Определение наличия датчика 1Wire на M1W2
Стали часто наблюдать такую картину, когда данные на External Sensor 1 то есть то нет (плавающая ошибка).
Но в топиках есть только два канала по температуре и серийник. На топике с серийником ошибки нет, но это так себе выборка.
Как понять где именно проблема?
Feb 08 18:35:39 IQ467000 wb-mqtt-serial[28564]: INFO: [mqtt] subscription succeeded (message id 1529)
Feb 08 18:35:41 IQ467000 wb-mqtt-serial[28564]: INFO: [modbus] Continuous read enabled [slave_id is 152]
Feb 08 18:35:41 IQ467000 wb-mqtt-serial[28564]: INFO: [modbus] Init: Input 1 set input 1 to 1-wire: setup register <modbus:152:holding: 275> <-- 0 (0x0)
Feb 08 18:35:42 IQ467000 wb-mqtt-serial[28564]: INFO: [modbus] Init: Input 2 set input 2 to 1-wire: setup register <modbus:152:holding: 276> <-- 0 (0x0)
Feb 08 18:35:42 IQ467000 wb-mqtt-serial[28564]: INFO: [serial device] device modbus:152 is connected
Feb 08 18:38:46 IQ467000 wb-mqtt-serial[31273]: WARNING: [serial config] Device WB-M1W2 152 wb-m1w2_152 (WB-M1W2) channel "External Sensor 1" is ignored: Serial protocol error: write and read register address are not defined
Feb 08 18:38:50 IQ467000 wb-mqtt-serial[31273]: INFO: [modbus] Continuous read enabled [slave_id is 152]
Feb 08 18:38:50 IQ467000 wb-mqtt-serial[31273]: INFO: [modbus] Init: Input 1 set input 1 to 1-wire: setup register <modbus:152:holding: 275> <-- 0 (0x0)
Feb 08 18:38:50 IQ467000 wb-mqtt-serial[31273]: INFO: [modbus] Init: Input 2 set input 2 to 1-wire: setup register <modbus:152:holding: 276> <-- 0 (0x0)
Feb 08 18:38:50 IQ467000 wb-mqtt-serial[31273]: INFO: [serial device] device modbus:152 is connected
Feb 08 18:41:06 IQ467000 wb-mqtt-serial[996]: WARNING: [serial config] Device WB-M1W2 152 wb-m1w2_152 (WB-M1W2) channel "External Sensor 1" is ignored: Serial protocol error: write and read register address are not defined
Feb 08 18:41:07 IQ467000 wb-mqtt-serial[996]: INFO: [mqtt] subscription succeeded (message id 1526)
Feb 08 18:41:07 IQ467000 wb-mqtt-serial[996]: INFO: [mqtt] subscription succeeded (message id 1527)
Feb 08 18:41:10 IQ467000 wb-mqtt-serial[996]: INFO: [modbus] Continuous read enabled [slave_id is 152]
Feb 08 18:41:10 IQ467000 wb-mqtt-serial[996]: INFO: [modbus] Init: Input 1 set input 1 to 1-wire: setup register <modbus:152:holding: 275> <-- 0 (0x0)
Feb 08 18:41:10 IQ467000 wb-mqtt-serial[996]: INFO: [modbus] Init: Input 2 set input 2 to 1-wire: setup register <modbus:152:holding: 276> <-- 0 (0x0)
Feb 08 18:41:10 IQ467000 wb-mqtt-serial[996]: INFO: [serial device] device modbus:152 is connected
Feb 09 12:53:47 IQ467000 wb-mqtt-serial[996]: WARNING: [modbus] failed to read 16 input(s) @ 17152 of device modbus:28: Serial protocol error: request timed out
Feb 09 13:20:32 IQ467000 wb-mqtt-serial[996]: WARNING: [modbus] failed to read 2 input(s) @ 7 of device modbus:152: Serial protocol error: request timed out
Feb 09 13:20:32 IQ467000 wb-mqtt-serial[996]: WARNING: [modbus] failed to read 2 input(s) @ 270 of device modbus:152: Serial protocol error: request timed out
