Не сбрасывается до заводских настроек Wiren Board 6.9
уже была похожая ситуация,Сброс до заводских настроек Wiren Board 6.9, но сейчас нет доступа к веб, пробовал 3 разных флешки результат один и тот же, пробовал ждать минут 5-10, результата нет, u-boot-install-wb результат не поменял:
Спойлер
U-Boot SPL 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0 = 0x01060110
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3e42
.p0_mpwrdlctl = 0x3f3f3834
.p0_mpwldectrl0 = 0x00000000
.p0_mpwldectrl1 = 0x00090009
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 64C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Loading Environment from MMC… OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=2
upgrade_available=0
Environment size: 43/8188 bytes
Resetting to default environment
Net: Could not get PHY for FEC0: addr 0
No ethernet found.
Hit any key to stop autoboot: 0
Info: input data size = 4285 = 0x10BD
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
Press FW button to enter firmware update mode
Entering firmware update mode.
Checking if ubootenv part is present
Loading FIT header to 0x82000000 …
Loading FIT strings to 0x82000028 …
Loading FIT struct to 0x82000100 …
Can’t find subimage ‘ubootenv’
Extracting kernel
7937936 bytes read in 365 ms (20.7 MiB/s)
Description: Update kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x82000300
Data Size: 7928976 Bytes = 7.6 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 47f6419e0d5d8326c41b16761827dc3d746fec78
Verifying … sha1+
Loading part 0 … OK
Extracting DTB
Loading FIT header to 0x83000000 …
Loading FIT strings to 0x83000028 …
Loading FIT struct to 0x83000100 …
55849 bytes read in 32 ms (1.7 MiB/s)
Description: Update DTB
Type: Flat Device Tree
Data Start: 0x83000480
Data Size: 46505 Bytes = 45.4 KiB
Architecture: ARM
Hash algo: sha1
Hash value: ef9dd3fe2b348fb8eb9f150b9dc2e27d6899e823
Verifying … sha1+
Loading part 0 … OK
Kernel image @ 0x82000000 [ 0x000000 - 0x78fc90 ]
Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef8c000, end 9ef9a5a8 … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.22-wb6_initramfs (root@WB-buildserver) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #2 SMP Tue Feb 1 16:52:01 MSK 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Wiren Board init (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @cfbd0000 s25932 r8192 d23220 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttymxc0,115200 bootmode=update_auto
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 506756K/524288K available (5120K kernel code, 202K rwdata, 1576K rodata, 5120K init, 295K bss, 17532K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xd0000000 ( 512 MB)
[ 0.000000] modules : 0xaf000000 - 0xb0000000 ( 16 MB)
[ 0.000000] .text : 0xb0008000 - 0xb0600000 (6112 kB)
[ 0.000000] .init : 0xb0800000 - 0xb0d00000 (5120 kB)
[ 0.000000] .data : 0xb0d00000 - 0xb0d32880 ( 203 kB)
[ 0.000000] .bss : 0xb0d34000 - 0xb0d7ddb0 ( 296 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000053] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002596] Console: colour dummy device 80x30
[ 0.002639] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.002672] pid_max: default: 32768 minimum: 301
[ 0.002863] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002888] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004080] CPU: Testing write buffer coherency: ok
[ 0.004576] /cpus/cpu@0 missing clock-frequency property
[ 0.004615] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004669] Setting up static identity map for 0x80100000 - 0x80100070
[ 0.007054] Brought up 1 CPUs
[ 0.007087] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.007103] CPU: All CPU(s) started in SVC mode.
[ 0.008321] devtmpfs: initialized
[ 0.034581] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.035263] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.035311] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.035488] pinctrl core: initialized pinctrl subsystem
[ 0.037530] NET: Registered protocol family 16
[ 0.038046] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.040735] cpuidle: using governor menu
[ 0.076086] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.076119] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.078319] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.118556] mxs-dma 1804000.dma-apbh: initialized
[ 0.123058] SCSI subsystem initialized
[ 0.123673] usbcore: registered new interface driver usbfs
[ 0.123833] usbcore: registered new interface driver hub
[ 0.124075] usbcore: registered new device driver usb
[ 0.125699] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
[ 0.126552] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
[ 0.127416] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
[ 0.128912] i2c i2c-1: IMX I2C adapter registered
[ 0.128958] i2c i2c-1: can’t use DMA, using PIO instead.
[ 0.129379] pps_core: LinuxPPS API ver. 1 registered
[ 0.129401] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.129457] PTP clock support registered
[ 0.131841] clocksource: Switched to clocksource mxc_timer1
[ 0.155756] NET: Registered protocol family 2
[ 0.156945] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.157071] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.157229] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.157342] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.157397] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.157704] NET: Registered protocol family 1
[ 0.158549] RPC: Registered named UNIX socket transport module.
[ 0.158583] RPC: Registered udp transport module.
[ 0.158600] RPC: Registered tcp transport module.
[ 0.158615] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.727728] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.743012] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.745042] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.755465] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.755499] io scheduler noop registered (default)
[ 0.760613] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[ 0.760655] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[ 0.769681] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[ 1.321542] console [ttymxc0] enabled
[ 1.327122] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud = 5000000) is a IMX
[ 1.337399] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 56, base_baud = 5000000) is a IMX
[ 1.380169] imx_rngc 2284000.rngb: Freescale RNGC registered.
