] RTL871X: nolinked power save leave
[ *** ] A start job is running for Bluetooth service (1min 12s / 1min 33s)[ 84.117783] RTL871X: nolinked power save enter
[*** ] A start job is running for Bluetooth service (1min 18s / 1min 33s)[ 89.882906] RTL871X: RTW_ADAPTIVITY_EN_
[ 89.882929] AUTO, chplan:0x20, Regulation:3,3
[ 89.891228] RTL871X: RTW_ADAPTIVITY_MODE_
[ 89.891232] NORMAL
[* ] A start job is running for Bluetooth service (1min 18s / 1min 33s)[ 90.843112] RTL871X: nolinked power save leave
[ **] A start job is running for Bluetooth service (1min 21s / 1min 33s)[ 93.159794] RTL871X: nolinked power save enter
[ **] A start job is running for Bluetooth service (1min 27s / 1min 33s)[ 98.933031] RTL871X: RTW_ADAPTIVITY_EN_
[ 98.933055] AUTO, chplan:0x20, Regulation:3,3
[ 98.941352] RTL871X: RTW_ADAPTIVITY_MODE_
[ 98.941356] NORMAL
[ *** ] A start job is running for Bluetooth service (1min 27s / 1min 33s)[ 99.892482] RTL871X: nolinked power save leave
[*** ] A start job is running for Bluetooth service (1min 30s / 1min 33s)[ 102.203424] RTL871X: nolinked power save enter
[ *** ] A start job is running for Bluetooth service (1min 36s / 3min 3s)[ 108.229020] RTL871X: RTW_ADAPTIVITY_EN_
[ 108.229044] AUTO, chplan:0x20, Regulation:3,3
[ 108.237274] RTL871X: RTW_ADAPTIVITY_MODE_
[ 108.237278] NORMAL
[ *] A start job is running for Bluetooth service (1min 37s / 3min 3s)[ 109.212987] RTL871X: nolinked power save leave
[** ] A start job is running for Bluetooth service (1min 39s / 3min 3s)[ 111.534791] RTL871X: nolinked power save enter
[** ] A start job is running for Bluetooth service (1min 45s / 3min 3s)[ 117.323152] RTL871X: RTW_ADAPTIVITY_EN_
[ 117.323175] AUTO, chplan:0x20, Regulation:3,3
[ 117.331458] RTL871X: RTW_ADAPTIVITY_MODE_
[ 117.331462] NORMAL
[*** ] A start job is running for Bluetooth service (1min 45s / 3min 3s)[ 117.902307] RTL871X: nolinked power save leave
[** ] A start job is running for Bluetooth service (1min 49s / 3min 3s)[ 122.009399] RTL871X: nolinked power save enter
[ *** ] A start job is running for Bluetooth service (1min 54s / 3min 3s)[ 126.455030] RTL871X: RTW_ADAPTIVITY_EN_
[ 126.455055] AUTO, chplan:0x20, Regulation:3,3
[ 126.463336] RTL871X: RTW_ADAPTIVITY_MODE_
[ 126.463341] NORMAL
[*** ] A start job is running for Bluetooth service (1min 54s / 3min 3s)[ 127.002983] RTL871X: nolinked power save leave
[ ***] A start job is running for Bluetooth service (1min 57s / 3min 3s)[ 129.307156] RTL871X: nolinked power save enter
[ *] A start job is running for Bluetooth service (2min 3s / 3min 3s)[ 135.183264] RTL871X: RTW_ADAPTIVITY_EN_
[ 135.183285] AUTO, chplan:0x20, Regulation:3,3
[ 135.191559] RTL871X: RTW_ADAPTIVITY_MODE_
[ 135.191563] NORMAL
[ **] A start job is running for Bluetooth service (2min 3s / 3min 3s)[ 135.722233] RTL871X: nolinked power save leave
[* ] A start job is running for Bluetooth service (2min 6s / 3min 3s)[ 138.014397] RTL871X: nolinked power save enter
[*** ] A start job is running for Bluetooth service (2min 12s / 3min 3s)[ 143.811021] RTL871X: RTW_ADAPTIVITY_EN_
[ 143.811045] AUTO, chplan:0x20, Regulation:3,3
[ 143.819321] RTL871X: RTW_ADAPTIVITY_MODE_
