Обновление serial через shh
Доброго времени суток!
Прошу помочь обновить serial для перехода с релиза 2207 на 2304 для более удобной настройки сети. По рекомендациям попытался обновить через apt install wb-configs, но при попытке получил следующий лог:
root@wirenboard-A6VLT4QR:~# apt install wb-configs
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  wb-configs-stretch
  wb-configs wb-configs-stretch
2 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
Need to get 56.8 kB of archives.
After this operation, 2048 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://deb.wirenboard.com/wb6/stretch stable/main armhf wb-configs-stretch        all 2.3.4-wb103 [22.1 kB]
Get:2 http://deb.wirenboard.com/wb6/stretch stable/main armhf wb-configs all 2.3        .4-wb103 [34.7 kB]
Fetched 56.8 kB in 0s (104 kB/s)
(Reading database ... 35233 files and directories currently installed.)
Preparing to unpack .../wb-configs-stretch_2.3.4-wb103_all.deb ...
Unpacking wb-configs-stretch (2.3.4-wb103) over (2.3.4-wb100) ...
[  487.977312] systemd[1]: apt-daily.timer: Adding 2h 28min 34.083108s random ti        me.
[  489.930491] systemd[1]: apt-daily.timer: Adding 10h 43min 26.636764s random t        ime.
[  491.770458] systemd[1]: apt-daily.timer: Adding 3h 4min 44.405265s random tim        e.
[  493.832168] systemd[1]: apt-daily.timer: Adding 10h 14min 49.837423s random t        ime.
[  496.297348] systemd[1]: apt-daily.timer: Adding 3h 29min 41.740517s random ti        me.
[  498.013395] systemd[1]: apt-daily.timer: Adding 59min 24.611402s random time.
Setting up wb-configs-stretch (2.3.4-wb103) ...
Installing new version of config file /etc/apt/sources.list.d/debian-upstream.li        st ...
Installing new version of config file /etc/apt/sources.list.d/stretch-backports.        list ...
[  509.095536] systemd[1]: apt-daily.timer: Adding 8min 18.503499s random time.
[  512.717846] systemd[1]: Stopping Journal Service...
[  512.753840] systemd-journald[108]: Received SIGTERM from PID 1 (systemd).
[  512.856636] systemd[1]: Stopped Journal Service.
[  512.909142] systemd[1]: Starting Journal Service...
[  513.065458] systemd[1]: Started Journal Service.
Preparing to unpack .../wb-configs_2.3.4-wb103_all.deb ...
Unpacking wb-configs (2.3.4-wb103) over (2.3.4-wb100) ...
[  516.756764] systemd[1]: apt-daily.timer: Adding 4h 57min 21.350681s random ti        me.
[  518.524425] systemd[1]: apt-daily.timer: Adding 5h 39min 17.418258s random ti        me.
[  520.538259] systemd[1]: apt-daily.timer: Adding 1min 20.663832s random time.
Setting up wb-configs (2.3.4-wb103) ...
[  528.934302] systemd[1]: apt-daily.timer: Adding 11h 4min 10.986249s random ti        me.
*** OMINOUS WARNING ***: /etc/hostname is not linked to either hostname.wb or ho        stname.wb-orig
*** OMINOUS WARNING ***: /etc/network/interfaces is not linked to either interfa        ces.wb or interfaces.wb-orig
*** OMINOUS WARNING ***: /etc/dnsmasq.conf is not linked to either dnsmasq.conf.        wb or dnsmasq.conf.wb-orig
*** OMINOUS WARNING ***: /etc/hostapd.conf is not linked to either hostapd.conf.        wb or hostapd.conf.wb-orig
Прошу помочь разобраться и довести процедуру до конца
Опишите последовательно процедуру перехода на актуальный релиз. Какие команды вводите и какие при этом возникают ошибки. В приведенном вами логе ошибок не увидел. Выполняли ли инструкцию далее? Что не получилось?
Актуальна ли еще ваша проблема?
Прошивку обновил через WebUI, загрузив туда файл прошивки. Вопрос с обновлением системы на новый релиз решен.
