Пытаюсь сбросить пароль по инструкции Wiren Board 6…8: Восстановление пароля пользователя root — Wiren Board
И уже на пункте 2 не удается сделать " а при появлении в UART-консоли сообщения с обратным отсчетом Hit key to stop autoboot (или Hit any key to stop autoboot ), нажмите пробел", потому что это сообщение не появляется.
Логи ниже. прошу помочь
Welcome to Debian GNU/Linux 9 (stretch)!
[ 3.976194] systemd[1]: Set hostname to .
[ 4.003720] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.017617] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 4.215216] systemd[1]: Configuration file /etc/systemd/system/sh-broker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.245867] systemd[1]: [/lib/systemd/system/wb-cloud-agent-telegraf.service:8] Unknown lvalue ‘ExecCondition’ in section ‘Service’
[ 4.260534] systemd[1]: Configuration file /etc/systemd/system/sh-controller.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.280941] systemd[1]: Configuration file /etc/systemd/system/sh-updater.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.298561] systemd[1]: [/lib/systemd/system/wb-cloud-agent-frpc.service:8] Unknown lvalue ‘ExecCondition’ in section ‘Service’
[ 4.326634] systemd[1]: [/lib/systemd/system/wb-mqtt-w1.service:10] Unknown lvalue ‘StartLimitIntervalSec’ in section ‘Service’
[ 4.387159] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
Mounting POSIX Message Queue File System…
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Remote File Systems.
Mounting /sys/kernel/config…
[ OK ] Listening on Syslog Socket.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Listening on Journal Socket.
Starting Create list of required st…ce nodes for the current kernel…
Starting Load Kernel Modules…
[ OK ] Listening on fsck to fsckd communication Socket.
Starting File System Check on Root Device…
Mounting Debug File System…
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Reached target Slices.
[ OK ] Listening on udev Control Socket.
Starting Journal Service…
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted /sys/kernel/config.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started File System Check on Root Device.
[ OK ] Started Journal Service.
[ OK ] Started File System Check Daemon to report status.
Starting Remount Root and Kernel File Systems…
Starting Apply Kernel Variables…
[ 5.464924] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
Starting Create Static Device Nodes in /dev…
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager…
Starting Load/Save Random Seed…
Starting udev Coldplug all Devices…
Starting prepare partitions at first boot…
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started prepare partitions at first boot.
[ OK ] Reached target Local File Systems (Pre).
[ 6.350512] Driver for 1-wire Dallas network protocol.
[ OK ] Started udev Coldplug all Devices.
[ 6.509230] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[ OK ] Found device /dev/ttyS0.
[ 6.664350] Bluetooth: Core ver 2.22
[ 6.668156] NET: Registered protocol family 31
[ 6.672625] Bluetooth: HCI device and connection manager initialized
[ 6.679139] Bluetooth: HCI socket layer initialized
[ 6.684053] Bluetooth: L2CAP socket layer initialized
[ 6.689260] Bluetooth: SCO socket layer initialized
[ 6.708044] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.728917] usbcore: registered new interface driver btusb
[ 6.737641] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 6.748164] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 6.754226] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ OK ] Found device /dev/mmcblk0p5.
[ 6.792408] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 6.799271] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 6.803994] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 6.808505] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 6.817317] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 6.829307] cfg80211: failed to load regulatory.db
[ OK ] Found device /dev/mmcblk0p6.
Starting File System Check on /dev/mmcblk0p6…
Activating swap /dev/mmcblk0p5…
[ 7.218107] Adding 262140k swap on /dev/mmcblk0p5. Priority:-2 extents:1 across:262140k SS
[ OK ] Activated swap /dev/mmcblk0p5.
[ OK ] Reached target Swap.
[ 7.314100] RTL871X: module init start
[ 7.317976] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[ 7.324962] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 7.530830] RTL871X: rtw_ndev_init(wlan0)
[ 7.536213] RTL871X: rtw_ndev_init(wlan1)
[ 7.547033] usbcore: registered new interface driver rtl8723bu
[ 7.553036] RTL871X: module init ret=0
[ 7.637360] usbcore: registered new interface driver rtl8xxxu
[ 7.646213] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ OK ] Started File System Check on /dev/mmcblk0p6.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mounting /mnt/data…
Starting Load/Save RF Kill Switch Status…
[ 8.442379] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Mounted /mnt/data.
[ OK ] Started Load/Save RF Kill Switch Status.
Mounting /var/log…
[ OK ] Mounted /var/log.
Starting Flush Journal to Persistent Storage…
[ OK ] Reached target Local File Systems.
[ OK ] Started ifup for eth1.
[ OK ] Started ifup for wlan0.
Starting prepare mounts and symlinks to config files…
[ 8.771513] systemd-journald[123]: Received request to flush runtime journal from PID 1
[ 8.812114] systemd-journald[123]: File /var/log/journal/c084018070af24d075c42c6463613f91/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ OK ] Started Flush Journal to Persistent Storage.
[ 9.074412] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[ OK ] Started prepare mounts and symlinks to config files.
Starting Create Volatile Files and Directories…
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Reached target System Time Synchronized.
[ 9.709423] RTL871X: RTW_ADAPTIVITY_EN_
[ 9.709450] AUTO, chplan:0x20, Regulation:3,3
[ 9.717770] RTL871X: RTW_ADAPTIVITY_MODE_
[ 9.717784] NORMAL
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on KNX Daemon (socket).
[ OK ] Started Monitor directories with device templates for wb-mqtt-serial.
