Добрый день, уважаемая тех поддержка.
Воспользовался инструкцией по переустановки zigbee2mqtt.
Пришлось потому что была проблема с многократным приходом событий от устройств.
Результат zigbee2mqtt не стартует:
03-10-2024 11:16:23.299 at start (/mnt/data/root/zigbee2mqtt/index.js:154:5)
03-10-2024 11:16:23.299 at Controller.start (/mnt/data/root/zigbee2mqtt/lib/controller.ts:140:27)
03-10-2024 11:16:23.299 at Zigbee.start (/mnt/data/root/zigbee2mqtt/lib/zigbee.ts:64:27)
03-10-2024 11:16:23.299 at Controller.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:138:29)
03-10-2024 11:16:23.299 at ZnpAdapterManager.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:57:26)
03-10-2024 11:16:23.299 at ZnpAdapterManager.determineStrategy (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:246:35)
03-10-2024 11:16:23.299 [2024-10-03 08:16:23] e[31merrore[39m: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
03-10-2024 11:16:22.687 [2024-10-03 08:16:22] e[31merrore[39m: z2m: Exiting...
03-10-2024 11:16:22.685 [2024-10-03 08:16:22] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
03-10-2024 11:16:22.683 [2024-10-03 08:16:22] e[31merrore[39m: z2m: Failed to start zigbee
03-10-2024 11:16:22.675 [2024-10-03 08:16:22] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
03-10-2024 11:16:22.672 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
03-10-2024 11:16:22.668 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /mnt/data/root/zigbee2mqtt/data/coordinator_backup.json.
03-10-2024 11:16:22.662 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
03-10-2024 11:16:22.656 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: - Channel List: configured=11, adapter=11
03-10-2024 11:16:22.650 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: - Network Key: configured=1a029a9d0e17d27d18c322bf8770551b, adapter=c128960407fdde4f42c6952e6a750c37
03-10-2024 11:16:22.643 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: - Extended PAN ID: configured=00124b0025906215, adapter=00124b0025906215
03-10-2024 11:16:22.637 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: - PAN ID: configured=26702, adapter=35834
03-10-2024 11:16:22.632 [2024-10-03 08:16:22] e[31merrore[39m: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
03-10-2024 11:16:22.392 [2024-10-03 08:16:22] e[32minfoe[39m: zh:zstack:znp: Serialport opened
03-10-2024 11:16:22.355 [2024-10-03 08:16:22] e[32minfoe[39m: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD4","baudRate":115200,"rtscts":false,"autoOpen":false}
03-10-2024 11:16:17.054 [2024-10-03 08:16:17] e[32minfoe[39m: z2m: Starting zigbee-herdsman (0.57.3)
03-10-2024 11:16:17.039 [2024-10-03 08:16:17] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
03-10-2024 11:16:16.952 [2024-10-03 08:16:16] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
03-10-2024 11:15:57.572 Starting Zigbee2MQTT without watchdog.
03-10-2024 11:15:55.421 > node index.js
03-10-2024 11:15:55.421 > zigbee2mqtt@1.40.1 start
Вопрос, как правильно переустанавливать с сохранением конфигурации и без повторного спаривания устройств?
