Помогите решить проблему с запуском.
3532376 bytes read in 1473 ms (2.3 MiB/s)
40355 bytes read in 705 ms (55.7 KiB/s)
Booting from mmc …
Kernel image @ 0x42000000 [ 0x000000 - 0x35e658 ]
Flattened Device Tree blob at 41000000
Booting using the fdt blob at 0x41000000
Loading Device Tree to 47b51000, end 47b5dda2 … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.1.15-wb2 (root@wbdevenv) (gcc version 4.9.2 ( 4.9 .2-10) ) #2 Sat Jun 3 20:09:17 UTC 2017
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine model: Wiren Board rev. 5.8 (i.MX28)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 32512
[ 0.000000] Kernel command line: console=ttyAMA0,115200 ro rootwait fixrtc ro ot=/dev/mmcblk0p3 rootfstype=ext4 video=
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 123292K/131072K available (4275K kernel code, 185K rwdata , 1544K rodata, 152K init, 268K bss, 7780K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff000000 ( 872 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05b7108 (5821 kB)
[ 0.000000] .init : 0xc05b8000 - 0xc05de000 ( 152 kB)
[ 0.000000] .data : 0xc05de000 - 0xc060c680 ( 186 kB)
[ 0.000000] .bss : 0xc060c680 - 0xc064f9b0 ( 269 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] clocksource mxs_timer: mask: 0xffffffff max_cycles: 0xffffffff, m ax_idle_ns: 79635851949 ns
[ 0.000021] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478 484971ns
[ 0.000711] Console: colour dummy device 80x30
[ 0.000770] Calibrating delay loop… 226.09 BogoMIPS (lpj=1130496)
[ 0.080279] pid_max: default: 32768 minimum: 301
[ 0.080541] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.080584] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.081865] CPU: Testing write buffer coherency: ok
[ 0.082696] Setting up static identity map for 0x40008400 - 0x40008458
[ 0.086422] devtmpfs: initialized
[ 0.115807] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max _idle_ns: 19112604462750000 ns
[ 0.116869] pinctrl core: initialized pinctrl subsystem
[ 0.119811] NET: Registered protocol family 16
[ 0.121304] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.161636] Serial: AMBA PL011 UART driver
[ 0.162275] 80074000.serial: ttyAMA0 at MMIO 0x80074000 (irq = 234, base_baud = 0) is a PL011 rev2
[ 0.416780] console [ttyAMA0] enabled
[ 0.442891] mxs-dma 80004000.dma-apbh: initialized
[ 0.453030] mxs-dma 80024000.dma-apbx: initialized
[ 0.463147] usbcore: registered new interface driver usbfs
[ 0.468998] usbcore: registered new interface driver hub
[ 0.474618] usbcore: registered new device driver usb
[ 0.482077] Linux video capture interface: v2.00
[ 0.487003] pps_core: LinuxPPS API ver. 1 registered
[ 0.492082] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti giometti@linux.it
[ 0.501352] PTP clock support registered
[ 0.506779] Advanced Linux Sound Architecture Driver Initialized.
[ 0.515020] Switched to clocksource mxs_timer
[ 0.555753] NET: Registered protocol family 2
[ 0.562048] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.569205] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.575691] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.582384] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.588374] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.595210] NET: Registered protocol family 1
[ 0.600373] RPC: Registered named UNIX socket transport module.
[ 0.606434] RPC: Registered udp transport module.
[ 0.611161] RPC: Registered tcp transport module.
