- Сделал.
root@wirenboard-A4VEY6PY:~# ls -l /dev/ttyM*
ls: cannot access '/dev/ttyM*': No such file or directory
root@wirenboard-A4VEY6PY:~# cat /etc/wb-hardware.conf
"w1": {
"module": "wb6-wx-di",
"options": {}
"w2": {
"options": {}
- Так же сделал
lrwxrwxrwx 1 root root 7 Jan 30 16:14 /dev/ttyMOD3 -> ttymxc6
"mod4": {
"module": "wbe2r-r-zigbee",
"options": {}
"w1": {
"options": {}
"w2": {
"options": {}
Для эксперимента указал ttyMOD3 в конфиге zigbee2mqtt
Jan 30 16:16:27 wirenboard-A4VEY6PY systemd[1]: Started zigbee2mqtt.
Jan 30 16:16:41 wirenboard-A4VEY6PY npm[25288]: > zigbee2mqtt@1.35.1 start
Jan 30 16:16:41 wirenboard-A4VEY6PY npm[25288]: > node index.js
Jan 30 16:16:46 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT requires node version ^18 || ^20 || ^21, you are running v16.18.1!
Jan 30 16:17:35 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:info 2024-01-30 16:17:35: Logging to console and directory: '/mnt/data/root/zigbee2mqtt/data/log/2024-01-30.16-17-35' filename: >
Jan 30 16:17:36 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:info 2024-01-30 16:17:36: Starting Zigbee2MQTT version 1.35.1 (commit #9eaaa0f9)
Jan 30 16:17:36 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:info 2024-01-30 16:17:36: Starting zigbee-herdsman (0.30.0)
Jan 30 16:18:04 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:error 2024-01-30 16:18:04: Error while starting zigbee-herdsman
Jan 30 16:18:04 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:error 2024-01-30 16:18:04: Failed to start zigbee
Jan 30 16:18:05 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:error 2024-01-30 16:18:05: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible so>
Jan 30 16:18:05 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:error 2024-01-30 16:18:05: Exiting...
Jan 30 16:18:06 wirenboard-A4VEY6PY npm[25336]: Zigbee2MQTT:error 2024-01-30 16:18:06: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
Jan 30 16:18:06 wirenboard-A4VEY6PY npm[25336]: at ZStackAdapter.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
Jan 30 16:18:06 wirenboard-A4VEY6PY npm[25336]: at Controller.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
Jan 30 16:18:06 wirenboard-A4VEY6PY npm[25336]: at Zigbee.start (/mnt/data/root/zigbee2mqtt/lib/zigbee.ts:60:27)
Jan 30 16:18:06 wirenboard-A4VEY6PY npm[25336]: at Controller.start (/mnt/data/root/zigbee2mqtt/lib/controller.ts:98:27)
Jan 30 16:18:06 wirenboard-A4VEY6PY npm[25336]: at start (/mnt/data/root/zigbee2mqtt/index.js:107:5)
Jan 30 16:18:06 wirenboard-A4VEY6PY systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
Jan 30 16:18:06 wirenboard-A4VEY6PY systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Jan 30 16:18:06 wirenboard-A4VEY6PY systemd[1]: zigbee2mqtt.service: Consumed 48.072s CPU time.
