Добрый день, я установил актуальную прошивку на контроллер Wirenboard 8.5, затем прогнал apt update && apt upgrade. Пытаюсь зайти на сайт через wirenboard-xxxxxxxx.local, а он висит на “Настройка HTTPS“:
Диагностический архив:
Вот такой ответ присылает на команду wget ``https://ifconfig.me`` -O -:
–2026-05-04 08:08:22-- https://ifconfig.me/
Resolving ifconfig.me (ifconfig.me)… 34.160.111.145, 2600:1901:0:b2bd::
Connecting to ifconfig.me (ifconfig.me)|34.160.111.145|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 10491 (10K) [text/html]
Saving to: ‘STDOUT’
0%[ ] 0 --.-KB/s <!DOCTYPE html>
<div id="container" class="clearfix">
<div id="header">
<table>
<tr>
<td>
<h1><a href="http://ifconfig.me">What Is My IP Address? - ifconfig.me</a></h1>
</td>
<td></td>
</tr>
<tr>
<td></td>
<td>
<div id="plungins">
<div class="plungin" id="button_facebook">
<div id="fb-root"></div>
<script src="http://connect.facebook.net/en_US/all.js#xfbml=1"></script>
<fb:like href="http://ifconfig.me/" send="false" layout="button_count" width="100"
show_faces="true" font=""></fb:like>
</div>
<div class="plungin" id="button_twitter">
<a href="http://twitter.com/share" class="twitter-share-button"
data-url="http://ifconfig.me/" data-text="What Is My IP Address? - ifconfig.me"
data-count="horizontal"></a>
<script type="text/javascript" src="http://platform.twitter.com/widgets.js"></script>
</div>
<div class="plungin" id="button_plusone">
<!-- Place this tag where you want the +1 button to render -->
<g:plusone size="medium" href="http://ifconfig.me/"></g:plusone>
<!-- Place this render call where appropriate -->
<script type="text/javascript">
(function () {
var po = document.createElement('script');
po.type = 'text/javascript';
po.async = true;
po.src = 'https://apis.google.com/js/plusone.js';
var s = document.getElementsByTagName('script')[0];
s.parentNode.insertBefore(po, s);
</script>
</div>
</div>
</td>
</tr>
</table>
</div>
<div id="info_area">
<h2>Your Connection</h2>
<table id="info_table" summary="info">
<tr>
<td class="info_table_label">IP Address</td>
<td id="ip_address_cell"><strong id="ip_address">
85.236.188.62
</strong></td>
</tr>
<tr>
<td class="info_table_label">User Agent</td>
<td>
Wget/1.21
</td>
</tr>
<tr>
<td class="info_table_label">Language</td>
<td>
</td>
</tr>
<tr>
<td class="info_table_label">Referer</td>
<td>
</td>
</tr>
<tr>
<td class="info_table_label">Method</td>
<td>
GET
</td>
</tr>
<tr>
<td class="info_table_label">Encoding</td>
<td>
identity
</td>
</tr>
<tr>
<td class="info_table_label">MIME Type</td>
<td>
</td>
</tr>
<tr>
<td class="info_table_label">Charset</td>
<td>
</td>
</tr>
<tr>
<td class="info_table_label">X-Forwarded-For</td>
<td>
85.236.188.62,34.160.111.145
</td>
</tr>
</table>
</div>
<!--<div id="middle"></div>-->
<div id="cli_wrap">
<h2>Command Line Interface</h2>
<table id="cli_table" summary="cli">
<tr>
<td class="cli_command">$ curl ifconfig.me</td>
<td class="cli_arrow">⇒</td>
<td>
85.236.188.62
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/ip</td>
<td>
85.236.188.62
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/ua</td>
<td>
Wget/1.21
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/lang</td>
<td>
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/encoding</td>
<td>
identity
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/mime</td>
<td>
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/charset</td>
<td>
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/forwarded</td>
<td>
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/all</td>
<td>
ip_addr: 85.236.188.62
<br>
remote_host: unavailable
<br>
user_agent: Wget/1.21
<br>
port: 55182
<br>
language:
<br>
referer:
<br>
connection:
<br>
keep_alive:
<br>
method: GET
<br>
encoding: identity
<br>
mime: */*
<br>
charset:
<br>
via: 1.1 google
<br>
forwarded: 85.236.188.62,34.160.111.145
<br>
<br>
</td>
</tr>
<tr>
<td class="cli_command">$ curl ifconfig.me/all.json</td>
<td>
{"ip_addr":"85.236.188.62","user_agent":"Wget/1.21","port":"55182","method":"GET","encoding":"identity","mime":"*/*","via":"1.1 google","forwarded":"85.236.188.62,34.160.111.145"}
</td>
</tr>
</table>
</div>
<div id="footer">© 2024 ifconfig.me</div>
</div>
100%[==============================================>] 10.25K --.-KB/s in 0.005s
2026-05-04 08:08:23 (1.86 MB/s) - written to stdout [10491/10491]
Как отключить автоматическую конфигурацию, если нет доступа к Web настройкам контроллера? через режим инкогнито браузера тоже не получается.
Что-то у меня не воспроизводится.
Попробуйте пожалуйста зайти по ip адресу, не используя имя. Ну и в случае неудачи - пришлите дииагностический архив.
Через ip a посмотрел какой ip есть на порту, через него удачно зашел на Web контроллера, в настройках веб-интерфейс отсутствует галочка на “Автоматическая конфигурация“.
Если ставлю статический ip для какого-либо порта, он все равно не заходит, также висит “Настройка HTTPS“.
Да, все разы я пытаюсь заходить через http, через статический ip или по серейнику контроллера не получается - также висит “Настройка HTTPS“. Получается зайти только если через ip a смотрю какой ip выдало на порт по DHCP и по нему удается зайти.
Проверьте пожалуйста в браузере - не меняет ли он http на https.
Попробовал поставить галочки на “Perserve log“ и “Disable cache“, обновил страницу и теперь нормально загружается web:
При чем до этого и через другие браузере не запускалось, а теперь в одном браузере поставил эти галочки и в других браузерах начало работать все.
Спасибо за помощь, думаю вопрос решен. Хотя я не понял, что было проблемой.
Понятно, кэш просто использовался.
