При попытке доступа через tailscale ip, получаем пустой экран с следующей ошибкой в консоли:
libs.eac10661c139e4b03a9c.js:133 Uncaught Error: [$injector:modulerr] Failed to instantiate module realHomeuiApp due to:
Error: [$injector:nomod] Module ‘realHomeuiApp’ is not available! You either misspelled the module name or forgot to load it. If registering a module ensure that you specify the dependencies as the second argument.
https://errors.angularjs.org/1.8.3/$injector/modulerr?p0=realHomeuiApp&p1=Error%3A%20[%24injector%3Anomod]%20Module%20’realHomeuiApp’%20is%20not%20available!%20You%20either%20misspelled%20the%20module%20name%20or%20forgot%20to%20load%20it.%20If%20registering%20a%20module%20ensure%20that%20you%20specify%20the%20dependencies%20as%20the%20second%20argument.
https%3A%2F%2Ferrors.angularjs.org%2F1.8.3%2F%24injector%2Fnomod%3Fp0%3DrealHomeuiApp
%20%20%20%20at%20http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A833
%20%20%20%20at%20http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A180353
%20%20%20%20at%20i%20(http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A180038)
%20%20%20%20at%20http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A180324
%20%20%20%20at%20http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A25120
%20%20%20%20at%20k%20(http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A1538)
%20%20%20%20at%20v%20(http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A25066)
%20%20%20%20at%20rn%20(http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A24402)
%20%20%20%20at%20r%20(http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A10341)
%20%20%20%20at%20Ae%20(http%3A%2F%2F100.67.130.41%2Flibs.eac10661c139e4b03a9c.js%3A133%3A10654)
at libs.eac10661c139e4b03a9c.js:133:833
at libs.eac10661c139e4b03a9c.js:133:25409
at k (libs.eac10661c139e4b03a9c.js:133:1538)
at v (libs.eac10661c139e4b03a9c.js:133:25066)
at rn (libs.eac10661c139e4b03a9c.js:133:24402)
at r (libs.eac10661c139e4b03a9c.js:133:10341)
at Ae (libs.eac10661c139e4b03a9c.js:133:10654)
at Te (libs.eac10661c139e4b03a9c.js:133:9899)
at HTMLDocument. (libs.eac10661c139e4b03a9c.js:133:184301)
at c (libs.eac10661c139e4b03a9c.js:39:25650)
