[ 270.928237] EXT4-fs error: 132 callbacks suppressed
[ 270.928256] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 270.949011] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 270.964568] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 270.976876] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 270.990267] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 271.002839] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 271.016511] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 271.028508] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3140: comm (agetty): reading directory lblock 0
[ 271.042416] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3016: comm (agetty): reading directory lblock 0
[ 271.058141] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1536: inode #3016: comm (agetty): reading directory lblock 0
[ 271.090939] EXT4-fs warning: 119 callbacks suppressed
[ 271.090958] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.123213] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.142713] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.177034] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.196887] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.215201] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.232494] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.253865] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.267949] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
[ 271.282240] EXT4-fs warning (device mmcblk0p2): dx_probe:767: inode #1598: lblock 0: comm systemd-cgroups: error -5 reading directory block
контролер перестал отвечать, перезагрузил, он не загрузился.
подключился к отладке, там повторяются эти строки каждую секунду
Здравствуйте! Пришлите, пожалуйста, фото с серийным номером контроллера (на лицевой панели), а также полный лог с момента начала загрузки. Лучше в виде отдельного файла.
log.txt (60.4 КБ)
через минуту после старта контроллер становится доступным через веб на минуту.
Сброс на заводскую прошивку прошел успешно.
Но через несколько минут снова отпал и в логах
[ OK ] Started Serial Getty on ttymxc0.
[ 119.288884] EXT4-fs error: 16 callbacks suppressed
[ 119.288902] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.306079] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.317840] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.329553] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.341299] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.353027] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.364202] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.376144] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.387871] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.399576] EXT4-fs error (device mmcblk0p3): __ext4_find_entry:1534: inode #2: comm (agetty): reading directory lblock 0
[ 119.413342] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
[ 119.445546] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
[ 119.547227] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
[ OK ] Stopped Serial Getty on ttymxc0.
[ 119.587670] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
[ 119.604205] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
[ 119.630261] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
[ OK ] Stopped Getty[ 119.647390] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
on tty1.
[ 119.690085] EXT4-fs warning (device mmcblk0p3): dx_probe:767: inode #8199: lblock 0: comm systemd-journal: error -5 reading directory block
[ OK ] Started Getty on tty1.
Актуальный лог загрузки
log2.txt (60.2 КБ)
a4sl35yj
выпущен в 2019
партия 357.
Предполагаю Wiren Board 6: Errata — Wiren Board
Какие внутренние модули расширения установлены?
Установлена батарейка, open Therm (для baxi) и релейный модуль
Модуль расширения [WBE2-I-OPENTHERM]
Модуль расширения [WBE2-DO-R6C-1]
Модуль резервного питания для Wiren Board 6 [WBMZ2-BATTERY]
Да, [ 2.146187] mmcblk0: mmc0:0001 W62704 3.53 GiB
- WB7 - 1 шт. WBMZ4-BATTERY - 1 шт.
- ссылку на эту тему,
- серийный номер устройства, a4sl35yj,
спс, направил письмо, жду.
Учтите, что модули WBE2-I-OPENTHERM и WBE2-DO-R6C-1 если куплены до начала этого года, возможно, придется немного подрезать, текстолит в том месте где располагается разъем процессорной платы.
понял, но покупал в этом году.
