Доброго вечера.
WirenBoard 6. Работал и работал себе, что то подвис, перезапустили черным выключателем… перестал запускаться. В Debug консоли вот так:
U-Boot 2017.03-1.1.0-gaa233c0fa3 (Jun 09 2020 - 19:28:23 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 53C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@02188000
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
323 bytes read in 64 ms (4.9 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
5906504 bytes read in 387 ms (14.6 MiB/s)
MMC read: dev # 0, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard670
46734 bytes read in 233 ms (195.3 KiB/s)
485 bytes read in 148 ms (2.9 KiB/s)
Applying DT overlay wb6-nogsm
597 bytes read in 141 ms (3.9 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 170 ms (2 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 109 ms (2.9 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 122 ms (2 KiB/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x5a2048 ]
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef32000, end 9ef54fff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.35-wb120+wb101 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 10.2.1-62
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Wiren Board rev. 6.7.0 (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 rootwait ro
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 489392K/524288K available (8192K kernel code, 714K rwdata, 2652K rodata, 1024K init, 2)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x234/0x3dc with crng_init=0
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000017] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000055] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002756] Console: colour dummy device 80x30
[ 0.002818] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj)
[ 0.002854] pid_max: default: 32768 minimum: 301
[ 0.003258] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.003293] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.004853] CPU: Testing write buffer coherency: ok
[ 0.005933] Setting up static identity map for 0x80100000 - 0x80100078
[ 0.006810] devtmpfs: initialized
[ 0.024174] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.024700] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 s
[ 0.024746] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.026113] pinctrl core: initialized pinctrl subsystem
[ 0.028140] NET: Registered protocol family 16
[ 0.030348] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.032387] thermal_sys: Registered thermal governor 'step_wise'
[ 0.032669] cpuidle: using governor menu
[ 0.213830] vdd1p1: supplied by regulator-dummy
[ 0.225473] vdd3p0: supplied by regulator-dummy
[ 0.237157] cpu: supplied by regulator-dummy
[ 0.248850] vddsoc: supplied by regulator-dummy
[ 0.582404] No ATAGs?
[ 0.582464] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.582485] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.583154] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regmap' already present!
[ 0.583841] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[ 0.585336] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[ 0.585374] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[ 0.625637] mxs-dma 1804000.dma-apbh: initialized
[ 0.630921] SCSI subsystem initialized
[ 0.631433] usbcore: registered new interface driver usbfs
[ 0.631555] usbcore: registered new interface driver hub
[ 0.631670] usbcore: registered new device driver usb
[ 0.632485] gpio-48 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.632610] gpio-49 (i2c_rtc): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.633661] i2c-gpio i2c_rtc: using lines 48 (SDA) and 49 (SCL)
[ 0.634453] gpio-76 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.634582] gpio-67 (i2c_eeprom1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.635175] i2c-gpio i2c_eeprom1: using lines 76 (SDA) and 67 (SCL)
[ 0.635879] gpio-70 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.636003] gpio-71 (i2c_eeprom2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.636601] i2c-gpio i2c_eeprom2: using lines 70 (SDA) and 71 (SCL)
[ 0.638146] gpio-30 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 0.638501] i2c i2c-1: IMX I2C adapter registered
[ 0.639216] mc: Linux media interface: v0.10
[ 0.639337] videodev: Linux video capture interface: v2.00
[ 0.639478] pps_core: LinuxPPS API ver. 1 registered
[ 0.639499] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.639556] PTP clock support registered
[ 0.640234] Advanced Linux Sound Architecture Driver Initialized.
[ 0.642235] clocksource: Switched to clocksource mxc_timer1
[ 0.660077] NET: Registered protocol family 2
[ 0.661210] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.661320] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.661428] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.661533] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.661729] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.661783] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.662111] NET: Registered protocol family 1
[ 0.663205] RPC: Registered named UNIX socket transport module.
[ 0.663243] RPC: Registered udp transport module.
[ 0.663260] RPC: Registered tcp transport module.