[ 0.615946] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.622913] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.633051] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.676906] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 48)
[ 0.684376] io scheduler noop registered (default)
[ 0.692766] 8006a000.serial: ttyAPP0 at MMIO 0x8006a000 (irq = 229, base_baud = 1500000) is a 8006a000.serial
[ 0.703772] mxs-auart 8006a000.serial: Found APPUART 3.1.0
[ 0.710184] 8006c000.serial: ttyAPP1 at MMIO 0x8006c000 (irq = 230, base_baud = 1500000) is a 8006c000.serial
[ 0.721181] mxs-auart 8006c000.serial: Found APPUART 3.1.0
[ 0.727530] 8006e000.serial: ttyAPP2 at MMIO 0x8006e000 (irq = 231, base_baud = 1500000) is a 8006e000.serial
[ 0.738537] mxs-auart 8006e000.serial: Found APPUART 3.1.0
[ 0.744789] 80070000.serial: ttyAPP3 at MMIO 0x80070000 (irq = 232, base_baud = 1500000) is a 80070000.serial
[ 0.755983] mxs-auart 80070000.serial: Found APPUART 3.1.0
[ 0.762241] 80072000.serial: ttyAPP4 at MMIO 0x80072000 (irq = 233, base_baud = 1500000) is a 80072000.serial
[ 0.773280] mxs-auart 80072000.serial: Found APPUART 3.1.0
[ 0.795148] loop: module loaded
[ 0.905191] 800f0000.ethernet supply phy not found, using dummy regulator
[ 1.023808] libphy: fec_enet_mii_bus: probed
[ 1.030139] PPP generic driver version 2.4.2
[ 1.035253] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.042346] usbcore: registered new interface driver usbserial
[ 1.048463] usbcore: registered new interface driver usbserial_generic
[ 1.055260] usbserial: USB Serial support registered for generic
[ 1.062021] mousedev: PS/2 mouse device common for all mice
[ 1.072077] stmp3xxx-rtc 80056000.rtc: rtc core: registered 80056000.rtc as r tc0
[ 1.080276] i2c /dev entries driver
[ 1.087371] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with hear tbeat 19s
[ 1.097399] 80010000.ssp supply vmmc not found, using dummy regulator
[ 1.135134] mxs-mmc 80010000.ssp: initialized
[ 1.141621] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.154274] usbcore: registered new interface driver usbhid
[ 1.159981] usbhid: USB HID core driver
[ 1.181267] NET: Registered protocol family 10
[ 1.189484] sit: IPv6 over IPv4 tunneling driver
[ 1.196272] NET: Registered protocol family 17
[ 1.201122] Key type dns_resolver registered
[ 1.207806] mmc0: new high speed MMC card at address 0001
[ 1.215479] registered taskstats version 1
[ 1.220174] mmcblk0: mmc0:0001 SEM04G 3.68 GiB
[ 1.225291] mmcblk0boot0: mmc0:0001 SEM04G partition 1 1.00 MiB
[ 1.232842] stmp3xxx-rtc 80056000.rtc: setting system clock to 1970-01-01 00: 00:05 UTC (5)
[ 1.241405] mmcblk0boot1: mmc0:0001 SEM04G partition 2 1.00 MiB
[ 1.247500] of_cfs_init
[ 1.250111] of_cfs_init: OK
[ 1.261348] usb1_vbus: disabling
[ 1.265202] usb0_vbus: disabling
[ 1.268697] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 1.273673] ALSA device list:
[ 1.276776] No soundcards found.
[ 1.287240] uart-pl011 80074000.serial: no DMA platform data
[ 1.297807] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesyst em
[ 1.305253] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[ 1.355551] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.362893] mmcblk0: retrying write for general error
[ 1.368623] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.376034] mmcblk0: retrying write for general error
[ 1.381697] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.389105] mmcblk0: retrying write for general error
[ 1.394747] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.402168] mmcblk0: retrying write for general error
[ 1.407895] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.415314] mmcblk0: retrying write for general error
[ 1.420975] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.428382] mmcblk0: retrying write for general error
[ 1.433459] mmc0: tried to reset card
[ 1.437211] blk_update_request: I/O error, dev mmcblk0, sector 3180544
[ 1.443770] Buffer I/O error on dev mmcblk0p3, logical block 131072, lost syn c page write
[ 1.452123] JBD2: Error -5 detected when updating journal superblock for mmcb lk0p3-8.
[ 1.461553] EXT4-fs (mmcblk0p3): recovery complete
[ 1.467251] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.474592] mmcblk0: retrying write for general error
[ 1.480326] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.487737] mmcblk0: retrying write for general error
[ 1.493379] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.500802] mmcblk0: retrying write for general error
[ 1.506527] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.513864] mmcblk0: retrying write for general error
[ 1.519590] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.527001] mmcblk0: retrying write for general error
[ 1.532661] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.540072] mmcblk0: retrying write for general error
[ 1.545231] blk_update_request: I/O error, dev mmcblk0, sector 3180544
[ 1.551791] Buffer I/O error on dev mmcblk0p3, logical block 131072, lost syn c page write
[ 1.560134] JBD2: Error -5 detected when updating journal superblock for mmcb lk0p3-8.
