Добрый день, установил сервис wb-mqtt-iec104. но при запуску он пишет ошибки и не запускается.
подскажите в чем может быть дело.
Jul 18 08:49:39 HOME wb-mqtt-iec104[8195]: INFO: [mqtt] Default host and port detected, checking if UNIX socket exists on /var/run/mosquitto/mosquitto.sock
Jul 18 08:49:39 HOME wb-mqtt-iec104[8195]: INFO: [mqtt] UNIX socket not found, falling back to TCP connection
Jul 18 08:49:39 HOME wb-mqtt-iec104[8195]: FATAL: Can't create mosquitto client with id "" Invalid argument (22) @ wblib/mqtt.cpp:213
Jul 18 08:49:39 HOME systemd[1]: wb-mqtt-iec104.service: Control process exited, code=exited status=1
Jul 18 08:49:39 HOME systemd[1]: Failed to start Wiren Board MQTT to IEC 60870-5-104 gateway.
Jul 18 08:49:39 HOME systemd[1]: wb-mqtt-iec104.service: Unit entered failed state.
Jul 18 08:49:39 HOME systemd[1]: wb-mqtt-iec104.service: Failed with result 'exit-code'.
Jul 18 08:49:40 HOME systemd[1]: wb-mqtt-iec104.service: Service hold-off time over, scheduling restart.
Jul 18 08:49:40 HOME systemd[1]: Stopped Wiren Board MQTT to IEC 60870-5-104 gateway.
Jul 18 08:49:40 HOME systemd[1]: wb-mqtt-iec104.service: Start request repeated too quickly.
Jul 18 08:49:40 HOME systemd[1]: Failed to start Wiren Board MQTT to IEC 60870-5-104 gateway.
Jul 18 08:49:40 HOME systemd[1]: wb-mqtt-iec104.service: Unit entered failed state.
Jul 18 08:49:40 HOME systemd[1]: wb-mqtt-iec104.service: Failed with result 'exit-code'.