[ 0.663274] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.664364] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.667221] Initialise system trusted keyrings
[ 0.667661] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.679361] NFS: Registering the id_resolver key type
[ 0.679440] Key type id_resolver registered
[ 0.679457] Key type id_legacy registered
[ 0.680368] Key type asymmetric registered
[ 0.680402] Asymmetric key parser 'x509' registered
[ 0.680502] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.680524] io scheduler mq-deadline registered
[ 0.680544] io scheduler kyber registered
[ 0.692525] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[ 0.692574] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[ 0.696489] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a IMX
[ 1.360063] printk: console [ttymxc0] enabled
[ 1.366544] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[ 1.410348] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[ 1.417777] random: fast init done
[ 1.421725] random: crng init done
[ 1.461221] brd: module loaded
[ 1.479510] loop: module loaded
[ 1.483097] at24 5-0050: supply vcc not found, using dummy regulator
[ 1.494573] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.501547] at24 6-0050: supply vcc not found, using dummy regulator
[ 1.512971] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.525429] libphy: Fixed MDIO Bus: probed
[ 1.532522] pps pps0: new PPS source ptp0
[ 1.572007] libphy: fec_enet_mii_bus: probed
[ 1.577487] fec 20b4000.ethernet ethFEC0: registered PHC device 0
[ 1.702925] pps pps1: new PPS source ptp1
[ 1.709543] libphy: fec_enet_mii_bus: probed
[ 1.718282] fec 2188000.ethernet ethFEC1: registered PHC device 1
[ 1.725365] PPP generic driver version 2.4.2
[ 1.730088] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.736730] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.742507] usbcore: registered new interface driver usb-storage
[ 1.748765] usbcore: registered new interface driver usbserial_generic
[ 1.755433] usbserial: USB Serial support registered for generic
[ 1.804606] rtc rtc0: invalid alarm value: 2024-03-21T32:32:00
[ 1.810874] rtc-pcf8563 4-0051: registered as rtc0
[ 1.827716] rtc-pcf8563 4-0051: setting system clock to 2024-03-23T14:21:30 UTC (1711203690)
[ 1.846062] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.852583] i2c /dev entries driver
[ 1.859334] lm75 4-0048: supply vs not found, using dummy regulator
[ 1.870971] lm75 4-0048: hwmon0: sensor 'lm75b'
[ 1.991043] sdhci: Secure Digital Host Controller Interface driver
[ 1.997325] sdhci: Copyright(c) Pierre Ossman
[ 2.001696] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.015719] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.023576] usbcore: registered new interface driver usbhid
[ 2.029175] usbhid: USB HID core driver
[ 2.045470] NET: Registered protocol family 10
[ 2.050044] mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[ 2.059971] Segment Routing with IPv6
[ 2.064491] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.072496] NET: Registered protocol family 17
[ 2.077257] Key type dns_resolver registered
[ 2.085949] registered taskstats version 1
[ 2.090125] Loading compiled-in X.509 certificates
[ 2.114843] imx_thermal 20c8000.anatop:tempmon: Industrial CPU temperature grade - max:105C critical:100C C
[ 2.126676] of_cfs_init
[ 2.129271] of_cfs_init: OK
[ 2.137027] ALSA device list:
[ 2.140160] No soundcards found.
[ 2.144025] Waiting for root device /dev/mmcblk0p3...
[ 2.152286] mmc0: new DDR MMC card at address 0001
[ 2.157974] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[ 2.162999] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[ 2.169299] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[ 2.175628] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB, chardev (245:0)
[ 2.186220] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.209985] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[ 2.217391] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[ 3.350596] EXT4-fs (mmcblk0p3): recovery complete
[ 3.361697] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 3.369985] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 3.378557] devtmpfs: mounted
[ 3.383257] Freeing unused kernel memory: 1024K
[ 3.388066] Run /sbin/init as init process
[ 3.747922] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +S)
[ 3.766759] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 9 (stretch)!
[ 3.817176] systemd[1]: Set hostname to <wirenboard-AYLDXRDD>.
[ 4.393141] systemd[1]: Configuration file /etc/systemd/system/yandex2mqtt.service is marked executable. P.
[ 4.408086] systemd[1]: Configuration file /etc/systemd/system/yandex2mqtt.service is marked world-writabl.