[ 143.819325] NORMAL
[ *** ] A start job is running for Bluetooth service (2min 12s / 3min 3s)[ 144.342227] RTL871X: nolinked power save leave
[ **] A start job is running for Bluetooth service (2min 13s / 3min 3s)[ 145.387586] SMSC LAN8710/LAN8720 20b4000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=20b4000.ethernet-1:00, irq=POLL)
[ ***] A start job is running for Bluetooth service (2min 14s / 3min 3s)[ 146.644272] RTL871X: nolinked power save enter
[ *** ] A start job is running for Bluetooth service (2min 20s / 3min 3s)[ 152.395655] RTL871X: RTW_ADAPTIVITY_EN_
[ 152.395686] AUTO, chplan:0x20, Regulation:3,3
[ 152.403994] RTL871X: RTW_ADAPTIVITY_MODE_
[ 152.404002] NORMAL
[*** ] A start job is running for Bluetooth service (2min 21s / 3min 3s)[ 152.932227] RTL871X: nolinked power save leave
[ *** ] A start job is running for Bluetooth service (2min 23s / 3min 3s)[ 155.234899] RTL871X: nolinked power save enter
[ **] A start job is running for Bluetooth service (2min 29s / 3min 3s)[ 160.985521] RTL871X: RTW_ADAPTIVITY_EN_
[ 160.985547] AUTO, chplan:0x20, Regulation:3,3
[ 160.993837] RTL871X: RTW_ADAPTIVITY_MODE_
[ 160.993843] NORMAL
[ *] A start job is running for Bluetooth service (2min 29s / 3min 3s)[ 161.522548] RTL871X: nolinked power save leave
[ *** ] A start job is running for Bluetooth service (2min 33s / 3min 3s)[ 165.609274] RTL871X: nolinked power save enter
[** ] A start job is running for Bluetooth service (2min 37s / 3min 3s)[ 169.585409] RTL871X: RTW_ADAPTIVITY_EN_
[ 169.585440] AUTO, chplan:0x20, Regulation:3,3
[ 169.593752] RTL871X: RTW_ADAPTIVITY_MODE_
[ 169.593760] NORMAL
[*** ] A start job is running for Bluetooth service (2min 38s / 3min 3s)[ 170.132113] RTL871X: nolinked power save leave
[ **] A start job is running for Bluetooth service (2min 40s / 3min 3s)[ 172.425159] RTL871X: nolinked power save enter
[ *** ] A start job is running for Bluetooth service (2min 46s / 3min 3s)[ 178.185782] RTL871X: RTW_ADAPTIVITY_EN_
[ 178.185813] AUTO, chplan:0x20, Regulation:3,3
[ 178.194124] RTL871X: RTW_ADAPTIVITY_MODE_
[ 178.194131] NORMAL
[ *** ] A start job is running for Bluetooth service (2min 46s / 3min 3s)[ 178.732099] RTL871X: nolinked power save leave
[ *** ] A start job is running for Bluetooth service (2min 49s / 3min 3s)[ 181.025396] RTL871X: nolinked power save enter
[ ***] A start job is running for Bluetooth service (2min 55s / 3min 3s)[ 186.785534] RTL871X: RTW_ADAPTIVITY_EN_
[ 186.785564] AUTO, chplan:0x20, Regulation:3,3
[ 186.793876] RTL871X: RTW_ADAPTIVITY_MODE_
[ 186.793883] NORMAL
[ **] A start job is running for Bluetooth service (2min 55s / 3min 3s)[ 187.332226] RTL871X: nolinked power save leave
[*** ] A start job is running for Bluetooth service (2min 57s / 3min 3s)[ 189.622271] RTL871X: nolinked power save enter
[* ] A start job is running for Bluetooth service (3min 3s / 3min 3s)[ 195.380281] RTL871X: RTW_ADAPTIVITY_EN_
[ 195.380312] AUTO, chplan:0x20, Regulation:3,3
[ 195.388617] RTL871X: RTW_ADAPTIVITY_MODE_
[ 195.388625] NORMAL
[FAILED] Failed to start Bluetooth service.
See 'systemctl status bluetooth.service' for details.
