На последней прошивке WB6.7 (202106021605_stable_webupd_wb67.fit) не работает обновление по USB
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB…
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
scanning usb for storage devices… 0 Storage Device(s) found
No storage devices, perhaps not 'usb start’ed…?
No USB update detected, continuing boot
“1 USB Device(s) found” в любом случае, есть подключенная флешка или нет
Флешки пробовал разные, линукс после загрузки их видит, U-boot не видит.
usb info
1: Hub, USB Revision 2.0
- u-boot EHCI Host Controller
- Class: Hub
- PacketSize: 64 Configurations: 1
- Vendor: 0x0000 Product 0x0000 Version 1.0
Configuration: 1
- Interfaces: 1 Self Powered 0mA
Interface: 0
- Alternate Setting 0, Endpoints: 1
- Class Hub
- Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms
- Class: Hub
Configuration: 1
Interface: 0
- Class Hub
Версия U-Boot 2017.03-1.1.0-gaa233c0fa3 (Jun 09 2020 - 19:28:23 +0000)
Дополню:
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 41C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@02188000
Hit any key to stop autoboot: 0
=> usb stop
stopping USB…
=> usb start
starting USB…
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
=> usb stop
stopping USB…
=> usb start
starting USB…
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices… 2 USB Device(s) found
scanning usb for storage devices… 1 Storage Device(s) found
Итак процедура сброса такова:
Подключаем флешку с прошивкой и включаем питание
CPU: Industrial temperature grade (-40C to 105C) at 47C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Жмем любую клавишу и попадаем в меню u-boot
Вводим команду usb start.
Если видим scanning bus 0 for devices… 1 USB Device(s) found вводим команду usb stop
Повторяем пункты 3, 4 до тех пор, пока не увидим 2 USB Device(s) found
Вводим boot
Далее по инструкции…
Добрый день. Дайте пожалуйста серийный номер контроллера.
У меня подобное поведение не воспроизводится… Пробовали несколько флешек?
А от какого БП работает контроллер?
WB6.7.2.A7F534SY.
Да, 2 флешки transcend, SmartBy, Sandisc. Разных размеров. SmartBy определилась сразу один раз. Она и натолкнула на этот алгоритм передергивания usb. Все флешки видны одинаково, если загрузить линукс. U-boot такие вещи любит…
Сейчас от этого. БП я менял.
Набрал кучу флешек. Transcend 8,16,32 Gb. Не определяются.
Sandisk 16 Gb не определяются
SmartBuy 8Gb через раз.
SmartBuy 16Gb ( Rev: PMAP Prod) - определяется всегда.
Других флешек нет
Воспроизводим, да, возможно баг.