[ 4.456394] systemd[1]: [/lib/systemd/system/wb-mqtt-w1.service:10] Unknown lvalue 'StartLimitIntervalSec''
[ 4.544016] systemd[1]: ModemManager.service: Cannot add dependency job, ignoring: Unit ModemManager.servi.
[ 4.564655] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.604510] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.647589] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ OK ] Created slice system-systemd\x2dfsck.slice.
Mounting POSIX Message Queue File System...
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
Mounting Debug File System...
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Listening on Journal Socket.
Starting Load Kernel Modules...
Starting Create list of required st???ce nodes for the current kernel...
Mounting /sys/kernel/config...
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on fsck to fsckd communication Socket.
Starting File System Check on Root Device...
[ OK ] Listening on udev Kernel Socket.
Starting Journal Service...
[ OK ] Reached target Remote File Systems.
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted /sys/kernel/config.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Create list of required sta???vice nodes for the current kernel.
[ OK ] Started File System Check on Root Device.
[ OK ] Started Journal Service.
[ OK ] Started File System Check Daemon to report status.
Starting Remount Root and Kernel File Systems...
Starting Create Static D[ 5.722918] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
evice Nodes in /dev...
Starting Apply Kernel Variables...
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
Starting Load/Save Random Seed...
Starting udev Coldplug all Devices...
Starting prepare partitions at first boot...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started prepare partitions at first boot.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Started udev [ 7.956542] Driver for 1-wire Dallas network protocol.
[ 8.040253] gpio-68 (onewire_w1): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 8.077927] gpio-11 (onewire_w2): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ OK ] Found device /dev/ttymxc0.
[ 8.495034] fec 20b4000.ethernet eth1: renamed from ethFEC0
[ 8.908324] fec 2188000.ethernet eth0: renamed from ethFEC1
[ 8.972213] imx_usb 2184000.usb: No over current polarity defined
[ 9.063955] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 9.068912] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 9.202337] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 9.235919] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 9.244304] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.251534] usb usb1: Product: EHCI Host Controller
[ 9.256453] usb usb1: Manufacturer: Linux 5.10.35-wb120+wb101 ehci_hcd
[ 9.263003] usb usb1: SerialNumber: ci_hdrc.0
[ 9.520299] hub 1-0:1.0: USB hub found
[ 9.576748] hub 1-0:1.0: 1 port detected
[ 9.632390] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 9.637366] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 9.792343] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 9.842537] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 9.850829] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.858124] usb usb2: Product: EHCI Host Controller
[ 9.863030] usb usb2: Manufacturer: Linux 5.10.35-wb120+wb101 ehci_hcd
[ 9.869577] usb usb2: SerialNumber: ci_hdrc.1
[ 9.992424] usb usb1-port1: over-current condition
[ 10.172719] hub 2-0:1.0: USB hub found
[ 10.211879] hub 2-0:1.0: 1 port detected
[ OK ] Found device /dev/mmcblk0p6.
[ OK ] Found device /dev/mmcblk0p5.
[ 10.602375] usb 2-1: new high-speed USB device number 2 using ci_hdrc
Activating swap /dev/mmcblk0p5...
[ 10.824305] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 10.832574] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Starting File System Check on /dev/mmcblk0p6...
[ 10.875392] Adding 262140k swap on /dev/mmcblk0p5. Priority:-2 extents:1 across:262140k SS
[ 10.894092] hub 2-1:1.0: USB hub found
[ 10.912410] hub 2-1:1.0: 4 ports detected
[ OK ] Activated swap /dev/mmcblk0p5.
[ OK ] Reached target Swap.
[ 11.252366] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 11.404339] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720, bcdDevice= 2.00
[ 11.412805] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 11.420172] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 11.425208] usb 2-1.1: Manufacturer: Realtek
[ 11.429494] usb 2-1.1: SerialNumber: 00e04c000001
[ 11.700197] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ OK ] Listening on [ 11.711077] Bluetooth: Core ver 2.22
Load/Save RF Kill Switch Status /[ 11.717279] NET: Registered protocol family 31
dev/rfkill Watch.
