Прикладываю логи с консоли
Визуально выглядит так: контроллер со вставленным накомпителем стартует, начинает мигать оранжевым, я жму кнопку fw, загорается зеленый светодиод и в таком состоянии висит пару минут, потом контроллер уходит в ребут
U-Boot SPL 2017.03-1.2.0-gf92dee6 (Mar 05 2021 - 20:08:19)
DRAM init ok, rows:16, ncs:1, size: 1024MB
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2017.03-1.2.0-gf92dee6 (Mar 05 2021 - 20:08:19 +0300), Build: jenkins-bui ld-u-boot-140
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 46C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 1 GiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@02188000
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 2.0
Type: Removable Hard Disk
Capacity: 7636.0 MB = 7.4 GB (15638528 x 512)
reading wb6_update.fit
** Unable to read file wb6_update.fit **
reading wb6_update_FACTORYRESET.fit
1 bytes read in 19 ms (0 Bytes/s)
# Detected USB flash drive with update file
# Filename: wb6_update_FACTORYRESET.fit
# Press a FW key if you want to update firmware from this file
# or wait 3 seconds to boot normally.
USB update procedure start
Checking if ubootenv part is present
## Loading FIT header to 0x82000000 ...
## Loading FIT strings to 0x82000028 ...
## Loading FIT struct to 0x820000c0 ...
FAT: Misaligned buffer address (82001088)
Skip 7961328 bytes of data
FAT: Misaligned buffer address (8200058c)
Skip 46090 bytes of data
FAT: Misaligned buffer address (82001174)
Skip 4085 bytes of data
Skip 168647322 bytes of data
FAT: Misaligned buffer address (820006c8)
** wb6_update_FACTORYRESET.fit shorter than offset + len **
Can't find subimage 'ubootenv'
Extracting kernel
7977904 bytes read in 4940 ms (1.5 MiB/s)
Description: Update kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x820002c0
Data Size: 7961328 Bytes = 7.6 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 83e0ef509133764a09e3e5a3501c6082802add22
## Verifying ... sha1+
Loading part 0 ... OK
Extracting DTB
## Loading FIT header to 0x83000000 ...
## Loading FIT strings to 0x83000028 ...
## Loading FIT struct to 0x830000c0 ...
FAT: Misaligned buffer address (83001088)
FAT: Misaligned buffer address (8300058c)
63110 bytes read in 696 ms (87.9 KiB/s)
Description: Update DTB
Type: Flat Device Tree
Data Start: 0x830003c0
Data Size: 46090 Bytes = 45 KiB
Architecture: ARM
Hash algo: sha1
Hash value: c84c6f3c02d97d1bd1c9392cacb821029c01bce5
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to bef60000, end bef6e409 ... OK
Starting kernel ...