[ 195.842110] RTL871X: nolinked power save leave
[ 199.929272] RTL871X: nolinked power save enter
[ 204.129152] RTL871X: RTW_ADAPTIVITY_EN_
[ 204.129175] AUTO, chplan:0x20, Regulation:3,3
[ 204.137430] RTL871X: RTW_ADAPTIVITY_MODE_
[ 204.137434] NORMAL
[ 204.662235] RTL871X: nolinked power save leave
[ 206.969279] RTL871X: nolinked power save enter
[ 207.247590] SMSC LAN8710/LAN8720 20b4000.ethernet-1:01: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=20b4000.ethernet-1:01, irq=POLL)
[ 209.367772] fec 20b4000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
[ 209.387471] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 212.899272] RTL871X: RTW_ADAPTIVITY_EN_
[ 212.899295] AUTO, chplan:0x20, Regulation:3,3
[ 212.907583] RTL871X: RTW_ADAPTIVITY_MODE_
[ 212.907587] NORMAL
[ 213.432360] RTL871X: nolinked power save leave
[ 217.529399] RTL871X: nolinked power save enter
[ 221.679162] RTL871X: RTW_ADAPTIVITY_EN_
[ 221.679185] AUTO, chplan:0x20, Regulation:3,3
[ 221.687453] RTL871X: RTW_ADAPTIVITY_MODE_
[ 221.687457] NORMAL
[ 222.212103] RTL871X: nolinked power save leave
[ 226.329395] RTL871X: nolinked power save enter
[ 230.479022] RTL871X: RTW_ADAPTIVITY_EN_
[ 230.479044] AUTO, chplan:0x20, Regulation:3,3
[ 230.487260] RTL871X: RTW_ADAPTIVITY_MODE_
[ 230.487263] NORMAL
[ 231.012236] RTL871X: nolinked power save leave
[ 233.308524] RTL871X: nolinked power save enter
[ 239.254406] RTL871X: RTW_ADAPTIVITY_EN_
[ 239.254429] AUTO, chplan:0x20, Regulation:3,3
[ 239.262687] RTL871X: RTW_ADAPTIVITY_MODE_
[ 239.262691] NORMAL
[ 239.792100] RTL871X: nolinked power save leave
[ 242.088273] RTL871X: nolinked power save enter
[ 248.029272] RTL871X: RTW_ADAPTIVITY_EN_
[ 248.029296] AUTO, chplan:0x20, Regulation:3,3
[ 248.037548] RTL871X: RTW_ADAPTIVITY_MODE_
[ 248.037552] NORMAL
[ 248.562223] RTL871X: nolinked power save leave
[ 252.649282] RTL871X: nolinked power save enter
[ 256.799142] RTL871X: RTW_ADAPTIVITY_EN_
[ 256.799166] AUTO, chplan:0x20, Regulation:3,3
[ 256.807445] RTL871X: RTW_ADAPTIVITY_MODE_
[ 256.807449] NORMAL
[ 257.332227] RTL871X: nolinked power save leave
[ 259.624522] RTL871X: nolinked power save enter
[ 265.574270] RTL871X: RTW_ADAPTIVITY_EN_
[ 265.574294] AUTO, chplan:0x20, Regulation:3,3
[ 265.582559] RTL871X: RTW_ADAPTIVITY_MODE_
[ 265.582563] NORMAL
[ 266.112288] RTL871X: nolinked power save leave
[ 268.404147] RTL871X: nolinked power save enter
[ 274.349144] RTL871X: RTW_ADAPTIVITY_EN_
[ 274.349168] AUTO, chplan:0x20, Regulation:3,3
[ 274.357433] RTL871X: RTW_ADAPTIVITY_MODE_
[ 274.357437] NORMAL
[ 274.882233] RTL871X: nolinked power save leave
[ 278.969275] RTL871X: nolinked power save enter
[ 283.119645] RTL871X: RTW_ADAPTIVITY_EN_
[ 283.119667] AUTO, chplan:0x20, Regulation:3,3
[ 283.127949] RTL871X: RTW_ADAPTIVITY_MODE_
[ 283.127953] NORMAL
[ 283.652226] RTL871X: nolinked power save leave
[ 285.945270] RTL871X: nolinked power save enter
[ 291.899146] RTL871X: RTW_ADAPTIVITY_EN_
[ 291.899169] AUTO, chplan:0x20, Regulation:3,3
[ 291.907432] RTL871X: RTW_ADAPTIVITY_MODE_
[ 291.907436] NORMAL
[ 292.432225] RTL871X: nolinked power save leave
[ 294.722284] RTL871X: nolinked power save enter
[ 300.669021] RTL871X: RTW_ADAPTIVITY_EN_
[ 300.669045] AUTO, chplan:0x20, Regulation:3,3
[ 300.677266] RTL871X: RTW_ADAPTIVITY_MODE_
[ 300.677270] NORMAL
[ 301.202227] RTL871X: nolinked power save leave
Может можно как то запуститься с флешки каким нибудь образом и получить доступ к файловой системе?