[ OK ] Reached target Paths.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting LSB: zbw_connect…
[ OK ] Started D-Bus System Message Bus.
Starting System Logging Service…
Starting initialize filesystems at first boot…
[ OK ] Started Startup script broker.
[ OK ] Started Cgroup management daemon.
[ OK ] Started watch config files.
[ OK ] Started Generates wb-mqtt-serial UI schema f[ 10.419140] new mount options do not match the existing superblock, will be ignored
or wb-mqtt-confed.
Starting Restore local date from Wiren Board GSM RTC…
[ OK ] Started Startup script controller.
[ OK ] Started Startup script updater.
[ OK ] Started Regular background program processing daemon.
Starting Mosquitto MQTT v3.1/v3.1.1 Broker…
[ OK ] Started Wiren Board Cloud Agent.
[ OK ] Started telegraf metric sender for Wiren Board Cloud.
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down…
Starting Initialize Wiren Board Device Tree overlays…
Starting LSB: RaZberry Z-Wave service…
Starting Login Service…
Starting Bluetooth service…
[ OK ] Started System Logging Service.
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ OK ] Started LSB: RaZberry Z-Wave service.
[ OK ] Started Mosquitto MQTT v3.1/v3.1.1 Broker.
[ 11.245692] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.251255] Bluetooth: BNEP filters: protocol multicast
[ 11.256604] Bluetooth: BNEP socket layer initialized
[ OK ] Started initialize filesystems at first boot.
[ OK ] Started LSB: zbw_connect.
[ OK ] Started Bluetooth service.
[ OK ] Started Login Service.
Starting Hostname Service…
[ OK ] Reached target Bluetooth.
Starting Avahi mDNS/DNS-SD Stack…
Starting Wiren Board MQTT to OPC UA gateway…
[ OK ] Started Wiren Board configuration editor backend.
[ OK ] Started Wiren Board firmware update service.
Starting Wiren Board MQTT to Modbus TCP gateway…
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Hostname Service.
[ 12.479866] RTL871X: nolinked power save enter
[ 12.618060] random: crng init done
[ 12.621545] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Started Wiren Board MQTT to OPC UA gateway.
[ OK ] Started Restore local date from Wiren Board GSM RTC.
[ OK ] Started Wiren Board MQTT to Modbus TCP gateway.
[ 16.679427] dwmac-sun8i 1c50000.ethernet eth1: PHY [stmmac-1:00] driver [ICPlus IP101A/G] (irq=POLL)
[ 16.713810] dwmac-sun8i 1c50000.ethernet eth1: No Safety Features support found
[ 16.721270] dwmac-sun8i 1c50000.ethernet eth1: No MAC Management Counters available
[ 16.729010] dwmac-sun8i 1c50000.ethernet eth1: PTP not supported by HW
[ 16.768046] dwmac-sun8i 1c50000.ethernet eth1: configuring for phy/mii link mode
[ 18.638679] 1c29800.serial: ttyS6 at MMIO 0x1c29800 (irq = 130, base_baud = 1500000) is a Allwinner sun4i
[ 18.998509] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 131, base_baud = 1500000) is a Allwinner sun4i
[ 19.725683] 1c29000.serial: ttyS4 at MMIO 0x1c29000 (irq = 132, base_baud = 1500000) is a Allwinner sun4i
[ OK ] Started Initialize Wiren Board Device Tree overlays.
[ OK ] Started MQTT Rule engine for Wiren Board.
Starting KNXD Configurator for Wiren Board…
Starting Raise network interfaces…
[ OK ] Started one-click diagnostic data c…ard, generating archive with data.
[ OK ] Started metrics sender…
[ OK ] Started Raise network interfaces.
[ OK ] Reached target Network.
[ OK ] Started Teleport Service.
[ OK ] Started zigbee2mqtt.
Starting MQTT Driver for ADC…
Starting dnsmasq - A lightweight DHCP and caching DNS server…
Starting KNX Daemon…
Starting Permit User Sessions…
[ OK ] Started MQTT Driver for serial devices.
Starting MQTT Driver for GPIO-controlled switches…
[ OK ] Started Wiren Board database logger.
Starting OpenBSD Secure Shell server…
Starting Advanced key-value store…
[ OK ] Started Kernel 1-Wire MQTT driver for WB-HomA.
[ OK ] Started Wiren Board journald to MQTT gateway.
Starting A high performance web server and a reverse proxy server…
[ OK ] Started KNX Daemon.
[ OK ] Started Permit User Sessions.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Advanced key-value store.
[ OK ] Stopped telegraf metric sender for Wiren Board Cloud.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started Wiren Board MQTT KNX bridge.
[ OK ] Reached target Network is Online.
Starting LSB: Start NTP daemon…
Starting LSB: Brings up/down network automatically…
[ OK ] Started dnsmasq - A lightweight DHCP and caching DNS server.
[ 23.739352] process ‘/sbin/netplugd’ started with executable stack
[ 23.758767] sun4i-emac 1c0b000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 23.767147] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started LSB: Start NTP daemon.
Starting Compensation of systime in…evice-tree (with opposite sign)…
[ OK ] Stopped KNX Daemon.
[ OK ] Started KNXD Configurator for Wiren Board.
[ OK ] Started Compensation of systime in … device-tree (with opposite sign).
[ OK ] Started A high performance web server and a reverse proxy server.
Starting Initialize Wiren Board on successful boot…
[ OK ] Started LSB: Brings up/down network automatically.
Debian GNU/Linux 9 wirenboard-AFZWDSID ttyS0
wirenboard-AFZWDSID login:
