Добрый день. Нет напряжения на шине RS-485 Wiren Board 7 помогите решить проблему.
Все работало, и в один момент контроллер перестал видеть модули.
Обновляли до последней версии, делали сброс к заводским настройкам, проблема осталась.
последние сообщения в системном журнале:
| 15-10-2024 11:48:24.523 [init.scope] | knxd.service: Failed with result ‘exit-code’. |
| 15-10-2024 11:48:24.522 [init.scope] | knxd.service: Main process exited, code=exited, status=1/FAILURE |
| 15-10-2024 11:48:24.520 [init.scope] | Started KNX Daemon. |
| 15-10-2024 11:48:24.519 [knxd] | WirenboardKNX: F00000105: [12:server] Link down, terminating |
| 15-10-2024 11:48:24.515 [knxd] | WirenboardKNX: E00000064: [19:router] router: setup router: failed |
| 15-10-2024 11:48:24.495 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:48:24.473 [init.scope] | Starting KNX Daemon… |
| 15-10-2024 11:48:24.465 [init.scope] | Stopped KNX Daemon. |
| 15-10-2024 11:48:24.462 [init.scope] | knxd.service: Scheduled restart job, restart counter is at 140. |
| 15-10-2024 11:48:19.360 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:48:14.357 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:48:14.272 [init.scope] | knxd.service: Failed with result ‘exit-code’. |
| 15-10-2024 11:48:14.271 [init.scope] | knxd.service: Main process exited, code=exited, status=1/FAILURE |
| 15-10-2024 11:48:14.269 [init.scope] | Started KNX Daemon. |
| 15-10-2024 11:48:14.268 [knxd] | WirenboardKNX: F00000105: [12:server] Link down, terminating |
| 15-10-2024 11:48:14.265 [knxd] | WirenboardKNX: E00000064: [19:router] router: setup router: failed |
| 15-10-2024 11:48:14.223 [init.scope] | Starting KNX Daemon… |
| 15-10-2024 11:48:14.215 [init.scope] | Stopped KNX Daemon. |
| 15-10-2024 11:48:14.212 [init.scope] | knxd.service: Scheduled restart job, restart counter is at 139. |
| 15-10-2024 11:48:11.415 [NetworkManager] | [1728982091.4152] audit: op=connection-activate uuid=91f1c71d-2d97-4675-886f-ecbe52b8451e name=wb-eth0 pid=1361 uid=0 result=fail reason=Connection ‘wb-eth0’ is not available on device eth0 because device has no carrier |
| 15-10-2024 11:48:11.165 [NetworkManager] | [1728982091.1647] audit: op=connection-activate uuid=c3e38405-9c17-4155-ad70-664311b49066 name=wb-eth1 pid=1361 uid=0 result=fail reason=Connection ‘wb-eth1’ is not available on device eth1 because device has no carrier |
| 15-10-2024 11:48:09.351 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:48:04.219 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:48:04.024 [init.scope] | knxd.service: Failed with result ‘exit-code’. |
| 15-10-2024 11:48:04.023 [init.scope] | knxd.service: Main process exited, code=exited, status=1/FAILURE |
| 15-10-2024 11:48:04.021 [init.scope] | Started KNX Daemon. |
| 15-10-2024 11:48:04.020 [knxd] | WirenboardKNX: F00000105: [12:server] Link down, terminating |
| 15-10-2024 11:48:04.017 [knxd] | WirenboardKNX: E00000064: [19:router] router: setup router: failed |
| 15-10-2024 11:48:03.973 [init.scope] | Starting KNX Daemon… |
| 15-10-2024 11:48:03.965 [init.scope] | Stopped KNX Daemon. |
| 15-10-2024 11:48:03.962 [init.scope] | knxd.service: Scheduled restart job, restart counter is at 138. |
| 15-10-2024 11:47:59.216 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:47:54.085 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:47:53.771 [init.scope] | knxd.service: Failed with result ‘exit-code’. |
| 15-10-2024 11:47:53.770 [init.scope] | knxd.service: Main process exited, code=exited, status=1/FAILURE |
| 15-10-2024 11:47:53.768 [init.scope] | Started KNX Daemon. |
| 15-10-2024 11:47:53.768 [knxd] | WirenboardKNX: F00000105: [12:server] Link down, terminating |
| 15-10-2024 11:47:53.765 [knxd] | WirenboardKNX: E00000064: [19:router] router: setup router: failed |
| 15-10-2024 11:47:53.723 [init.scope] | Starting KNX Daemon… |
| 15-10-2024 11:47:53.715 [init.scope] | Stopped KNX Daemon. |
| 15-10-2024 11:47:53.712 [init.scope] | knxd.service: Scheduled restart job, restart counter is at 137. |
| 15-10-2024 11:47:49.067 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:47:44.054 [wb-mqtt-serial] | WARNING: </dev/ttyRS485-1 9600 8 N 2>: closed due to repetitive errors |
| 15-10-2024 11:47:43.521 [init.scope] | knxd.service: Failed with result ‘exit-code’. |
| 15-10-2024 11:47:43.521 [init.scope] | knxd.service: Main process exited, code=exited, status=1/FAILURE |
| 15-10-2024 11:47:43.518 [init.scope] | Started KNX Daemon. |
| 15-10-2024 11:47:43.517 [knxd] | WirenboardKNX: F00000105: [12:server] Link down, terminating |
| 15-10-2024 11:47:43.515 [knxd] | WirenboardKNX: E00000064: [19:router] router: setup router: failed |
| 15-10-2024 11:47:43.473 [init.scope] | Starting KNX Daemon… |
| 15-10-2024 11:47:43.465 [init.scope] | Stopped KNX Daemon. |
| 15-10-2024 11:47:43.462 [init.scope] | knxd.service: Scheduled restart job, restart counter is at 136. |
