Ошибка npm WARN tar ENOSPC: no space left on device, write
npm install -g --unsafe-perm node-red
Выдал ошибку
Порылся по форуму вот вывод самых популярных команд в похожих темах
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 976M 960M 0 100% /
devtmpfs 240M 0 240M 0% /dev
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 568K 248M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 248M 0 248M 0% /sys/fs/cgroup
/dev/mmcblk0p6 4.7G 1.5G 3.0G 34% /mnt/data
tmpfs 50M 0 50M 0% /run/user/0
такая вот тоже
:/# du -sh *
5.6M bin
9.8M boot
4.0K chroot_this.sh
0 dev
4.2M etc
8.0K home
74M lib
4.0K media
1.5G mnt
247M opt
du: cannot access ‘proc/28020/task/28020/fd/4’: No such file or directory
du: cannot access ‘proc/28020/task/28020/fdinfo/4’: No such file or directory
du: cannot access ‘proc/28020/fd/4’: No such file or directory
du: cannot access ‘proc/28020/fdinfo/4’: No such file or directory
0 proc
0 root
16K root.default
568K run
5.4M sbin
4.0K srv
0 sys
2.2M tmp
4.0K umount_chroot.sh
575M usr
30M var
5.1M ~
/mnt# df -h
Есть подозрение что где-то разросся лог
tail -f /var/log/messages
Sep 17 15:02:46 wirenboard-AF5IYJZ2 kernel: [266782.162148] Bluetooth: hci0: advertising data len corrected 28 → 12
Sep 17 15:03:00 wirenboard-AF5IYJZ2 ser2net[2455]: Could not open device /dev/ttyACM0 for port 8485: No such file or directory
Sep 17 15:03:07 wirenboard-AF5IYJZ2 npm[24038]: Zigbee2MQTT:info 2021-09-17 15:03:07: MQTT publish: topic ‘zigbee2mqtt/ZB_test’, payload ‘{“brightness”:64,“color_temp”:243,“last_seen”:1631890987792,“linkquality”:83,“state”:“OFF”}’
Sep 17 15:03:15 wirenboard-AF5IYJZ2 ser2net[2455]: Could not open device /dev/ttyACM0 for port 8485: No such file or directory
Sep 17 15:03:24 wirenboard-AF5IYJZ2 kernel: [266875.651148] Bluetooth: hci0: advertising data len corrected 28 → 12
Sep 17 15:03:31 wirenboard-AF5IYJZ2 ser2net[2455]: Could not open device /dev/ttyACM0 for port 8485: No such file or directory
Sep 17 15:03:37 wirenboard-AF5IYJZ2 wb-rules[1377]: Device “ppp0” does not exist.
Sep 17 15:03:46 wirenboard-AF5IYJZ2 ser2net[2455]: Could not open device /dev/ttyACM0 for port 8485: No such file or directory
Sep 17 15:03:57 wirenboard-AF5IYJZ2 kernel: [266913.946133] Bluetooth: hci0: advertising data len corrected 28 → 12
Sep 17 15:04:08 wirenboard-AF5IYJZ2 ser2net[2455]: Could not open device /dev/ttyACM0 for port 8485: No such file or directory
Sep 17 15:04:23 wirenboard-AF5IYJZ2 ser2net[2455]: Could not open device /dev/ttyACM0 for port 8485: No such file or directory
Sep 17 15:04:37 wirenboard-AF5IYJZ2 wb-rules[1377]: Device “ppp0” does not exist.
Место кончилось.
Здравствуйте! Да, место на устройстве /dev/root закончилось! Папка с логами /var занимает немного. Очень много занимает директория /opt и /usr. Проверьте, что там находится. Вероятно, было установлено какое-то стороннее ПО, которое и занимает место на устройства.