[ 1.568061] Aborting journal on device mmcblk0p3-8.
[ 1.573653] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.581065] mmcblk0: retrying write for general error
[ 1.586765] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.594098] mmcblk0: retrying write for general error
[ 1.599830] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.607237] mmcblk0: retrying write for general error
[ 1.612897] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.620308] mmcblk0: retrying write for general error
[ 1.626020] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.633356] mmcblk0: retrying write for general error
[ 1.639063] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.646491] mmcblk0: retrying write for general error
[ 1.651580] blk_update_request: I/O error, dev mmcblk0, sector 3180544
[ 1.658209] Buffer I/O error on dev mmcblk0p3, logical block 131072, lost syn c page write
[ 1.666560] JBD2: Error -5 detected when updating journal superblock for mmcb lk0p3-8.
[ 1.675177] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.682513] mmcblk0: retrying write for general error
[ 1.688220] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.695641] mmcblk0: retrying write for general error
[ 1.701303] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.708715] mmcblk0: retrying write for general error
[ 1.714380] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.721790] mmcblk0: retrying write for general error
[ 1.727509] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.734845] mmcblk0: retrying write for general error
[ 1.740547] mmcblk0: card_busy_detect: error sending status cmd, status 0x809 00
[ 1.747966] mmcblk0: retrying write for general error
[ 1.753054] blk_update_request: I/O error, dev mmcblk0, sector 2131968
[ 1.759678] Buffer I/O error on dev mmcblk0p3, logical block 0, lost sync pag e write
[ 1.767600] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. O pts: (null)
[ 1.775901] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 1.783842] devtmpfs: mounted
[ 1.787693] Freeing unused kernel memory: 152K (c05b8000 - c05de000)
INIT: version 2.88 booting
[info] Using makefile-style concurrent boot in runlevel S.
[…] Starting the hotplug events dispatcher: udevd[ 3.799722] udevd[157]: s tarting version 175
. ok
[…] Synthesizing the initial hotplug events…[ 5.047209] imx28-pinctrl 80 018000.pinctrl: pin GPMI_D03 already requested by 80018000.pinctrl; cannot claim for 80000000.apbh:ssp1gpio
[ 5.059548] imx28-pinctrl 80018000.pinctrl: pin-3 (80000000.apbh:ssp1gpio) st atus -22
[ 5.067493] imx28-pinctrl 80018000.pinctrl: could not request pin 3 (GPMI_D03 ) from group spi1.0 on device 80018000.pinctrl
[ 5.078803] spi_gpio 80000000.apbh:ssp1gpio: Error applying setting, reverse things back
[ 5.543082] CAN device driver interface
[ 5.556199] mxs-spdif-dai 80054000.spdif: MXS SPDIF Audio Transmitter
[ 5.615361] mxs-dcp 80028000.dcp: Failed to register sha1 hash!
[ 5.646012] mxs-dcp: probe of 80028000.dcp failed with error -22
[ 5.652684] 80034000.can supply xceiver not found, using dummy regulator
[ 5.737482] flexcan 80034000.can: device registered (reg_base=c8930000, irq=2 09)
done.
