zigbee2mqtt@2.8.0 start
node index.js
Starting Zigbee2MQTT without watchdog.
[2026-04-30 12:23:05] info: z2m: Logging to console, file (filename: log.log)
[2026-04-30 12:23:05] info: z2m: Starting Zigbee2MQTT version 2.8.0 (commit #unknown)
[2026-04-30 12:23:05] info: z2m: Starting zigbee-herdsman (9.0.2)
[2026-04-30 12:23:06] info: zh:zstack:znp: Opening SerialPort with {“path”:“/dev/ttyMOD4”,“baudRate”:115200,“rtscts”:false,“autoOpen”:false}
[2026-04-30 12:23:06] info: zh:zstack:znp: Serialport opened
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: - PAN ID: configured=52243, adapter=48778
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: - Extended PAN ID: configured=00124b0030d56441, adapter=00124b0030d56441
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: - Network Key: configured=e4068e1d75622c80b08e713d62bc9a98, adapter:active=f18a1b24e0d57b7d05d478eddf69ce4d adapter:preconfigured=f18a1b24e0d57b7d05d478eddf69ce4d, adapter:alternate=f18a1b24e0d57b7d05d478eddf69ce4d
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: - Channel List: configured=11, adapter=11
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /mnt/data/root/zigbee2mqtt/data/coordinator_backup.json.
[2026-04-30 12:23:06] error: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
[2026-04-30 12:23:06] error: z2m: Error while starting zigbee-herdsman
[2026-04-30 12:23:06] error: z2m: Failed to start zigbee-herdsman
[2026-04-30 12:23:06] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2026-04-30 12:23:06] error: z2m: Exiting…
[2026-04-30 12:23:06] error: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at ZnpAdapterManager.determineStrategy (/mnt/data/root/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@9.0.2/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:248:23)
at ZnpAdapterManager.start (/mnt/data/root/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@9.0.2/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:61:26)
at ZStackAdapter.start (/mnt/data/root/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@9.0.2/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:147:16)
at Controller.start (/mnt/data/root/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@9.0.2/node_modules/zigbee-herdsman/src/controller/controller.ts:143:29)
at Zigbee.start (/mnt/data/root/zigbee2mqtt/lib/zigbee.ts:70:27)
at Controller.start (/mnt/data/root/zigbee2mqtt/lib/controller.ts:101:13)
at start (/mnt/data/root/zigbee2mqtt/index.js:149:5)