Пробовал вставлять флэшку с wb6_update.fit, отформатированной по инструкции, на нее не реагирует как на скришотах в мануале по обновлению и прошивке
Консоль как раз и доступна, разве нельзя войти?
Нет, если не удастся выполнить команды из консоли Debug порта - проще сделать Factory reset.
[/quote]
-это последнее на чем останавливается лог загрузки
и дальше ни на что не реалигует, курсор на одном месте стоит
реагирует на usb флешку только выдает логи о том что вставлена или извлечена
[ 680.798939] usb 1-1: USB disconnect, device number 2
[ 837.017435] usb 2-1.2: new high-speed USB device number 4 using ci_hdrc
[ 837.191925] usb 2-1.2: New USB device found, idVendor=24a9, idProduct=205a, bcdDevice= 2.00
[ 837.200350] usb 2-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 837.207729] usb 2-1.2: Product: Silicon-Power
[ 837.212102] usb 2-1.2: Manufacturer: UFD_3.0
[ 837.216390] usb 2-1.2: SerialNumber: 2103390782200459
[ 837.261840] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[ 837.292537] scsi host0: usb-storage 2-1.2:1.0
[ 838.328635] scsi 0:0:0:0: Direct-Access UFD_3.0 Silicon-Power 0000 PQ: 0 ANSI: 4
[ 838.355601] sd 0:0:0:0: [sda] 60743681 512-byte logical blocks: (31.1 GB/29.0 GiB)
[ 838.385383] sd 0:0:0:0: [sda] Write Protect is off
[ 838.417862] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 838.452882] sda: sda1
[ 838.464834] sd 0:0:0:0: [sda] Attached SCSI removable disk
Еще дело в том что если я сделаю хард резет ему то вся память полностью очистится. А у нас в исполнении стенда он куплен, чемодан. Я смогу ему вернуть всю конфигурацию под стенд? или все ручками прописывать придется? или у Вас есть стандартные бэкапы какие нибудь для восстановления стендов?
Да, конечно, предусмотрено: Инсталляция в чемодане WB-DEMO-KIT v.3 — Wiren Board
Если не меняли адреса и настройки связи Modbus устройств - восстановится в исходном виде.
Спасибо. Буду пытаться менять флэшку…
На всех флеш которые пробовал, не запускается. На всех один и тот же лог.
U-Boot 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 52C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
1 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
324 bytes read in 69 ms (3.9 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
5899176 bytes read in 392 ms (14.4 MiB/s)
…на том месте где WB должен увидеть флэш на 1 usb.
Такое чувство что он просто usb не видит при загрузке, хотя после загрузки ядра видит нормально и отображает в логах что она смонтирована…
это после логов загрузки ядра-
[ 241.207615] usb 2-1.2: new high-speed USB device number 4 using ci_hdrc
[ 241.384857] usb 2-1.2: New USB device found, idVendor=13fe, idProduct=4500, bcdDevice= 1.00
[ 241.393280] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 241.400642] usb 2-1.2: Product: USB DISK 2.0
[ 241.404919] usb 2-1.2: SerialNumber: 6A511710
[ 241.441879] usb-storage 2-1.2:1.0: USB Mass Storage device detected
на одной из флэш
такой лог, немного отличается но с нее не грузится, что не пробовал: fat32, все размеры кластеров, названия файлов итд и тп
CPU: Industrial temperature grade (-40C to 105C) at 55C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
Точно работающий способ создать флешку и пример вывода тут: Не подключается к WEB UI и SSH - #14 от пользователя BrainRoot
Устройств хранения не обнаружено.
И да, уже после загрузки ядра - может вполне распознаваться, но загрузчик менее универсален.
Здравствуйте! Получилось ли обновить прошивку контроллера?
Здравствуйте. Подошла типичная старая флешка на 2гб. Спасибо.
