Невозможно выполнить сброс до заводских настроек через wb6_update_FACTORYRESET.fit
Если файл переименовать в wb6_update.fit то обновление проходит.
Файлы на флешке прекрасно видит.
Что нужно еще сделать, чтобы выполнить полный сброс?
Контроллер 6.8.1
прошивка 2021-09-13T11:21:28.000Z 167.7 MB 202109131119_stable_webupd_wb67.fit
U-Boot 2017.03-1.2.0-gf92dee6f51 (Jun 02 2021 - 13:45:31 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 47C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 1 GiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@02188000
Hit any key to stop autoboot: 0
Writing to MMC(0)... done
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: Generic Rev: 2.00 Prod: Flash-Disk
Type: Removable Hard Disk
Capacity: 509.0 MB = 0.4 GB (1042504 x 512)
reading wb6_update.fit
** Unable to read file wb6_update.fit **
reading wb6_update_FACTORYRESET.fit
1 bytes read in 20 ms (0 Bytes/s)
# Detected USB flash drive with update file
# Filename: wb6_update_FACTORYRESET.fit
# Press a FW key if you want to update firmware from this file
# or wait 3 seconds to boot normally.
U-Boot SPL 2017.03-1.2.0-gf92dee6f51 (Jun 02 2021 - 13:45:31)
DRAM init ok, rows:16, ncs:1, size: 1024MB
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
CPU: Industrial temperature grade (-40C to 105C) at 33C
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
CPU: Industrial temperature grade (-40C to 105C) at 37C
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Warning: Bootlimit (3) exceeded. Using altbootcmd.
Switching to rootfs on partition 2
Saving Environment to MMC...
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
USB update procedure start
Checking if ubootenv part is present
## Loading FIT header to 0x82000000 ...
## Loading FIT strings to 0x82000028 ...
## Loading FIT struct to 0x82000100 ...
FAT: Misaligned buffer address (820010c8)
Skip 7965224 bytes of data
FAT: Misaligned buffer address (82000694)
Skip 46090 bytes of data
FAT: Misaligned buffer address (8200127c)
Skip 4085 bytes of data
Skip 167589837 bytes of data
** wb6_update_FACTORYRESET.fit shorter than offset + len **
Can't find subimage 'ubootenv'
Extracting kernel