[…] [ 7.134827] ci_hdrc ci_hdrc.0: EHCI Host Controller
Waiting for /dev to be fully populated…[ 7.168902] ci_hdrc ci_hdrc.0: new U SB bus registered, assigned bus number 1
[ 7.235264] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 7.335674] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.342506] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 7.349883] usb usb1: Product: EHCI Host Controller
[ 7.354790] usb usb1: Manufacturer: Linux 4.1.15-wb2 ehci_hcd
[ 7.360635] usb usb1: SerialNumber: ci_hdrc.0
[ 7.652255] hub 1-0:1.0: USB hub found
[ 7.683817] hub 1-0:1.0: 1 port detected
[ 7.728211] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 7.733194] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 7.805323] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 7.829027] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.835980] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 7.843229] usb usb2: Product: EHCI Host Controller
[ 7.848225] usb usb2: Manufacturer: Linux 4.1.15-wb2 ehci_hcd
[ 7.853996] usb usb2: SerialNumber: ci_hdrc.1
[ 7.972718] hub 2-0:1.0: USB hub found
[ 7.990563] hub 2-0:1.0: 1 port detected
[ 13.826952] mmcblk0: error -110 transferring data, sector 7733184, nr 8, cmd response 0x900, card status 0xb00
[ 13.837070] mmc0: tried to reset card
[ 13.840757] mmcblk0: retrying using single block read
[ 20.639478] mmcblk0: error -110 transferring data, sector 7733184, nr 8, cmd response 0x900, card status 0x0
[ 20.649450] blk_update_request: I/O error, dev mmcblk0, sector 7733184
[ 27.449616] mmcblk0: error -110 transferring data, sector 7733185, nr 7, cmd response 0x900, card status 0x0
[ 27.459568] blk_update_request: I/O error, dev mmcblk0, sector 7733185
[ 34.259735] mmcblk0: error -110 transferring data, sector 7733186, nr 6, cmd response 0x900, card status 0x0
[ 34.269690] blk_update_request: I/O error, dev mmcblk0, sector 7733186
[ 41.069861] mmcblk0: error -110 transferring data, sector 7733187, nr 5, cmd response 0x900, card status 0x0
[ 41.079816] blk_update_request: I/O error, dev mmcblk0, sector 7733187
[ 47.879993] mmcblk0: error -110 transferring data, sector 7733188, nr 4, cmd response 0x900, card status 0x0
[ 47.889949] blk_update_request: I/O error, dev mmcblk0, sector 7733188
[ 54.690151] mmcblk0: error -110 transferring data, sector 7733189, nr 3, cmd response 0x900, card status 0x0
[ 54.700114] blk_update_request: I/O error, dev mmcblk0, sector 7733189
[ 61.500272] mmcblk0: error -110 transferring data, sector 7733190, nr 2, cmd response 0x900, card status 0x0
[ 61.510226] blk_update_request: I/O error, dev mmcblk0, sector 7733190
udevd[187]: timeout ‘/sbin/blkid -o udev -p /dev/mmcblk0’
udevd[188]: timeout: killing ‘net.agent’ [284]
udevd[188]: ‘net.agent’ [284] terminated by signal 9 (Killed)
udevd[199]: timeout: killing ‘/sbin/modprobe -b of:NonewireTCw1-gpio’ [285]
udevd[190]: timeout: killing ‘/sbin/modprobe -b of:Nlirc-rfm69TClirc-pwm’ [286]
udevd[201]: timeout: killing ‘/sbin/modprobe -b of:Nsound-spdifTCfsl,mxs-spdif-audio’ [288]
[ 68.310366] mmcblk0: error -110 transferring data, sector 7733191, nr 1, cmd response 0x900, card status 0x0
[ 68.320325] blk_update_request: I/O error, dev mmcblk0, sector 7733191
udevd[200]: timeout: killing ‘net.agent’ [301]
udevd[200]: ‘net.agent’ [301] terminated by signal 9 (Killed)
udevd[187]: timeout: killing ‘/sbin/blkid -o udev -p /dev/mmcblk0’ [281]
udevd[187]: ‘/sbin/blkid -o udev -p /dev/mmcblk0’ [281] terminated by signal 9 (Killed)
udevd[189]: timeout: killing ‘net.agent’ [302]
udevd[189]: ‘net.agent’ [302] terminated by signal 9 (Killed)
udevd[204]: timeout: killing ‘net.agent’ [304]
udevd[204]: ‘net.agent’ [304] terminated by signal 9 (Killed)
[ 75.120492] mmcblk0: error -110 transferring data, sector 2475440, nr 8, cmd response 0x900, card status 0xb00
[ 75.130617] mmcblk0: retrying using single block read
[ 81.929276] mmcblk0: error -110 transferring data, sector 2475440, nr 8, cmd response 0x900, card status 0x0
[ 81.939247] blk_update_request: I/O error, dev mmcblk0, sector 2475440
Пробовал решить проблему через переустановку. Не помогло.
