Приветствую при попытки выполнить root@wirenboard:~# apt-get update && apt-get install wb-mqtt-mbgate выдает следующее. я та понимаю Modbus TCP не установился.
root@wirenboard-A6IZNJU7:~# apt-get update && apt-get install wb-mqtt-mbgate
Ign:1 http://releases.contactless.ru/stable/stretch stretch InRelease
Ign:2 http://deb.debian.org/debian stretch InRelease
Ign:3 http://deb.debian.org/debian stretch-updates InRelease
Ign:4 http://releases.contactless.ru/stable/stretch stretch Release
Ign:5 http://deb.debian.org/debian stretch Release
Ign:6 http://releases.contactless.ru/stable/stretch stretch/main armhf Packages
Ign:7 http://deb.debian.org/debian stretch-updates Release
Ign:8 http://releases.contactless.ru/stable/stretch stretch/main all Packages
Ign:9 http://releases.contactless.ru/stable/stretch stretch/main Translation-en
Ign:10 http://deb.debian.org/debian stretch/main all Packages
Ign:11 http://deb.debian.org/debian stretch/main armhf Packages
Ign:12 http://deb.debian.org/debian stretch/main Translation-en
Ign:13 http://deb.debian.org/debian stretch-updates/main all Packages
Ign:14 http://deb.debian.org/debian stretch-updates/main armhf Packages
Ign:15 http://deb.debian.org/debian stretch-updates/main Translation-en
Err:11 http://deb.debian.org/debian stretch/main armhf Packages
Cannot initiate the connection to deb.debian.org:80 (2a04:4e42:3a::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:3a::644 80]
Err:6 http://releases.contactless.ru/stable/stretch stretch/main armhf Packages
Unable to connect to releases.contactless.ru:http:
Err:14 http://deb.debian.org/debian stretch-updates/main armhf Packages
Ign:16 http://http.debian.net/debian stretch-backports InRelease
Ign:17 http://http.debian.net/debian stretch-backports Release
Ign:18 http://http.debian.net/debian stretch-backports/main armhf Packages
Ign:19 http://http.debian.net/debian stretch-backports/main all Packages
Ign:20 http://http.debian.net/debian stretch-backports/main Translation-en
Err:18 http://http.debian.net/debian stretch-backports/main armhf Packages
Cannot initiate the connection to http.debian.net:80 (2001:67c:2564:a119::77). - connect (101: Network is unreachable) [IP: 2001:67c:2564:a119::77 80]
Ign:21 http://security.debian.org stretch/updates InRelease
Ign:22 http://security.debian.org stretch/updates Release
Ign:23 http://security.debian.org stretch/updates/main all Packages
Ign:24 http://security.debian.org stretch/updates/main armhf Packages
Ign:25 http://security.debian.org stretch/updates/main Translation-en
Err:24 http://security.debian.org stretch/updates/main armhf Packages
Cannot initiate the connection to security.debian.org:80 (2a04:4e42:600::204). - connect (101: Network is unreachable) [IP: 2a04:4e42:600::204 80]
Reading package lists… Done
W: The repository ‘http://releases.contactless.ru/stable/stretch stretch Release’ does not have a Release file.
N: Data from such a repository can’t be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository ‘http://deb.debian.org/debian stretch Release’ does not have a Release file.
W: The repository ‘http://deb.debian.org/debian stretch-updates Release’ does not have a Release file.
W: The repository ‘http://http.debian.net/debian stretch-backports Release’ does not have a Release file.
W: The repository ‘http://security.debian.org stretch/updates Release’ does not have a Release file.
E: Failed to fetch http://releases.contactless.ru/stable/stretch/dists/stretch/main/binary-armhf/Packages Unable to connect to releases.contactless.ru:http:
E: Failed to fetch http://deb.debian.org/debian/dists/stretch/main/binary-armhf/Packages Cannot initiate the connection to deb.debian.org:80 (2a04:4e42:3a::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:3a::644 80]
E: Failed to fetch http://deb.debian.org/debian/dists/stretch-updates/main/binary-armhf/Packages Cannot initiate the connection to deb.debian.org:80 (2a04:4e42:3a::644). - connect (101: Network is unreachable) [IP: 2a04:4e42:3a::644 80]
E: Failed to fetch http://http.debian.net/debian/dists/stretch-backports/main/binary-armhf/Packages Cannot initiate the connection to http.debian.net:80 (2001:67c:2564:a119::77). - connect (101: Network is unreachable) [IP: 2001:67c:2564:a119::77 80]
E: Failed to fetch http://security.debian.org/dists/stretch/updates/main/binary-armhf/Packages Cannot initiate the connection to security.debian.org:80 (2a04:4e42:600::204). - connect (101: Network is unreachable) [IP: 2a04:4e42:600::204 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
