Press FW button to enter firmware update mode
Entering firmware update mode.
U-Boot SPL 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0 = 0x0112010c
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3d40
.p0_mpwrdlctl = 0x3f3f3933
.p0_mpwldectrl0 = 0x00030007
.p0_mpwldectrl1 = 0x00080008
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 48C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=2
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net: Could not get PHY for FEC0: addr 0
No ethernet found.
Hit any key to stop autoboot: 0
## Info: input data size = 4285 = 0x10BD
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
И так по кругу.
Перед этим обновили контроллер с флешки. все прошло нормально, получили доступ через web. Контроллер выключили и через пару дне попытались включить и тут такое
Вопрос решился - проблемой оказался блок питания.
2 лайка
