Пытаюсь обновить прошивку с USB с FACTORY RESET.
Результат:
FACTORY RESET REQUESTED
This WILL destroy ALL YOUR DATA: configuration, scripts,
files in home directory!
If you are ABSOLUTELY SURE that you want to reset Wiren Board
to factory condition, hold the FW button for 4 seconds.
If you will not do it in 10 seconds, the controller will reboot
without firmware update.
If you want to perform a regular firmware update, rename
FIT file to "wbX_update.fit" without "factory-reset" suffix.
oo.
oo....
Factory reset is confirmed!
Tue Mar 26 05:46:30 UTC 2024: started update from /disk/wb6_update_FACTORYRESET.fit
Description: WirenBoard firmware update
Compatible device: contactless,imx6ul-wirenboard670
Firmware version: 202308241309
Firmware compatible: +single-rootfs
Release name: wb-2207-bullseye-transition
Release suite: stable
Release target: wb6/stretch
Release repo prefix:
Time of creation: Thu Aug 24 13:10:23 UTC 2023
>>> Checking SHA1 hash of install
PROGRESS: 0%
>>> SHA1 hash of install ok
>>> Wiping data partition (factory reset)
[ 22.912516] EXT4-fs (mmcblk0p6): recovery complete
[ 22.918938] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.0109282 s, 1.5 MB/s
>>> Firmware seems to be compatible with this controller
>>> Extracting install script
>>> Running install script
[ 33.767718] vref-3v3: disabling
>>> Checking SHA1 hash of rootfs
PROGRESS: 100%
!!! SHA1 of rootfs doesn't match (expected 278832bb3684ed060ea57095a23bda34e66c18ad, got 6ea2acb1e161a7ca127d260a9d2566f2ead7335d)
Waiting for microSD to settle (3/3)
BusyBox v1.30.1 (Debian 1:1.30.1-6+b3) built-in shell (ash)
Enter 'help' for a list of built-in commands.
sh: can't access tty; job control turned off
Подскажите, что можно сделать?