[ 11.722357] Bluetooth: HCI device and connection manager initialized
[ 11.742685] Bluetooth: HCI socket layer initialized
[ 11.756284] Bluetooth: L2CAP socket layer initialized
[ 11.764466] Bluetooth: SCO socket layer initialized
[ 11.859106] usbcore: registered new interface driver btusb
[ 11.873057] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 11.887255] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 11.893365] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
Starting Load/Save RF Ki[ 11.903406] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
ll Switch Status...
[ 11.911423] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 11.922351] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 11.982799] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 12.024795] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 12.092329] cfg80211: failed to load regulatory.db
[ OK ] Started Load/Save RF Kill Switch Status.
[ 12.742373] RTL871X: module init start
[ 12.746186] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[ 12.753197] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 12.762517] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 12.960285] RTL871X: rtw_ndev_init(wlan0)
[ 12.982422] RTL871X: rtw_ndev_init(wlan1)
[ 12.995016] usbcore: registered new interface driver rtl8723bu
[ 13.000873] RTL871X: module init ret=0
[ 13.114529] usbcore: registered new interface driver rtl8xxxu
[ OK ] Started File System Check on /dev/mmcblk0p6.
Mounting /mnt/data...
[ OK ] Found device 802.11n_WLAN_Adapter.
[ 13.620094] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Mounted /mnt/data.
Mounting /var/log...
[ OK ] Mounted /var/log.
[ OK ] Reached target Local File Systems.
Starting prepare mounts and symlinks to config files...
Starting Flush Journal to Persistent Storage...
[ 13.957429] systemd-journald[108]: Received request to flush runtime journal from PID 1
[ 14.000521] systemd-journald[108]: File /var/log/journal/74f09575e0cb77ba5ea7e9286086ac7a/system.journal c.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started prepare mounts and symlinks to config files.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Run certbot twice daily.
[ OK ] Started Monitor directories with device templates for wb-mqtt-serial.
[ OK ] Reached target Paths.
[ OK ] Listening on KNX Daemon (socket).
[ OK ] Reached target Sockets.
[ OK ] Started Daily apt download activities.
[ OK ] Reached target Basic System.
[ OK ] Started watch config files.
[ OK ] Started Cgroup management daemon.
Starting initialize filesystems at first boot...
Starting Restore /etc/resolv.conf i???fore the ppp link was shut down...
[ 17.424579] new mount options do not match the existing superblock, will be ignored
Starting Login Service...
[ OK ] Started D-Bus System Message Bus.
Starting System Logging Service...
[ OK ] Started Regular background program processing daemon.
Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Started Generates wb-mqtt-serial UI schema for wb-mqtt-confed.
Starting Bluetooth service...
Starting Initialize Wiren Board Device Tree overlays...
Starting Restore local date from Wiren Board GSM RTC...
[ OK ] Started System Logging Service.
[ OK ] Started Restore /etc/resolv.conf if???before the ppp link was shut down.
[ 18.655242] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.660580] Bluetooth: BNEP filters: protocol multicast
[ 18.735374] Bluetooth: BNEP socket layer initialized
[ OK ] Started Bluetooth service.
[ OK ] Started Login Service.
[FAILED] Failed to start Hostname Service.
See 'systemctl status systemd-hostnamed.service' for details.
[ OK ] Reached target Bluetooth.
[FAILED] Failed to start Certbot.
See 'systemctl status certbot.service' for details.
[ OK ] Started initialize filesystems at first boot.
[ OK ] Started Mosquitto MQTT v3.1/v3.1.1 Broker.
[ OK ] Started Wiren Board firmware update service.
[ OK ] Started Wiren Board configuration editor backend.
Starting Wiren Board MQTT to OPC UA gateway...
Starting Wiren Board MQTT to Modbus TCP gateway...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Wiren Board MQTT to OPC UA gateway.
[ OK ] Started Restore local date from Wiren Board GSM RTC.
[ OK ] Started Wiren Board MQTT to Modbus TCP gateway.
[ *] A start job is running for Initiali???ree overlays (8min 48s / no limit)
И естественно так до бесконечности вист и мигает красный диод.
Обновиться через флешку не получается… как через Debug стянуть файлы не знаю…
Помогите пжст …