Feb 09 13:20:34 IQ467000 wb-mqtt-serial[996]: WARNING: [modbus] failed to read 2 input(s) @ 7 of device modbus:152: Serial protocol error: request timed out
Feb 09 13:20:34 IQ467000 wb-mqtt-serial[996]: WARNING: [serial device] device modbus:152 is disconnected
Feb 09 13:21:02 IQ467000 wb-mqtt-serial[996]: INFO: [modbus] Continuous read enabled [slave_id is 152]
Feb 09 13:21:02 IQ467000 wb-mqtt-serial[996]: INFO: [modbus] Init: Input 1 set input 1 to 1-wire: setup register <modbus:152:holding: 275> <-- 0 (0x0)
Feb 09 13:21:02 IQ467000 wb-mqtt-serial[996]: INFO: [modbus] Init: Input 2 set input 2 to 1-wire: setup register <modbus:152:holding: 276> <-- 0 (0x0)
Feb 09 13:21:02 IQ467000 wb-mqtt-serial[996]: INFO: [serial device] device modbus:152 is connected
Feb 10 00:38:47 IQ467000 wb-mqtt-serial[1588]: WARNING: [serial config] Device WB-M1W2 152 wb-m1w2_152 (WB-M1W2) channel "External Sensor 1" is ignored: Serial protocol error: write and read register address are not defined
Feb 10 00:38:48 IQ467000 wb-mqtt-serial[1588]: INFO: [mqtt] subscription succeeded (message id 1525)
Feb 10 00:38:48 IQ467000 wb-mqtt-serial[1588]: INFO: [mqtt] subscription succeeded (message id 1526)
Feb 10 00:38:51 IQ467000 wb-mqtt-serial[1588]: INFO: [modbus] Continuous read enabled [slave_id is 152]
Feb 10 00:38:51 IQ467000 wb-mqtt-serial[1588]: INFO: [modbus] Init: Input 1 set input 1 to 1-wire: setup register <modbus:152:holding: 275> <-- 0 (0x0)
Feb 10 00:38:51 IQ467000 wb-mqtt-serial[1588]: INFO: [modbus] Init: Input 2 set input 2 to 1-wire: setup register <modbus:152:holding: 276> <-- 0 (0x0)
Feb 10 00:38:51 IQ467000 wb-mqtt-serial[1588]: INFO: [serial device] device modbus:152 is connected
Вообще, было бы удобнее видеть сразу в топиках на каком уровне произошла ошибка, какой-то код может выводить?
Нашел, что можно выводить статус подключения 1Wire, написал такой конфиг:
    "channels":
            "enabled": true,
            "name": "External Sensor 1"
            "enabled": true,
            "name": "External Sensor 1 OK"
    "device_type": "WB-M1W2",
    "enabled": true,
    "slave_id": "126"
Но в логах получаю ошибку:
Device WB-M1W2 126 wb-m1w2_126 (WB-M1W2) channel "External Sensor 1 OK" is ignored: Serial protocol error: write and read register address are not defined
wb-mqtt-serial новый, в шаблоне в /usr/share/wb-mqtt-serial/templates/config-wb-m1w2.json поле с OK присутствует.
Что не так написал?
В M1W2 регистр статуса датчика есть с прошивки 4.6
Если прошивка старше - то там регистра нет.
Прошивка 4.8 вроде (обновил до последней на релизе 2401).
Сам топик не появляется…
Беру WB-M1W2 с прошивкой 4.31.0
Настраиваю:
Ну и ожидаемо получаю при отключенном датчике:
Screenshot_20240212_111004
Разобрался, тип девайса нужно указывать WB-M1W2 BUTTONS :crazy_face:
Вот про это я не сказал, прошу прощения.
Правильно понимаю, что BUTTONS это просто для новой прошивки m1w2? Как бы v2?
Совместим ли он со старой прошивкой? Интересует именно чтение температуры, то что отвалится топик с “ОК” я понимаю.
Да, старый шаблон помечен как deprecated.
