Периодическая перезагрузка контроллера WB7.4
Прошу помощи в установлении причин периодической перезагрузки контроллера WB7.3.4, wb-2404.
В системном журнале периодическое (раз в несколько часов) появление одних и тех же ошибок:
27-08-2024 21:18:21.587 [wb-mqtt-mbgate]	ERROR: [mbgate] FATAL: Configuration error: All channels are disabled
27-08-2024 21:18:13.367 [wb-mqtt-iec104]	ERROR: [main] FATAL: Configuration error: No enabled groups found!
27-08-2024 21:18:12.787 [wb-mqtt-opcua]	ERROR: [main] FATAL: Configuration error: Found no enabled groups!
27-08-2024 21:18:08.988 [NetworkManager]	<error> [1724782688.9818] audit: failed to open auditd socket: Protocol not supported
27-08-2024 21:18:07.677 [ntp]	unable to create socket on wlan0 (7) for fe80::c63c:b0ff:fee6:b7cc%5#123
27-08-2024 21:18:07.676 [ntp]	bind(23) AF_INET6 fe80::c63c:b0ff:fee6:b7cc%5#123 flags 0x11 failed: Cannot assign requested address
27-08-2024 21:18:04.628 [wpa_supplicant]	Using interface wlan0 with hwaddr c4:3c:b0:e6:b7:cc and ssid "WirenBoard-A2IWJBK7"
27-08-2024 21:18:04.584 [init.scope]	Timed out waiting for device /dev/mmcblk1p1.
27-08-2024 21:17:56.535 [bluetooth]	sap-server: Operation not permitted (1)
27-08-2024 21:17:56.534 [bluetooth]	profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
27-08-2024 21:17:50.481	vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
27-08-2024 21:17:50.477	dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
27-08-2024 21:17:50.476	sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0  on device 1c20800.pinctrl
27-08-2024 21:17:50.475	sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
27-08-2024 21:17:50.473	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
27-08-2024 21:17:50.472	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PA regulator
27-08-2024 21:17:50.470	sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
27-08-2024 21:17:50.469	sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8  on device 1c20800.pinctrl
27-08-2024 21:17:50.467	sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
27-08-2024 21:17:50.466	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
27-08-2024 21:17:50.465	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
27-08-2024 21:17:50.464	sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
27-08-2024 21:17:50.463	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
27-08-2024 21:17:50.462	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
27-08-2024 21:17:50.459	dw-apb-uart 1c28800.serial: Error applying setting, reverse things back
27-08-2024 21:17:50.458	sun4i-pinctrl 1c20800.pinctrl: could not request pin 274 (PI18) from group PI18  on device 1c20800.pinctrl
27-08-2024 21:17:50.457	sun4i-pinctrl 1c20800.pinctrl: pin-274 (1c28800.serial) status -517
27-08-2024 21:17:50.455	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 274
27-08-2024 21:17:50.454	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PI regulator
27-08-2024 21:17:50.451	sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
27-08-2024 21:17:50.423	sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
27-08-2024 21:17:50.415	/cpus/cpu@3 missing clock-frequency property
27-08-2024 21:17:50.415	/cpus/cpu@2 missing clock-frequency property
27-08-2024 21:17:50.415	/cpus/cpu@1 missing clock-frequency property
27-08-2024 21:17:50.415	/cpus/cpu@0 missing clock-frequency property
27-08-2024 08:39:53.796	i2c i2c-2: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x60, flags: 0x1
27-08-2024 08:39:53.796	i2c i2c-2: mv64xxx_i2c_fsm: Ctlr Error -- state: 0x7, status: 0x0, addr: 0x60, flags: 0x1```
diag_output_A2IWJBK7_2024-08-28-07.52.35.zip (262,1 КБ)
архив диагностики
Проверьте пожалуйста что на контроллер не установлен fit от 7.4
как это сделать?
Оптимально - выполните factory reset акутуальным (2407) fit файлом.
Дополнительное ПО (nodeJS) - не устанавливать, проверить будет ли воспроизводиться.
Хотелось бы узнать, удалось ли вам решить проблему? Если у вас возникли дополнительные вопросы или нужна помощь, не стесняйтесь обращаться!
