При загрузке :
Welcome to Wiren Board 7.3.4 (s/n ), release wb-2401 (as stable)
Linux wirenboard 5.10.35-wb159+wb1 #1 SMP Fri Mar 22 15:10:33 UTC 2024 armv7l GNU/Linux
System load: 1.17 0.73 0.32 Up time: 4 min
Memory usage: 5% of 997M Usage of /: 34% of 2.0G /mnt/data: 6% of 4.9G
Last login: Fri May 10 12:33:29 UTC 2024 on ttyS0
root@wirenboard:~# nmtui
NetworkManager is not running.
root@wirenboard:~# [ 305.132492] EXT4-fs (mmcblk0p2): error count since last fsck: 2
[ 305.138465] EXT4-fs (mmcblk0p2): initial error at time 1708180701: ext4_search_dir:1398: inode 7379: block 11628
[ 305.148682] EXT4-fs (mmcblk0p2): last error at time 1708180701: ext4_empty_dir:2913: inode 7379: block 11628
Далее
[ 269.796074] systemd[1]: Detected architecture arm.
[ 274.382499] EXT4-fs (mmcblk0p2): re-mounted. Opts:
[ 305.133111] EXT4-fs (mmcblk0p2): error count since last fsck: 2
[ 305.139052] EXT4-fs (mmcblk0p2): initial error at time 1708180701: ext4_search_dir:1398: inode 7379: block 11628
[ 305.149237] EXT4-fs (mmcblk0p2): last error at time 1708180701: ext4_empty_dir:2913: inode 7379: block 11628
