Отваливается вайфай и WBIO
8-02-2024 22:52:26.487 [wb-mqtt-serial] WARNING: </dev/ttyMOD1 9600 8 N 1>: closed due to repetitive errors
18-02-2024 22:52:20.213 [NetworkManager] IPV6CP: timeout sending Config-Requests
18-02-2024 22:52:19.085 [wb-mqtt-serial] WARNING: </dev/ttyMOD1 9600 8 N 1>: closed due to repetitive errors
18-02-2024 22:52:11.686 [wb-mqtt-serial] WARNING: </dev/ttyMOD1 9600 8 N 1>: closed due to repetitive errors
18-02-2024 22:52:04.141 [wb-mqtt-serial] WARNING: </dev/ttyMOD1 9600 8 N 1>: closed due to repetitive errors
18-02-2024 22:51:56.742 [wb-mqtt-serial] WARNING: </dev/ttyMOD1 9600 8 N 1>: closed due to repetitive errors
18-02-2024 22:51:50.535 [NetworkManager] Could not determine remote IP address: defaulting to 10.64.64.64
18-02-2024 22:51:50.202 [NetworkManager] kernel does not support PPP filtering
18-02-2024 22:51:49.329 [wb-mqtt-serial] WARNING: </dev/ttyMOD1 9600 8 N 1>: closed due to repetitive errors
18-02-2024 22:51:48.929 [NetworkManager] no servers found in /etc/resolv.conf, will retry
18-02-2024 22:51:48.877 [NetworkManager] [1708285908.7724] device (ttyUSB1): Activation: failed for connection ‘gsm 1’
18-02-2024 22:51:48.707 [ModemManager] [modem2/bearer3] checking if connected failed: PDP context not found in the known contexts list
18-02-2024 22:51:41.928 [wb-mqtt-serial] WARNING: </dev/ttyMOD1 9600 8 N 1>: closed due to repetitive errors
18-02-2024 22:41:41.978 [NetworkManager] [1708285301.9589] device (ttyUSB1): Activation: failed for connection ‘gsm 1’
18-02-2024 22:41:41.695 [NetworkManager] [1708285301.6935] device (wlan1): Activation: failed for connection 'WirenBoard’
Подскажите что это за ошибки. при этом вся связь отваливается. то от вайфая то вб-мио е2. который по лан кабелю. иногда может отвалиться и не подключаться. устройство вб мио е2 если включить все реле dor10a8 две штуки. подключал и по rs и по utp постоянно отвал. источник питания менял. связь менял. порты менял. может и разные проблемы. но вайфай отваливается на двух устройствах wirenboard
HW Revision
7.4.3
Serial Number
ASTPC63T
Batch No
7.4.3C/1GQ 1D/J-1G
(111,9 КБ)
Пожалуйста разверните описание, термин "отваливается совершенно не позволяет понять происходящее.
Для начала опишите активные интерфейсы, типы адресов на них, планируемую таблицу маршрутизации и ее приоритеты.
Затем - покажите в каком состоянии соединения (интерфейсы в “нормальном” состоянии и при (предположительных) проблемах.
Очень сильно помогут логи и результат опроса модуля с помощью modbus_client.
В частности - значения input регистров 104 и 105.
Точка доступа на вайрен боарде вайфай, если подключаюсь к ней с телефона или ноудбука переодически отключается. на одном устройствве все по дефолту просто отключается в разные промежутки времени,
на втором установлен модуль модбас в первый слот и модуль модема, вб мио был подключен к модую модбас ,если включать все реле на боковых модулях do10a (2 шт) . модуль зависал и реле начинали тактовать, питание подавал от разных источников и разным напряжением , перенес напрямую на ютп, ип адресс по умолчанию 192.168.0.7, на вайренбоарде установил 192.168.0.2 теперь при включении всех реле , каналы вб мио краснеют и не отвечают, помогает сброс питания в обоих случаях,
к сожалению подключиться не могу, приоритет связи
высокий : вайфай,
средний : 2 езернета и модем
к самому контроллеруу уже подключено 4 таких же боковых модулей, проблем нет
Покажите пожалуйста логи подключения. Вот например так: Wirenboard 7 невозможно подключить к точке доступа WIFI контроллера - #4 от пользователя BrainRoot
Что такое “модуль”? Модуль расширения? Если да - то как подключен его изолированный Gnd?
Какое в таком состоянии напряжение питания на MIO-E? Пингуется ли?
Состояния интерфейсов? Планируемая таблица маршрутизации и фактическая?
питание в том же в котором и было до включения всех реле, не просело ни на о,1 вольт, не пингуется, как будто зависает,
по состоянию интерфейсов не понял, мне главное чтоб я мог к нему подключиться по вайфай, и чтоб связь была стабильной, никакой маршрутизации нет, только вайфай и симкарта, иногда точка доступа может пропасть на устройстве и приходится перегружать по несколько раз его чтоб подцепиться
на данный момент связь по симкарте пропала, а от вайфая я очень далеко, если появится, какие данные вам надо скинуть чтоб вы смогли подключиться и посмотреть где я мог накосячить, в вайренборде не силен, все делал на овенах, вот решил попробовать вайрен , и уже в отчаянии, объект пришлось запускать сырым, это фонтан в общественном месте, и любая проблема с ним выливается в негодование заказчика
Так.
Попробую описать как я виду текущую конфигурацию.
Контроллер, к нему подключены несколько WB-LED на шину “/dev/ttyRS485-2”
пара сторонних устройств и WB-MR6C на порт “/dev/ttyMOD1”
WB-MIO-E с адресом настроенное как Modbus TCP с адресом 192.168.0.7 по сети. На шину WBIO этого модуля - 2 WBIO-DO-R10A-8.
Все верно?
В диагностическом архиве - нет данных, точнее есть всего за пару минут так как включен Debug для wb-mqtt-serial.
Ну и по порядку, про ошибки порта расширения - куда подключен (и подключен ли) Gnd изолированного порта “/dev/ttyMOD1”?
Про связь с WB-MIO. Вижу что сконфигурирован eth1 как 192.168.0.3/24
Продолжает ли успешно пинговаться адрес 192.168.0.7 когда с модулем нет связи?
Совершенно необходимо знать для диагностики.
Wi-fi - как он (сейчас) настроен? интересует конфиг обоих интерфейсов.
То есть - как задуманы подключения, как они должны работать.
Ну и логи, естественно.
Вообще для начала надо обновить пакеты, штатным apt update && apt upgrade -y/