[ 1.415106] brd: module loaded
[ 1.434062] loop: module loaded
[ 1.442332] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.453738] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.461240] libphy: Fixed MDIO Bus: probed
[ 1.467772] 20b4000.ethernet supply phy not found, using dummy regulator
[ 1.475797] pps pps0: new PPS source ptp0
[ 1.508744] libphy: fec_enet_mii_bus: probed
[ 1.515011] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.641937] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.762890] pps pps1: new PPS source ptp1
[ 1.767963] libphy: fec_enet_mii_bus: probed
[ 1.775065] fec 2188000.ethernet eth1: registered PHC device 1
[ 1.781478] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.788179] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.793998] usbcore: registered new interface driver cdc_acm
[ 1.799695] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.808057] usbcore: registered new interface driver usb-storage
[ 1.871611] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 1.887844] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 1.896970] i2c /dev entries driver
[ 1.905191] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.912696] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_SD1_DATA1 already requested by watchdog; cannot claim for watchdog_6x
[ 1.924237] imx6ul-pinctrl 20e0000.iomuxc: pin-114 (watchdog_6x) status -22
[ 1.931240] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 114 (MX6UL_PAD_SD1_DATA1) from group wdggrp_6x on device 20e0000.iomuxc
[ 1.943664] gpio-wdt watchdog_6x: Error applying setting, reverse things back
[ 1.950856] gpio-wdt: probe of watchdog_6x failed with error -22
[ 1.958645] sdhci: Secure Digital Host Controller Interface driver
[ 1.964974] sdhci: Copyright(c) Pierre Ossman
[ 1.969360] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.041911] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.061516] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.071518] random: fast init done
[ 2.089606] usbcore: registered new interface driver usbhid
[ 2.097374] usbhid: USB HID core driver
[ 2.111658] NET: Registered protocol family 17
[ 2.122652] Registering SWP/SWPB emulation handler
[ 2.129661] registered taskstats version 1
[ 2.146652] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[ 2.170027] rtc-pcf8563 4-0051: setting system clock to 2024-05-31 09:05:11 UTC (1717146311)
[ 2.178522] of_cfs_init
[ 2.182156] of_cfs_init: OK
[ 2.192080] vdd3p0: disabling
[ 2.195099] vref-3v3: disabling
[ 2.198249] usb1_vbus: disabling
[ 2.212319] Freeing unused kernel memory: 5120K (b0800000 - b0d00000)
[ 2.228086] mmc0: new DDR MMC card at address 0001
[ 2.248164] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[ 2.262258] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
mount: mounting none on /dev/pts [ 2.273724] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
failed: No such file or directory
[ 2.292460] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[ 2.303343] mmcblk0: p1 p2 p3 p4 < p5 p6 >
Boot mode: update_auto
Board is WB6, loading ci_hdrc_imx module
[ 2.539406] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 2.544625] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 2.581921] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 2.587599] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.594453] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.601684] usb usb1: Product: EHCI Host Controller
[ 2.606612] usb usb1: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[ 2.613271] usb usb1: SerialNumber: ci_hdrc.0
[ 2.619106] hub 1-0:1.0: USB hub found
[ 2.623108] hub 1-0:1.0: 1 port detected
[ 2.628581] 2184200.usb supply vbus not found, using dummy regulator
[ 2.639278] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.644370] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.671931] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.677719] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.684593] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.691873] usb usb2: Product: EHCI Host Controller
[ 2.696769] usb usb2: Manufacturer: Linux 4.9.22-wb6_initramfs ehci_hcd
[ 2.703462] usb usb2: SerialNumber: ci_hdrc.1
[ 2.709230] hub 2-0:1.0: USB hub found
[ 2.713219] hub 2-0:1.0: 1 port detected
[ 3.011983] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 3.071988] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 3.205363] usb 1-1: New USB device found, idVendor=0951, idProduct=1666
[ 3.212318] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.219589] usb 1-1: Product: DataTraveler 3.0
[ 3.224178] usb 1-1: Manufacturer: Kingston
[ 3.228408] usb 1-1: SerialNumber: 049226C312CFE46149B71939
[ 3.237957] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 3.244918] scsi host0: usb-storage 1-1:1.0
[ 3.282552] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
[ 3.289327] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.298263] hub 2-1:1.0: USB hub found
[ 3.302290] hub 2-1:1.0: 4 ports detected
[ 3.622015] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 3.774461] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720
[ 3.781467] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.788998] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 3.794102] usb 2-1.1: Manufacturer: Realtek
[ 3.798421] usb 2-1.1: SerialNumber: 00e04c000001
1+0 records in
1+0 records out
1024 bytes (1.0 kB, 1.0 KiB) copied, 0.000308834 s, 3.3 MB/s
Wait for eMMC to become available…
Activate Mass Storage device
[ 4.029372] udc-core: couldn’t find an available UDC - added [g_mass_storage] to list of pending drivers
[ 4.324465] scsi 0:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[ 4.337080] sd 0:0:0:0: [sda] 60555264 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 4.348400] sd 0:0:0:0: [sda] Write Protect is off
[ 4.354640] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.478963] sda: sda1
[ 4.488503] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 197.071943] random: crng init done
Какие есть варианты восстановления до заводских настроек ?
Флешки все fat 32, и виндой и руфусом пробовал разницы нет
Не очень понятно, “не доступа” - что значит? Что возвращается при запросе http?
Рекомендую для начала привести настройки загрузки к умолчальным: Кончилось место, сброс до заводских настроек - #25 от пользователя Mitya
Рабочий способ описывал: Не подключается к WEB UI и SSH - #14 от пользователя BrainRoot
Здравствуйте, попробую данные способы во вторник, если все получится отпишусь.
Просмотрел, что есть такой способ решения проблемы,сейчас пробую его:
Как будет результат напшу.
Помогло, спасибо.
